It is currently Tue Sep 16, 2025 11:43 am
PostPosted: Thu Jan 31, 2013 12:07 am
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Zip/Postal Code: 29302
Egg white pore filler under water based finish. Just curious what would be the results? I plan to put 2 spit coats of shellac after the pore filling and use the new polyWrey finish. Any suggestions or warnings?
Richard
PostPosted: Thu Jan 31, 2013 4:28 am
Go for it
I'm doing the exact same thing right now.
Egg white pore fill on Ziricote B&S - only two coats needed. I also use the whites to raise the grain on the top then sand back.
Two spit coats of shellac and spray EM6000.
No warnings, easy as [:Y:]
Mat
PostPosted: Thu Jan 31, 2013 6:50 am
First name: Chuck
Last Name: Hutchison
City: Houston
Sacconi say Tony Stradavari used vernice bianca. Wonder if it would work on a guitar.
PostPosted: Thu Jan 31, 2013 8:02 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
please could you explain the proccess of using egg whites?
We are all in the gutter but some of us are looking at guitars.
PostPosted: Thu Jan 31, 2013 9:08 am
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
i haven't finished the process yet. But the basic procedure is: 1: separate the egg white 2: dip 240 wet dry sandpaper into the egg white. I used a small 2x3 soft sanding block 3: sand in a swirling motion until yo build up a nice slurry on the back. 4:Take an old credit card or small squeegee and fill the pores at a 45 degree angle. IF you do a search there is a lot of info on pore filling with egg whiite.
Richard
PostPosted: Thu Jan 31, 2013 11:59 am
That's pretty much the way I do it. I don't use a credit card but it's just another way of doing it. Sand the egg whites in circular polishing motion and work in small areas like 3x3in at a time or so. The idea is to create a sawdust slurry and pack it into the pores. The egg whites dry hard and clear and act as a binder for the dust and fill in the pores.
I think you can make mayonnaise with the yokes or something.
PostPosted: Thu Jan 31, 2013 12:22 pm
Not really for filling Pores. Violin wood does not usually have the kind of open pores found on many Guitar woods.
Anyway, the Vernice Bianca was just a theory based on someone finding protein matter under the varnish layer. Doesn't really prove the Vernice Bianca theory at all.
PostPosted: Thu Jan 31, 2013 10:17 pm
First name: Chuck
City: Houston
Yeap, no one knows what Strad used, but that's a different thread.
About the egg whites, do you just slop on the runny whites or beat them a minute to get it lathered up? I might have to give this a try.
Cheers,
Hutch
PostPosted: Thu Jan 31, 2013 10:23 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Can you tint egg whites for a contrasting pore fill? Sorry about the hijack. :oops:
Alex
PostPosted: Fri Feb 01, 2013 11:14 am
Beating egg whites will stiffen them and that is not what you want. I've read all sorts of ways to do it but what works for me is just dip the sand paper in the egg whites and polish out the guitar till it stiffens. Then move to another section. When dry just sand or scrape flush and reapply as necessary (or as was mentioned above you can use the squeegee technique if you like, less sanding perhaps). It's that easy.
PostPosted: Fri Feb 01, 2013 11:35 am
First name: George
City: Seattle
Some people whisk the whites into a foam, let the mixture sit in the fridge for a couple hours, then scoop off the foam and use the remaining liquid (called "glare") to create the slurry. I've done it this way and straight from the shell and didn't really notice a difference.
I've never tried tinting or adding anything to the egg whites, but here's something I ran across a while back:
http://www.classicalguitardelcamp.com/v ... f8c0cad016
George :-)
PostPosted: Fri Feb 01, 2013 12:31 pm
That is correct, but the name is glair. Glare is what you have when the sun is in your eyes.
PostPosted: Fri Feb 01, 2013 1:02 pm
First name: George
City: Seattle
I never know which way to go with that word. :-) Some say either way is acceptable, while others say no. Oh well, as I age I'm starting to forget everything anyway, so it won't be a problem much longer!
George :-)
PostPosted: Sat Feb 02, 2013 6:02 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
You don't need to seal the wood after pore filling with eggwhites as the whites act as an adequate sealer. Here's a rosewood guitar I made that is pore filled with egg whites and finished in KTM-9
PostPosted: Sat Feb 02, 2013 9:28 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
Alex
No, the egg whites act as a binder: the dust from sanding is the filler.
Users browsing this forum: Kbore, roby and 10 guests
