It is currently Sun Sep 14, 2025 8:21 pm
PostPosted: Fri Jan 04, 2013 2:24 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
I need to press in some tuner bushings in my headstock for these cute but expensive tuners:
http://www.stewmac.com/shop/Tuners/Guit ... uitar.html
I really don't want to spend the money to buy the StewMac tool for doing this as I don't think I'll be doing it very often.
Is there an "at home" method for doing this including duct tape and chewing gum?
I'm thinking a C-clamp and some backing support should do the trick - but I've never done this before - so I'm seeking your input.
P A U L B U R N E R
Burner Guitars
PostPosted: Fri Jan 04, 2013 2:28 pm
I now have the stew mac rig, but before I had it, I used a backer of some cork or similar, and then pressed them in using the drill press with a large round of metal or wood in it ...
PostPosted: Fri Jan 04, 2013 2:29 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I'll be watching for the correct answer since I have just been pressing them in with a deep welled socket of appropriate size. . .
Bryan Bear PMoMC
PostPosted: Fri Jan 04, 2013 2:32 pm
State: Tennessee
As long as the hole is reamed to the proper size just about anything will press them in.
PostPosted: Fri Jan 04, 2013 2:33 pm
Last Name: Burner
City: Lincoln
State: Nebraska
I do have a fret press - would that be something to consider using?
P A U L B U R N E R
Burner Guitars
PostPosted: Fri Jan 04, 2013 2:42 pm
I made a press that looks like a violin edge clamp. It has two wood cylinders that are movably disposed on a threaded bolt. One of the cylinders is moved toward the other with a wingnut. The faces of the cylinders are provided with leather. The bolt must be small in diameter so as to fit in the hole that receives the bushing without interfering with the bushing as it is pressed in. I will try to put up a pic tonight or so.
PostPosted: Fri Jan 04, 2013 2:58 pm
First name: Ron
Last Name: Belanger
I do the same as Steve
PostPosted: Fri Jan 04, 2013 3:17 pm
Take a 1" x 1" x 3/4" piece of hardwood or plywood and glue a 1" x 1" piece of cork to it. Drill a !/4" hole through the center as to make a "wooden washer". Get a 1/4" x 2" carriage bolt and insert through wooden washer. Put the washer and bolt through the headstock from the back. Put the bushing over the bolt followed by a nylon washer and wing nut and tighten to press in.
Chuck
PostPosted: Fri Jan 04, 2013 3:22 pm
I use UHMW nylon and a c clamp or my drill press and the Nylon bushing.
PostPosted: Fri Jan 04, 2013 3:30 pm
Why don't you make a spool clamp -- that should work well.
By the way, you guys have been putting out some especially nice looking instruments -- keep up the awesome work!!!
Simon
PostPosted: Fri Jan 04, 2013 3:35 pm
+1 to that,
it is not about forcing anything in,
it is about fitting counterparts.
PostPosted: Fri Jan 04, 2013 3:49 pm
City: chicagoland
State: illinois
no need for fancy press setups; you can tap them in with a makeshift wood or nylon mallet
PostPosted: Fri Jan 04, 2013 4:00 pm
Hi, here is my home made clamp:
It works like a charm 8-)
PostPosted: Fri Jan 04, 2013 4:22 pm
I've used this for at least 6 years. It's worked great for me.
http://kennedyguitars.com/_Kennedy_Guit ... press.html
PostPosted: Sat Jan 05, 2013 4:39 pm
Last Name: Burner
City: Lincoln
State: Nebraska
[taken from an email I just sent to a friend, entitled "No-Swear 2013!"]
I have realized that it is just a fact of life that every time I do something NEW on a guitar build it will probably be a learning experience where I learn how to NEVER do something again. [uncle] [uncle]
If I take this new expectation as a matter of fact - then I will probably have much lower blood pressure - and swear a lot less.
Today's experience was with pressing in tuner bushings. I've not used press-in bushings before - have always used Gotoh tuners up to now.
So - todays' lesson is that you need to make sure the bushing clears the finish before biting into to the wood. If you don't ream the hole JUST enough - then you will exert excessive pressure on the finish to the point where it will stress crack or lift or bubble under the pressure. Today I got to see two of those happen.
oops_sign
I guess the good news is that 4 of the tuners went in just fine. laughing6-hehe laughing6-hehe laughing6-hehe
So.... learn from my mistakes. Keep a notebook. REAM those dang holes a little bigger!
(Thank God I've got Joe White on my side to fix these mess-ups!)
P A U L B U R N E R
Burner Guitars
PostPosted: Sat Jan 05, 2013 5:01 pm
State: Tennessee
About 75% I hit a home run the other 25%............oh well.
PostPosted: Sat Jan 05, 2013 5:14 pm
Last Name: Burner
City: Lincoln
State: Nebraska
I hit 66% today as 4 of the bushings went in fine....
HA
P A U L B U R N E R
Burner Guitars
PostPosted: Sat Jan 05, 2013 5:16 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Joe will do it up like new, these kind of problems are why I am glad I do my own finishing. No matter how much we try to avoid messing up, something can go wrong. My goal is to only make each mistake once and so far it has worked out that way.
Fred
Fred Tellier
PostPosted: Sat Jan 05, 2013 6:13 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
I chucked up a piece of 1/4" all thread in my drill press and put a nut and washer on it.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Sat Jan 05, 2013 6:53 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Wish this forum had a "Like" button.
PostPosted: Sat Jan 05, 2013 6:59 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Fred Tellier has it right. It doesn't have to be complicated. Your thumb will do it just fine. But if you are after a mechanical means to seat the bushing, then I highly recommend the wing nut method, as has been described and illustrated by others already. DO pad your wing nut with a washer or use a cork-lined spool clamp to avoid marring your bushings. Note: The truly important part of this is to have your bushing holes reamed out just right. And that can be determined by trial and error with a piece of scrap that is drilled out to the same diameter as the holes in your head stock, and then marking your reamer with a bit of masking tape.
PostPosted: Mon Jan 07, 2013 1:39 pm
My fret press arbor works great for seating bushings. I place a bolt in the arbor shaft that has a leather pad glued on the head. Fast and allows a lot of control.
PostPosted: Mon Jan 07, 2013 8:11 pm
Overkill, perhaps, but easy to make and nice to use. SBC
PostPosted: Tue Jan 08, 2013 6:40 am
Todd Stock wrote:
I have the SM tool as well, and it's great for pulling bushings, but really not needed for seating them.
Furthermore, I had one slip and dent a headstock finish while installing bushings. Never again. Definitely pays for itself for removing bushings, though!
Wes McMillian
Santo, TX
http://www.wesmcmillian.com
PostPosted: Tue Jan 08, 2013 12:03 pm
With me and nitro it seems that little lifts when prepping the bushing holes are pretty common. Here's yet another way to apply butyl c to the edge and affords good control.
Get a small syringe with a 25G or preferably smaller needle. Raise a small bead on the bevel and touch it to the edge of the lift.
Users browsing this forum: dofthesea, James Orr and 72 guests
