It is currently Mon Sep 15, 2025 9:37 am
PostPosted: Wed Jan 30, 2013 9:56 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
Not to use plywood for neck blocks??????? I use it for the tail block...works great , won't split???? I see some builders laminate pieces of hardwood ...just wondering .... :?: :?:
MK5acoustics.com
PostPosted: Wed Jan 30, 2013 10:03 pm
Martin has been using it for some time.
PostPosted: Wed Jan 30, 2013 10:08 pm
City: chicagoland
State: illinois
plywood has dampening/vibration absorbing properties....i wouldn't want it anywhere near an acoustic instrument, even an area such as a neck block. laminated hardwood, or even laminated softwood, would be far superior to plywood....a large percentage of plywood composition is adhesive, and the rest, about the crappiest wood there is
PostPosted: Thu Jan 31, 2013 4:13 am
Plywood has weak and strong layers, and glue voids, unless you find extremely high quality plywood.
Old growth, shmold growth!
PostPosted: Thu Jan 31, 2013 6:16 am
First name: Tom
Last Name: West
State: Nova Scotia
I think the plywood that Martin uses is high quality. Not your Daddys or Grandaddys ply by any means.
Tom
PostPosted: Thu Jan 31, 2013 6:24 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Tom
I have no experience with using plywood in guitars but with 20 years of furniture building experience in can say the difference between high quality (and expensive) Baltic birch ply and standard birch ply, for example, would be to draw comparison between Canadian and American hockey players. :). Ever notice that great jigs are often built out of Baltic ply over solid wood for stability? Tone conduction, however, is a different matter I presume.
Doug
PostPosted: Thu Jan 31, 2013 6:47 am
First name: Chuck
Last Name: Hutchison
City: Houston
You need old growth plywood.
PostPosted: Thu Jan 31, 2013 1:06 pm
I've been using it for end blocks on my last three, and something happened with the third that got me worried.
The end of the lining that was close the the block had a small piece that cracked while routing the binding channel. While trying to remove it with my pellet knife (actually just push it so it would break and fall inside the box), the knife accidentaly found it's way between the back and the end block, and unglued a portion of the top from the end block. I was quite surprised the glue joint was not better than this. I gently slipped that knife again and the entire glue joint failed! No heat, and almost no pressure.
So I'm currently runing some tests (Titebond with baltic birch playwood). So far, plywood glue joint seem to be considerably weaker than solid wood glue joint. I'm pretty sure it's because of the end grain portion of the glue joint (not surprisingly). I'm trying to repeat to process to see if my results are consistent.
All this to say, with the amount of pressure the strings put on the neck block/top glue joint, I'd be afraid plywood would creep far more easily, thus pushing the entire neck forward.
Alain Moisan
(Now building just for fun!)
PostPosted: Thu Jan 31, 2013 1:26 pm
.... laughing6-hehe
Don't forget quarter sawn, no runout.
Users browsing this forum: No registered users and 61 guests
