It is currently Sun Aug 17, 2025 8:54 am
 Post subject: Go Bar Rods
PostPosted: Wed Feb 06, 2013 1:36 am
First name: Rienk
Last Name: Ayers
City: Santa Maria
I am going to be making a Go-Bar deck, but I intend to make the spacing at least 36", and the top will be cantilevered so that three sides are completely open (so that I don't have posts in the way or have to duck down below the top).
So, I would like to know what size diameter of fiberglass rods I should buy.
Anyone using long fiberglass rods like this?
If not, what are the typical diameters of 24" rods?
I assume I'll need to bump up the diameter of the 36" to keep a similar down force.
Thanks!
 Post subject: Re: Go Bar Rods
PostPosted: Wed Feb 06, 2013 6:57 am
First name: Trevor
Last Name: Gore
City: Sydney
I use 9.5mm hardwood dowelling on a 1200mm high deck.
If you're lucky, Todd will be along soon with a link to the page he wrote on how to calculate it all out. Or just search on go-bars. It should come up pretty soon.
http://www.goreguitars.com.au
PostPosted: Wed Feb 06, 2013 7:16 am
Last Name: Jeffries
City: Williamstown
State: NJ
Zip/Postal Code: 08094
I used 1/8" fiberglass rods, bought from a kite supply place in PA. They were less than a dollar for 48" lengths, and they even cut them in half for me for free. 20 rods for less than $10, can't beat it! For the ends, I just used those little plastic white caps for closet shelving(but had to wrap some electrical tape around the ends just so the caps would have a snug fit).
PostPosted: Wed Feb 06, 2013 8:26 am
Mine are 3/16".. I've wanted to build a robust shelf above my bench that could be used as the top half of a large, multi station go-bar deck.
PostPosted: Wed Feb 06, 2013 11:36 am
First name: Rienk
Last Name: Ayers
City: Santa Maria
Thanks guys.
I'm mostly going to use vacuum presses, but I want a Go Bar deck as a backup.
The formula is handy; I was going to ask our engineer - but he wasn't at work when I was curious (love forums).
I checked out 'Into the Wind' but they are expensive. For less money, you can buy a set of 24" from BCG, and support a luthier.
Our company gets it's own custom pultrusions made, so I was going to call our vendor in Ohio to see what they had off the shelf.
But then I checked McMaster, and they sell 10' lengths of 1/4" rods for $4.89 - what a deal.
I think I will adjust my Go Bar height to be a little less than 3' tall... that way I can cut the long shaft into three pieces of 40", and have a set of 30 rods for $48.90. (you could also make a set of 30" rods using their 5' pieces; 30 would cost $40.35 - for a few bucks more, I'd rather have the longer ones).
Get a package of 100 rod tips for under $4, and you're styling.
1/4" Rod . . . . . 8543K59 . . $2.69 . . . 8543K21 . . $4.89
Rod Tips (100) . 9753K12 . . $3.52
PostPosted: Wed Feb 06, 2013 11:52 am
First name: Rienk
Last Name: Ayers
City: Santa Maria
I don't know if I'll do this, but here is an idea you could try out to make a custom Go Bar workbench.
- Buy one of the cheap Harbor Freight work benches (with coupon, you can get it for $140).
- Buy a sheet of 60"x60" half inch baltic birch plywood.
- Stiffen the back side of the workbench with a 24" piece of the plywood (shear wall).
- Add a couple of 3/4" holes in the middle of the back side, parallel with a couple of existing dog holes.
- Make a 24"x60" plywood box, with 3" side walls (to stiffen and hold tools)
- Thread some 3/3" OD metal pipe into the workbench, and also to the shelf (approximately 34" off table top)
Now you have a custom workbench that can have two gobar decks, plus a small end vice - all for under $200.
http://www.harborfreight.com/workbench- ... 69054.html
PostPosted: Wed Feb 06, 2013 11:54 am
1/4" fiberglass is really stiff. I have a few of them where I need extra force. But most of mine are 3/16" which is still plenty strong.
PostPosted: Wed Feb 06, 2013 11:57 am
First name: Rienk
Last Name: Ayers
City: Santa Maria
How long are yours?
PostPosted: Wed Feb 06, 2013 12:39 pm
I've got 50 @ 24"
My deck is 2 thicknesses of 3/4" C-2 maple-ply top and bottom, glued up on my tablesaw deck (flat). I've got 31" between them. I used 36" lengths of 3/8" all-thread with 1/2 EMT and 3/8" washers as the spacers. I also added some white rubber feet to the ends of the all-thread to protect my bench top. I build on a 1-1/2" thick work board that I can adjust up and down using 14" 2x4 blocks between the deck and the work board (they live on top of the deck when not in use). With this setup I can have a flat surface, or I can add a radius dish, I can glue up braces, or glue on a back. It's adjusable.. To maximize clamping preasure, I like to keep my go-bars as straight/un-bent as possible.
Michael
PostPosted: Wed Feb 06, 2013 12:40 pm
Most of mine are 36" but I also have a set cut about 32" long for attaching plates to rims.
PostPosted: Wed Feb 06, 2013 1:25 pm
Todd Stock wrote:
the buckling force for the slender rod is proportional to R^4/L^2 . . .
Todd, do you just pull this stuff from rote memory? I'm always amazed at the intricate stuff you post at will. Tools specs, forumulas, etc.
Filippo Morelli wrote:
Order from Into The Wind.
I'm with Filippo. I ordered a few dozen 3/16 fiberglass rods and rubber tips from Into the Wind five or six years ago. They're perfect.
PostPosted: Wed Feb 06, 2013 3:01 pm
First name: Rienk
Last Name: Ayers
City: Santa Maria
Todd Stock wrote:
I just tattoo the useful stuff in out of the way locations...
Goodwin has 1/4" x 48" at $1.29 per rod in 48 pack...3/16" x 72" would run about $2 per in lots of 48...so pricing is not at all bad.
I THOUGHT I recognized your picture - from that movie 'Memento'...
Good tip on source for rods. How do I find "Goodwin"? [Edit - I think it was supposed to be GoodWinds.com]
What length of rods and height of Go Bar setup do others use?
