It is currently Sun Jul 27, 2025 9:34 am
Post new topic Reply to topic  [ 70 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon May 06, 2013 12:31 pm
pat macaluso wrote:
Alain Moisan wrote:
after over 70 guitars, I'm still using the same bit. I have not experience much tearout, if any (climb cut is the secret)
Wow! What bit do you use? Pro sharpen? How often?
Stewmac. Never reshaprened.
(Although my bit is more than due for a replacement, I have to admit!)
Alain Moisan
(Now building just for fun!)
PostPosted: Mon May 06, 2013 1:14 pm
I have a stewmac bit and bearing set that I never used, if anyone wants it.
I also have a tru-channel setup that I never used, except for the body carriage pieces, which I like.
Old growth, shmold growth!
PostPosted: Mon May 06, 2013 1:23 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
got a price in mind?
PostPosted: Mon May 06, 2013 5:00 pm
Just pay me for shipping. Probly fit into a $5 flat rate box. Let get home and find them first.
PostPosted: Mon May 06, 2013 5:47 pm
First name: Zeke
Last Name: McKee
Is that for the true channel too? If so I love you!
PostPosted: Mon May 06, 2013 6:31 pm
My only problem with all of these carriage systems is that they don't do as well at dealing with steeply arched and tapered guitar backs, or wedge guitars. With his old system, one can have the bearings on the side and keep the bearing plate fairly parallel with the back, allowing for an even depth cut. The carriage systems cannot adjust to the taper because their positions are fixed and consequently their cuts run away from the guitar at the headblock or on the sides on a wedge. Incidentally, Ribbecke's original jig was designed to allow the laminant trimmer to tilt side to side to follow the plate. That part of the design wasn't implemented when LMI offered the plans so many years ago.
PostPosted: Mon May 06, 2013 7:57 pm
I thought about that too when looking at the tru-channel stack. I'm not sure that'd be too huge a problem for most acoustics, but it was originally a consideration of mine when deciding to use the handheld unit to more accurately follow the arch. What pushed me over the edge to the Luthier Tools unit was the bearing system though. It didn't seem the best for my personal sensibilities.
Well, the tru-channel won't fit in the flat rate box. :D
PostPosted: Mon May 06, 2013 8:20 pm
First name: Zeke
Last Name: McKee
well im more interested in the tru-channel than the bits, if you would like to sell the tru-channel that may be able to be arranged. Or I can send you a bigger box laughing6-hehe just let me know if ya want it out of your way.
PostPosted: Mon May 06, 2013 10:17 pm
Last Name: A
I'll take the bits if they are still up for grabs - be glad to pay the shipping. Looks liek teh Tru Channel is spoken for already - let me know if you change your mind ZekeM.
PostPosted: Mon May 06, 2013 11:51 pm
Hmm. I may have a use for the tru-channel, though. I think the Luthier Tools cutter head can be mounted to the tru-channel thing.
PostPosted: Tue May 07, 2013 3:30 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
I copied Chris Paulik's binding cutter http://www.youtube.com/watch?v=Ve_PmQMS ... E1A7DA0FAC
Uses a downward spiral cutter. Cost me nothing to build. Works great.
We are all in the gutter but some of us are looking at guitars.
PostPosted: Tue May 07, 2013 5:43 am
First name: Zeke
Last Name: McKee
that's cool. I'll just have to quit being lazy and build me one. :)
PostPosted: Tue May 07, 2013 8:25 am
First name: Nelson
Last Name: Palen
I see a couple problems with the Luthier's Tools setup: The bearing is too far away from the cut which would cause serious inconsistency in the depth of cut. Also, without being able to see exactly how the tool is operated, it appears that the operator would have to precisely maintain the perpendicularity of the bearing to the surface being cut or there would again be serious depth of cut inconsistency. Please correct me if I'm wrong or not seeing the whole picture.
Edit: I see, after looking at the description, that the tool is self-aligning to the guitar outline. Not sure how this works but that should take care of the perpendicularity issue mentioned above.
PostPosted: Tue May 07, 2013 1:35 pm
Depends on how good your sides are.
The bearing can be moved up some too, I believe.
My handheld unit has two bearings, which are held against the side, and ride out any inconsistencies.
Paulick's video brings out a good point as well, the sides of the guitar must be perpendicular to the table surface, that would be the same with this (and ANY) carriage setup.
I'd forgot about that since my current method makes that a moot point, but my shoulders are tipped back to create the neck angle, so that would present a slight problem, since when the sides and tail of the guitar body are perpendicular to the table, my shoulders are not.
So the handheld unit for me registers off the sides perfectly, rides out any arch to the back or sides, has infinite depth and height adjustment, uses a spiral down cut router bit, works with my tipped shoulders, and is fast and easy to operate.
If carriage systems were my thing, this would take the cake, but I might as well just stop kidding myself.
I'm just a handheld unit kinda guy!
(I'm sure SOME of you will find that last sentence amusing, you sick puppies....)
PostPosted: Tue May 07, 2013 4:40 pm
I DO think that this unit would work perfectly as a dedicated solid body binding router. The handheld seems a little cumbersome for that.
PostPosted: Wed May 08, 2013 10:54 am
Todd Stock wrote:
All of these binding cutters register off the surface of the top or back, so depending on where the guide rides, there will be some reduction in depth, but on a flattop, only the run from 2" into the lower bout and around the upper back will be noticeably shallower. Easy to use a wheel type marking gauge to clean up the channel, and the slight angle on the bottom of the binding channel is usually not much of an issue with the bevel that most of us use on the inside corner.
Interesting. I haven't noticed any depth reduction, and I haven't chamfered any inside corners on any of my binding.
That hasn't been an issue for me.
