It is currently Wed Apr 29, 2026 2:48 pm
Post new topic Reply to topic  [ 58 posts ]  Go to page 1, 2, 3  Next
PostPosted: Fri Feb 08, 2013 10:54 am
First name: Larry
Last Name: Hawes
I was wondering which placement you preferred and why. I can see that some neck block configurations could make adjustment difficult through the sound hole or even some sound hole placements could be difficult as well. Why do you adjust the truss rod from the location you choose?
Thank You and Best To All
PostPosted: Fri Feb 08, 2013 11:17 am
Last Name: Kincheloe
Headstock, because I think the cover looks cool. May be a bit more prone to cracking the headstock off if you drop the guitar, but I don't worry about it since something is bound to break in that event, and the headstock is not the worst potential place.
Really, both are perfectly fine. Pick your favorite, or change it up every guitar :)
PostPosted: Fri Feb 08, 2013 11:33 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I prefer the sound hole access as the cover on the peg head looks wrong to, and the guitarist will be less inclined to mess with it all the time.
Fred
Fred Tellier
PostPosted: Fri Feb 08, 2013 11:41 am
I'm a sound hole guy.. I don't like having to pull screws to make what I feel should be an annual adjustment.
PostPosted: Fri Feb 08, 2013 11:43 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
Soundhole for a clean headstock, but I have made and engraved some silver truss rod covers for Gibson banjos and mandolins that turned out pretty cool.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Fri Feb 08, 2013 12:01 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
I like easy access and as long as its easy then I'm for it. That makes standard soundhole rods not for me. But if they are extended to the soundhole and can be adjusted by just sticking a wrench through the strings instead of sticking your hand in the hole, I like it.
PostPosted: Fri Feb 08, 2013 12:23 pm
First name: Robbie
Last Name: Fraelich
Head plate. IMHO It is easier to adjust during set up. Truss rod covers also can be done in a nice way that adds to the headstock.
PostPosted: Fri Feb 08, 2013 12:25 pm
I like truss rods at the peghead.
Doesn't really matter much - just my preference.
For a client - I build what THEY want.
PostPosted: Fri Feb 08, 2013 12:48 pm
Sound hole guy here too. Why weaken the head stock more when head stock failures are so common, in drop accidents or especially in shipment? Doesn't make sense to me...
tim...
PostPosted: Fri Feb 08, 2013 12:56 pm
City: Lawrence
Zip/Postal Code: 66047
Several years ago at a “gathering” in Bebe Arkansas a guy named Matt (sorry I forget his last name) brought an arch top with a groove cut length ways into the face of the head before the head plate was glued on. After the head plate was glued on a ball nose allen wrench could be ran through the hole left by the groove from the top of the head to adjust the truss rod.
PostPosted: Fri Feb 08, 2013 1:14 pm
I'm firmly in the same camp as Tim, soundhole for me. I run cf up over the headstock transition to reinforce it, why would I then want to cut a big groove and weaken it again?
I only run the truss rod up to just short of first fret.
PostPosted: Fri Feb 08, 2013 2:21 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
You guys do know you're not supposed to adjust the rod under string tension, right?
PostPosted: Fri Feb 08, 2013 2:29 pm
Looking forward to hearing people's opinion on this one..
PostPosted: Fri Feb 08, 2013 2:30 pm
First name: Zeke
Last Name: McKee
as am I. Hmmmmmm
PostPosted: Fri Feb 08, 2013 2:34 pm
I do both.
I like peghead adjustment.
Most guys seem to like the soundhole adjustment, and a lot of my customers seem to want a clean headplate.
Old growth, shmold growth!
PostPosted: Fri Feb 08, 2013 2:35 pm
as am I. Hmmmmmm
I adjust under tension. How else can you tell what you're doing..?
PostPosted: Fri Feb 08, 2013 2:41 pm
First name: Zeke
Last Name: McKee
[quote="Rodger Knox"]You guys do know you're not supposed to adjust the rod under string tension, right?
as am I. Hmmmmmm
I adjust under tension. How else can you tell what you're doing..?[/quote]
exactly I always do too except for guitars with soundhole adjustment cuz you just can't and it's a major pain. Adjust a bit, tune it up, loosen the strings, try it again??? Doesn't make any sense to me.
PostPosted: Fri Feb 08, 2013 3:01 pm
First name: Rodger
Last Name: Knox
City: Baltimore
I've seen quite a few stripped and broken truss rods, I guess now I know why.
Truss rods are strong enough to hold a neck in place, but many are not strong enough to move it against string tension, particularly single action rods.
I learned that the accepted method is using clamps & blocks to flex the neck into the correct position so there's no stress on the rod while it's being adjusted.
I'd like to hear what the experienced repair guys (you know who you are) say.
PostPosted: Fri Feb 08, 2013 3:10 pm
First name: Zeke
Last Name: McKee
Sounds to me like the truss rods aren't built strong enough
PostPosted: Fri Feb 08, 2013 3:15 pm
[quote="Rodger Knox"]I've seen quite a few stripped and broken truss rods, I guess now I know why.
I'd like to hear what the experienced repair guys (you know who you are) say.[/
I've never had a truss rod break or strip. It doesn't take much force to adjust my necks. If it does, something is wrong..
PostPosted: Fri Feb 08, 2013 4:40 pm
Agreed! I use the Blanchard truss rod that Allied sells. By its design, very little torque is needed to turn it, but more turning is required. Sort of like a compound low on a 4WD. There's very little torque stress on the rod, which is a major factor in breakage, with most of the stress in tension. Not affiliated, just a user.
BTW, I'm a soundhole guy. Too many people out there think you can set the action with the truss rod. With a properly placed hole in the upper transverse brace, access is easy. Haven't had any complaints (knock on wood).
PostPosted: Fri Feb 08, 2013 4:43 pm
Last Name: Eaton
City: Lamoine
State: ME
Zip/Postal Code: 04605
In theory it should be the same idea as adjusting a block plane blade, especially the type with a lever cap screw to tighten down the blade. You should ALWAYS release the tension off the lever cap before adjusting the depth of cut. If not then you end up putting far too much pressure on the threads of the adjustment screw.
So a truss rod should be based on the same theory. Zeke stating the strength of the rod should be greater if they are stripping out doesn't really make sense when you think about the point of weakness. The rod itself is not the issue, it is the threads where all the strain is being applied. One can only make the threads so strong. Doing this under tension will work fine for quite some time in most cases but there is always a chance that the rod has a weak thread initially and will strip out very soon. Either way I agree that this is poor practice, even if it's a pain to get right without stings on. I am not speaking in experience with guitar making but am experienced in planes adjustment screw being stripped and understand why.
PostPosted: Fri Feb 08, 2013 4:51 pm
First name: Zeke
Last Name: McKee
There are alternatives to making stronger threads such as stronger materials, tighter thread tolerances, different types of threads.
I've never had one strip out so I see no weakness in any of mine. I personally believe stripped truss rods are caused by user error, BUT if you notice a significant number of broken and stripped rods it seems like this could be a result of defective rods. If this is the case you should consider the rods as the problem. I personally believe they should be able to withstand tightening with the strings tuned to pitch. I they can't then it's defective IMO.
Users browsing this forum: Colin North, doncaparker and 340 guests
