It is currently Sat Aug 16, 2025 4:50 am
PostPosted: Mon Mar 04, 2013 12:44 pm
I finished up my first Post-Somogyi guitar yesterday. I attended his voicing workshop back in november.
I've played it for about 4 hours so far. It's a real joy. I will hate to see it go.
I'll post some final photos on the OM gallery.
Cheers, Michael
PostPosted: Mon Mar 04, 2013 1:13 pm
Shellac, I command thee to come out of the pad and go onto the guitar!
Sent from my GT-I9300 using Tapatalk 2
PostPosted: Mon Mar 04, 2013 1:16 pm
Took the neck off of my "Big Mouth" challenge guitar and started to rework the profile. First time I've gotten back in the shop in several weeks
Got the 1 and 9 profiles done now just need to connect the dots.
PostPosted: Mon Mar 04, 2013 1:27 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Glued the bridge on a uke and realized I hadn't drilled the string holes in tie block. Todd S came up with a brilliant and elegant jig to extend a 1/6" bit, and got the holes drilled. Also sprayed first coats of lacquer for the very first time (on an OM).
PostPosted: Mon Mar 04, 2013 1:30 pm
SteveSmith wrote:
Steve, what kind of vice is that?! Looks killer!
PostPosted: Mon Mar 04, 2013 1:42 pm
It's a StewMac Ultimate Vise. An expensive present to myself last year and, in my opinion, worth every cent I paid for it. Earlier versions apparently had quality problems but I have not seen any of that with the one I bought.
http://www.stewmac.com/shop/Tools/Vises/Ultimate_Vise.html
PostPosted: Mon Mar 04, 2013 2:47 pm
Last Name: Renick
City: Mount Shasta
State: ca
Zip/Postal Code: 96067
Country: us
Been a while since I have posted, scored a new to me drill press, from the 1940's, Walker Turner, made in Plainfield NJ, right by where I grew up, not when though. Nicely restored, quill lock and depth stop, not all bench models have these. Smooth running and classy, very proud to have this in my shop. Not much new guitar work, but this kalimba is just finished. The wood is reclaimed from an old piano.
Rob
http://shastaguitar.com/
http://www.kalimbakit.com/
PostPosted: Mon Mar 04, 2013 3:17 pm
First name: Tony
Last Name: C
City: Brooklyn
Should have punched it just to teach the rest of your wood stash a lesson. Believe me, there have been no issues with any of my wood since I punched that challenge uke. laughing6-hehe
http://www.CostaGuitars.com
PMoMC
PostPosted: Mon Mar 04, 2013 3:56 pm
First name: micah
Last Name: medlong
City: parma
State: ohio
Zip/Postal Code: 44129
He's right! when I went over his place to see his stash, all of the wood was shaking in fear when he walk in the room.
PostPosted: Mon Mar 04, 2013 4:05 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I was pore filling the 2 Ziricote guitars, the 12 fret 00 cutaway is ready for lacquer and I just put the thinned last coat on the OM. I really like the West system 105/207 combination that the Z-coat thread evolved into last week.
I posted this on the other thread but since it is actually on photobucket I guess it won't be a problem posting again.
The specks on the back are dust that I did not notice until I looked at the picture and I am too lazy to go do it again
Fred Tellier
PostPosted: Mon Mar 04, 2013 4:28 pm
Fretboard binding and fretwork on a 12-fret Serenade double top. Got them all made, semi-hemi ends and pressed in. They all leveled off with just the thinnest line of level, so I musta done somfin' right for a change.
Alan D.
PostPosted: Mon Mar 04, 2013 4:43 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
Building a couple Parlors. 1st one is an Ind Rosewood/Sinker Cedar cutaway. The second is Black Limba (from the Sniggs) and a Lutz spruce top.
P#12 Ind RW/Sinker Cedar Cutaway (steel string)
P#13 Black Limba/Lutz Cutaway (nylon string)
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Mon Mar 04, 2013 5:16 pm
Here's a few I'm working on, currently in various stages of completion.
PostPosted: Mon Mar 04, 2013 5:45 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
More pore fill on the Newbie Challenge guitar and #3. Thicknessed, bent the sides and joined the back for #4 which will be an EIR/Adi slope D for a friend. Also a couple more tongue drums.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Mon Mar 04, 2013 6:36 pm
First name: nick
Last Name: dingle
While I'm waiting for a bit of dry weather and the attendant acceptable RH's to do much more on my two newbie challenge builds, I've been working on this toy.....
PostPosted: Mon Mar 04, 2013 7:35 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
I know you're right about this, but then the uke gave me that look....you know the one that says "I'm so sorry and I'll never trouble you again" so I didn't do it. But you better believe I shook my finger (i not m) at it in admonishment!
PostPosted: Mon Mar 04, 2013 8:08 pm
Last Name: Kincheloe
Workin' on my harp guitar. Tuners are pegheds, so ream some holes...
Order of operations is important here, because the last hole is very close to the heel, so the handle of the reamer would run into it if I didn't do this before gluing the heel on. That headplate is curly osage orange, sliced from a chunk I found on the ground while hiking :)
Then lots of carving before and after gluing the heel... still needs final sanding.
Also working on the neck. So much more fun plow planing truss rod slots than routing them :) Especially when your only router is a dremel and thus takes a zillion passes while on high speed mode (i.e. loud) to remove that much wood.
Now if there was just a way to do saddle slots without a router (and without open slot ends, because that's too breakable for my taste), I'd be able to build 100% electricity free if I so desired.
PostPosted: Mon Mar 04, 2013 8:25 pm
First name: Kent
Last Name: Wilkinson
City: New Carlisle
State: Ohio
Zip/Postal Code: 45344
Started my second build. A Tele shaped lap steel. Just did the rough cut out. Also installed the neck on a uke I am restoring.
PostPosted: Mon Mar 04, 2013 10:38 pm
First name: Sen
Last Name: Goh
Country: Singapore
Brace carving for me - one of the most enjoyable part of the build.
Sen CL Goh
http://senguitar.blogspot.com
PostPosted: Tue Mar 05, 2013 12:39 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Everything is a first for me in this. But I have to agree, brace carving in great fun.
Doug
PostPosted: Tue Mar 05, 2013 6:34 am
While I'm watching paint dry..
PostPosted: Tue Mar 05, 2013 6:45 am
Spent the weekend developing a website, still needs tons of work. Check it out below.
PostPosted: Tue Mar 05, 2013 8:00 am
Set up on my new (to me) 1939 Recording King Carson J. Robison, Model K Jumbo, neck set on my new (to me) Carson J. Robison KG-11, and dis-assembly and X-bracing my new (to me) Carson J. Robison KG-14. All from the Spartanburg, SC guitar show. I've never owned a C.J.R., and I got 3 in one week. Go figure.
James
PostPosted: Tue Mar 05, 2013 1:39 pm
Hi,
I'm working on my #4, inspired by the Gibson J45, with bearclaw sitka and sassafras back and sides.
Tonight I will glue the soundboard on the rim ;)
PostPosted: Tue Mar 05, 2013 3:33 pm
Rout blank with your Veritas, glue shim into slot ends, shape bridge?
(Wouldn't have to round the ends of the saddle either)
