It is currently Thu Aug 07, 2025 7:16 am
PostPosted: Tue Dec 18, 2012 10:34 pm
First name: Jonas
Last Name: Baker
City: North Haven
State: CT
Zip/Postal Code: 06473
I'm trying to get a soprano uke done before Christmas. I don't have any fretwire for a uke, and I'm hoping to find some thin and also softer wire. I was thinking either brass or nickle fretwire that is softer than the usual 18% would be better for the nylon strung uke. As far as size I don't have an exact preference, but I figure it should be a thinner than the .080" width that is the thinnest I have.
Does anyone know where to find fretwire suitable for a soprano ukulele, or does anyone have any they could sell me? All I really need is enough for one soprano ukulele and I'm hoping to find this ASAP.
Thanks everyone, and happy holidays.
Jonas baker
PostPosted: Tue Dec 18, 2012 10:48 pm
First name: Big
Last Name: Jim
what about Mandolin fret wire ? idunno
PostPosted: Tue Dec 18, 2012 11:21 pm
First name: Raymond
Last Name: Pipkin
On the four I've made, I've used the thin .053 mando wire from stewmac.com http://www.stewmac.com/shop/Fretting_supplies/Stewart-MacDonald_Fretwire/Narrow_Fretwire.html It seems to work ok. They ship pretty quick.
PostPosted: Tue Dec 18, 2012 11:24 pm
Last Name: Kincheloe
That's what I use as well.
PostPosted: Wed Dec 19, 2012 7:06 am
custom pearl inlay has the fretwire
PostPosted: Wed Dec 19, 2012 8:13 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I use uber thin mando frets
PostPosted: Wed Dec 19, 2012 9:11 am
First name: micah
Last Name: medlong
City: parma
State: ohio
Zip/Postal Code: 44129
Lmi has wire. But I'm learning that it's really soft. I tried using a tang nipper on it and it just kinks the wire.
PostPosted: Wed Dec 19, 2012 2:27 pm
First name: Jonas
Last Name: Baker
City: North Haven
State: CT
Thank you all for the tips, I'll check out those sources.
Micahmed, you mention the LMI wire is very soft, I was actually looking for softer wire because I figured with the nylon strings the softer wire would be a benefit, and I believe a lot of classical guitar builders use softer fret wire for this reason. Maybe it doesn't matter at all? I never thought about the softer wire being harder to snip with the tang nipper...
Jonas
PostPosted: Wed Dec 19, 2012 3:45 pm
City: chicagoland
State: illinois
....sounds like you destroyed your nipper on SS wire or something.... maybe the wife borrow them to cut mosaic tile?
PostPosted: Wed Dec 19, 2012 4:07 pm
I have used, and most newer ukes use med. I made 1 concert with SM small. It was ok. More classy looking. Very diff feel from med if yer not used to it. Also, tang niper did'nt like it. Not sure why you would want softer.
PostPosted: Wed Dec 19, 2012 5:53 pm
You need a tang nipper with a smaller notch in it for that tiny wire. Otherwise it tips crooked before you ever get a bite, and crimps it while cutting.
You can trim the tang with flush cut nippers rather than the special tang nipper tool, but those tend to leave a larger burr that takes more filing to smooth out.
PostPosted: Wed Dec 19, 2012 7:26 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I don't get the need for soft wire for nylon strings. I can see how you can get away with softer wire, but not why you would seek it out.
Bryan Bear PMoMC
PostPosted: Sun Dec 23, 2012 7:29 pm
Softer wire would not be a plus. I learned on a friend's cheap guitar that had brass frets. Even with nylon strings the frets had grooves worn in them relatively quickly. The 18% nickel wire is still pretty soft compared to stainless steel, but is fine for nylon strings. Mandolin wire is just ukulele wire by a different name [:Y:]
Users browsing this forum: TRein and 41 guests