I actually don't like the idea of an inside bevel, why reduce the gluing surface area?
PostPosted: Wed May 08, 2013 11:05 am
I'm on my second StewMac cutter, at over 100 instruments between the two. Haven't worn out a bearing, yet.
If I think a top will be splintery(after a while, you get a feel for wood...) I'll cut the top's purfling channels with a 1/4" downcut spiral bit using a hand held Porter Cable 310, with a simple wooden "finger" clamped to the base as a bearing/guide. Works great, costs nothing. There isn't any taper to the top's surface, so a hand held router works just fine for the purfling channels. I've never experienced a situation when routing a back that required a spiral bit.
I also don't like the idea or the bearing being so far away from the cut; even the best factory acoustic guitars have sides that are slightly less than perpendicular, and often slightly "wavy", enough so that the cut will not be true every time. Bearings are also a much quicker method of changing the cut depth, and 100% consistent, every time, where you'll be adjusting, and making test cuts, adjusting, more test cuts, etc... for every. single.cut. with the above system.
PostPosted: Wed May 08, 2013 11:18 am
Anyone have a source for bearings for the stew mac rig? Need some intermediate sizes that they don't sell. Have wraped with tape to build up diameter, but would prefer the proper size bearing.
PostPosted: Wed May 08, 2013 8:46 pm
I'm with you all the way on this.
Alain Moisan
PostPosted: Thu May 09, 2013 12:37 am
Filippo Morelli wrote:
There is a difference in binding height no doubt. Whether you discern it or not is the question.
I cut my bindings just as Todd does, except Todd chooses to true up the ledge height. I've seen him do it and seen the thin sliver off wood that gets removed off the ledge. I, on the other hand, ignore this difference as I don't think it is that relevant. Each to his own ... but it's definitely there!
Filippo
No, I just took my latest acoustic out and measured it. It's exactly 3/16th's in height all the way around the back of the instrument at all the 20 or so points of measurement that I measured. That's exactly the height it was when I made it, so my binding ledge was absolutely consistent to the binding all the way around the instrument.
But I agree, if it WERE there, I would likely consider it irrelevant as well and likely wouldn't true it up.
So what causes that for you guys? Does it have something to do with the sliding carriage system? Just curious.
PostPosted: Thu May 09, 2013 12:42 am
You really believe that chamfering the inside of that edge is going to reduce the surface area in any way whatsoever? What's that like 2% of the glue surface area over something that is continuously glued in two dimensions?
Filippo
I just think that the bottom edge is already thin enough, chamfering it would reduce it further. If binding is 3/32 wide and the chamfer removes even as little as 1/64th of an inch, that would actually be roughly 15% of the gluing surface area of the bottom edge.
But I guess it doesn't really matter though, it's not going to come unglued.
To each his own!
PostPosted: Thu May 09, 2013 12:21 pm
So you measure 0.1875" with zero variation? It's a small amount (which is why I'm not concerned), but when you mention the depth in fractions, you'll not measure any variation.
Filippo
I forgot to mention that I'm extremely nearsighted. I can read the microprinting on check signature lines.
No kidding.
At that magnification 3/16th might as well be a foot, it takes up my entire field of view.
So yes, I can see exactly where the binding lines up to the ruler, exactly in the centers of the black index lines.
Yes, zero variation.
PostPosted: Thu May 09, 2013 12:31 pm
Todd Stock wrote:
Usual practice in cabinetmaking is to trim corners strips, binding, etc. to fit towards the show edges...that means that we chamfer the inside corner to prevent any issues with dimensional change on the trim piece. Trim is very seldom structural, so we accept a slightly thicker glue line over a small area of the joint to achieve a tight fit at the show surface...even after scraping and sanding away material. The only reason why we would worry about glue on the narrow edge of the binding is to seal that joint and prevent wicking of finish if we choose not to use an adhesive filler such as mahogany or shellac/pumice. What we don't want is a joint where the binding does not seat, due to debris in the joint, slightly mis-milled, or dimensional change of the binding when it gets wet with a waterbased adhesive. Also - for fiber/wood/fiber side purfing which many builders use, there's not much advantage to be gained in maximizing glue area - we're more concerned with a really tight, clean joint.
Ah, standard practice for cabinetmaking.
OKay, I can see that, if indeed it's not truly structural on an acoustic guitar.
However, I notice a difference in response of the box when I rout for bindings, that is restored somewhat when tghe binding is glued.
To that end I've endeavored to develop as tight and complete a binding ledge joint as is humanly possible, to minimize the possible impact of routing for bindings, to the best of my abilities.
That's one reason Ive started making my own bindings, as I've been unhappy with the trueness I get from manufacturers.
Maybe it's in my head, but I think every bit adds up to a whole.
First name: Zeke
Last Name: McKee
The issue is not your eyesight. It's the fact that you are using a ruler to measure. That's not an accurate enough form of measurement to detect the variation.
PostPosted: Thu May 09, 2013 12:44 pm
Sure it is. Even if the ruler is not exactly 3/16th, the distance between the two points of measurement stays the same at that point on the ruler, so I can detect whether or not the binding is that particular distance. It lines up on the center of the black index marks. They're not very wide.
I can see a thousandth of an inch difference with my eyeball at that distance no problem.
Hard for you to believe, I know.
But just so you are aware I got my dial caliper out, measured it, same result. .190 all around.
I measured a point, locked the caliper, checked all around.
Frankly,I'm a little surprised myself, considering that the final sanding shoulkd have likely caused a s little more variation, but no.
I'm very careful about that too, though.
Last edited by theguitarwhisperer on Thu May 09, 2013 12:50 pm, edited 1 time in total.
Users browsing this forum: bobgramann, doncaparker and 14 guests
