It is currently Wed Aug 20, 2025 4:46 am
PostPosted: Thu Apr 25, 2013 9:24 pm
Anyone know a good way? Jig?
PostPosted: Thu Apr 25, 2013 9:42 pm
Last Name: Ensor
City: Springfield
State: Missouri
Flexible long ruler.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Thu Apr 25, 2013 10:38 pm
Pat, if the headstock blank is still square, I would use a try square registered off the top of headstock. Match the two lines up.
PostPosted: Fri Apr 26, 2013 12:17 am
I sand flat one edge of the neck blank on the edge sander, then sand the FB and headstock plane square to that. That side becomes my reference surface. I use a square to mark the FB plane HS transition, the end of the nut slot, and the body join. Then I use one of those tools with an adjustable arm with a nail coming through it that butts against the edge of the neck. Basically it marks a small hole where you press it into the wood. The next hole will be the same distance from the surfaced edge. Two hole is the hs plane, two in the FB, connect the dots and boom"
PostPosted: Fri Apr 26, 2013 5:22 am
First name: Derek
Last Name: Dowding
City: Wallsend
Zip/Postal Code: 2287
Near enough for jazz. (Apologies for the crude sketch)
I've got a mind like a steel......whatsername!!?
PostPosted: Fri Apr 26, 2013 7:42 am
First name: Danny
Last Name: Vincent
http://www.google.ca/search?q=centre+fi ... 77&bih=891
PostPosted: Fri Apr 26, 2013 9:10 am
Last Name: A
I just measure the centerline on the neck blank at the 12th and the 1st fret, and then at the bottom of the headstock and the top of the headstock, connect the dots. Draw line before any shaping.
PostPosted: Fri Apr 26, 2013 11:08 am
If one side is still straight and square, I've had great luck with one of these Incra T-rules:
PostPosted: Fri Apr 26, 2013 11:46 am
Nice ruler! My biggest challenge is getting a centerline on the headstock that is in direct line with the truss rod slot to use in positioning the headstock veneer that already has the logo installed and then later pinning the routing template in proper position to shape the headstock making sure the logo is still centered.
This is what I've been doing lately.
Put a true side on one side of the neck blank (as several others have mentioned) and use that against the router fence when routing the truss rod slot.
Use a fretboard surrogate with dowel pins in the midline that fit snugly in the truss rod slot and which has a center marker on the end.
Measure the distance to the trued edge and use that measurement to mark the peghead upstream and draw a line.
This has worked well so far. I always double check it by making sure the nut slot is a uniform width when the peghead veneer is clamped on.
PostPosted: Fri Apr 26, 2013 5:56 pm
Draw lines at each side of the neck at the nut, equal distances from the center line. Draw an arc from each of the points, onto the peg head. Where the two arcs intersect is the center line of the peg head. Measuring from the edge of the peg head will only work if your peghead is symetrical and the blank is squared up.
James
PostPosted: Fri Apr 26, 2013 11:49 pm
Last Name: Shanklin
City: Windsor
State: ON
http://www.amazon.com/Incra-RULE18-18-Inch-Rules-Marking/dp/B0000DD2UT
Very flexible and works great for me.
Bob
PostPosted: Mon Apr 29, 2013 7:29 pm
I can't believe that Stew-Mac haven't devised a dedicated tool for this purpose. ;)
Pete
PostPosted: Tue Apr 30, 2013 7:28 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
this thread is great- so many methods. I have to admit being a bit off sometimes when it comes to this. For me the winner is
James
have to try that next time, thanks James.
We are all in the gutter but some of us are looking at guitars.
PostPosted: Tue Apr 30, 2013 7:59 am
Todd Stock wrote:
If the neck is straight, just use a combo square - adjust blade to half of neck and peg head width...mark from both sides...centered between the marks will be the center point. Works on already-shaped headstock if symmetric. If a flexible ruler is not torqued or twisted, it can be used to lay out the line.
+1
Mountain Song Guitars www.mountainsongguitars.com
PostPosted: Tue Apr 30, 2013 8:59 pm
there was ar least one purpose built tool created for this purpose by a lutherier/toolmaker in bc. lmi briefly sold his creations in the late '90's. absolutely beautiful tools at equally beautiful prices. i have no idea if he still makes them.
a more reasonably priced but by no means cheap solution is the brige city tools corner square.
PostPosted: Wed May 01, 2013 7:27 am
First name: joseph
Last Name: sallis
Country: UK
Filippo Morelli wrote:
I don't understand why the arcs are helpful. Once you have a centerline on the fingerboard you can even take a sheet of paper and have a project that centerline on the peg head.
Filippo
Filippo, I think you're right. After writting my last post I thought about it and came to the conclusion I'm more likely to get it wrong with drawing arcs than with a ruler.
PostPosted: Wed May 01, 2013 5:45 pm
First name: Rusty
Incra flexible rules work very well and so does their centering rule.
INCRA Precision Specialty Rules -
12" Precision Centering Rule
Part Number: CENTER12 & CENT300M
Sent from my iPad using Tapatalk HD
