It is currently Thu Aug 21, 2025 11:39 am
PostPosted: Fri Feb 08, 2013 2:51 pm
I think there was a post a few years ago with a link to a site that described how to make a long level from MDF and a few adjustable screws. Can anyone direct me to such a site?
PostPosted: Fri Feb 08, 2013 4:44 pm
Last Name: G
It's possible to use a plumbbob and midpoints on a sheet to make a level. See if you can figure it out from this picture:
http://www.greatplanestrading.com/StP10/DSCN0672.jpg
PostPosted: Fri Feb 08, 2013 4:54 pm
You can use 2 squares one on each table and they should mate over the knives. A jointer has to be well set up to be a useful tool. Your out put will only be as good as the input.
PostPosted: Fri Feb 08, 2013 5:42 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Why would you need a level to set up a jointer?
A long(ish) straightedge and a set of feeler gauges , that's all you need ...
PostPosted: Fri Feb 08, 2013 5:45 pm
First name: Tom
Last Name: West
State: Nova Scotia
I concur with John Hall and two squares...........with the warning your squares have to be accurate. All squares are not equal,just make sure yours are 90 degrees.
Tom
PostPosted: Fri Feb 08, 2013 6:39 pm
Thank you for the correction (and the other ideas, too). I meant "straight edge", "not level".
The article I saw before used something like a six inch by four feet piece of MDF with a trick to put in bolts on the edge and get them lined up exactly. It was a really simple trick, but it slipped my old mind. I think it used two boards as mirrors of each other.
PostPosted: Fri Feb 08, 2013 7:31 pm
Todd, I think that was the method I was referring to. What is the use of the six inch ruler?
Thanks.
Users browsing this forum: Colin North, Kbore, Ken Lewis and 14 guests
