It is currently Wed Aug 13, 2025 7:55 pm
 Post subject: tortoise material
PostPosted: Mon Mar 04, 2013 11:05 pm
First name: Matthew
Last Name: Wehrle
City: sullivan
State: il
Zip/Postal Code: 61951
Country: united states
Where's the best place to get tortoise material for use as headstock veneer?
 Post subject: Re: tortoise material
PostPosted: Mon Mar 04, 2013 11:31 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Maybe this would work. http://www.stewmac.com/shop/Pickguards/ ... ments.html
Alex
PostPosted: Mon Mar 04, 2013 11:46 pm
First name: Mark
City: Concord
Test whatever you end up choosing with a light wood (Holly, Maple, etc) veneer, white or reflective layer under it. It will look pretty flat if you don't.
PostPosted: Tue Mar 05, 2013 7:16 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
This guy has real celluloid but you have to pay the hazardous shipping fee $$$
http://www.axinc.net/category_s/47.htm
Kevin Looker
I'm not a luthier.
PostPosted: Tue Mar 05, 2013 9:21 am
"Real celluloid" will shrink over time, unfortunately, and never stops degrading.
Here's my 'Tortoloid' material used as a mandolin headstock; unfortunately, I can't find any photos of the completed instrument at this time, but I think it worked out pretty well. I would also highly recommend a light-colored veneer under whatever you choose, and if the veneer has some figure(flamed maple!) it will add that little "something extra" to the appearance, too.
PostPosted: Tue Mar 05, 2013 11:44 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
+1 for Mario's Tortoloid, I have not seen it on a headstock but as a pickguard it looks great and is easy to work with. Mario how did you attach it to the mandolin headstock?
Fred
Fred Tellier
PostPosted: Tue Mar 05, 2013 12:29 pm
I also will say Mario's will be better than the acetate and celuloids.
PostPosted: Tue Mar 05, 2013 2:50 pm
I'd also like to be able to get Mario's stuff for overlays and electric pickguards, especially in larger and thicker (@.120") sheets. I've been using the S-Mac stuff linked to above for electric pickguards and it's nice but a little dark and a touch brittle when routing out.
PostPosted: Tue Mar 05, 2013 3:20 pm
City: chicagoland
State: illinois
you should also be able to spray the underside of the material with a light colored paint, or even put a foil backing on it perhaps, to make it "pop" a bit better, if laying it over a light colored wood isn't an option
PostPosted: Tue Mar 05, 2013 4:10 pm
I used the same 3M transfer adhesive we use to attach the pickguards; it's permanent enough. John Greven's Tor-Tis material is similar, so between the two of us, there should be a headplate for to suit most everyone's tastes, yet it surprises me how few of them we see used this way. Well, actually, given how pretty woods are, and since we're all wood fanatics, it's not so surprising, I suppose....
Mike, I have some ideas for development of a thicker, less flexible sheet, but haven't had enough free-time(ha! what the he!! is that...?) to work-out the colors(the thicker the final sheet, the less dye it will need), much less the correct raw materials. The Tortoloid material will remain slightly flexible forever, which is great when it's fixed to an acoustic instrument(because it will not stiffen the top...), but it also means that even if I made it at .120", it would still eventually sag if unsupported, as it would be near the pickup cavities and such.
Hadn't considered backing it with foil, but that would possibly also open-up further variations(gold foil, copper foil, crinkled, etc...).
PostPosted: Thu Mar 07, 2013 12:28 pm
"Mike, I have some ideas for development of a thicker, less flexible sheet, but haven't had enough free-time(ha! what the he!! is that...?) to work-out the colors(the thicker the final sheet, the less dye it will need), much less the correct raw materials. The Tortoloid material will remain slightly flexible forever, which is great when it's fixed to an acoustic instrument(because it will not stiffen the top...), but it also means that even if I made it at .120", it would still eventually sag if unsupported, as it would be near the pickup cavities and such."
For my uses the stiffness wouldn't matter, I don't do 'swimming pool' routes because in a tortoise-style material I don't mind the wood showing through.
Here's pics of the Stew-Mac stuff on a recent build.
http://www.tdpri.com/telephoto/data/1312/Photo_770.jpg
http://www.tdpri.com/telephoto/data/1312/Photo_7561.jpg
Users browsing this forum: Ken Lewis and 31 guests
