It is currently Wed Jul 23, 2025 11:11 am
 Post subject: Hickory bridge
PostPosted: Sun Feb 24, 2013 11:31 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Building a black walnut guitar for a friend and he wants hickory for his bridge and fretboard. From what I've read it has high damping qualities. Anybody here used it for bridges?
 Post subject: Re: Hickory bridge
PostPosted: Mon Feb 25, 2013 12:33 am
Last Name: Kincheloe
I take it this wasn't meant to be in classfieds...
I've used pecan, which is in the same genus, and would use it again. At least the piece I had made a decent ping when tapped.
Do you have a particular variety of hickory in mind? Shagbark grows all over around here, but I haven't ever had the opportunity to tap test a piece of the wood and see how it compares with pecan.
PostPosted: Mon Feb 25, 2013 10:02 am
First name: Chuck
City: Houston
Darn Dennis. Did this go in the Classified section? I'm on my stupid smart fone and I guess it's smarter than me. Meant to go in building forum.
Anyway, it is shagbark hickory. I'm going to try and we'll see how it turns out.
PostPosted: Mon Feb 25, 2013 11:17 pm
First name: Chuck
City: Houston
Thanks Filippo, I'll give him a buzz
PostPosted: Tue Feb 26, 2013 1:24 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
I think it depends alot on the board. I made a hickory fretboard and I roughed out the bridge. It seems like it should work fine. The tap is really metallic and dense. The board I used had less flex in it than maple i've tested. Its about 18 degrees off quarter. I would say its alot lighter than ebony and about the same as IRW bridges. I hope to string mine up in a couple weeks. I'm using it on the OLF build off #2. The build off is over but I'm still working on it and posting pics on the forum.
Jason Moe
LaCrosse WI 54601
PostPosted: Tue Feb 26, 2013 9:50 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Hutch did you get a piece of pecan bridge from me? Know I gave some to dennis , gud luck with the commission.
