It is currently Tue Aug 12, 2025 6:37 pm
 Post subject: Re topping
PostPosted: Mon Nov 12, 2012 8:05 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
This is my first try, looking for advice. I would assume rout off top.binding then rout off top?
MK5acoustics.com
 Post subject: Re: Re topping
PostPosted: Mon Nov 12, 2012 8:19 am
First name: David
Last Name: LaPlante
Here is a much more elegant way of doing it:
http://www.guitar-repair.com/article_apr_09_retop.htm
PostPosted: Mon Nov 12, 2012 8:57 am
I've only done this repair a hand full of times but the method I used which I borrowed from some one else who I cannot give credit for since I can't remember who, is to rout the top off and leave the bindings in place. So basically:
1) join the new soundboard and thickness it
2) remove the fingerboard and bridge
3) trace the guitar pattern on the new top
4) rout the top off just inside the bindings
5) salvage the rosette and inlay to te new top
6) cut the new soundboard inside the traced lines to the thickness of the bindings
7) brace the top to the same pattern
8) now the top should just drop in place, glue it in
9) There will be a gap between the binding and the top freshen it up with a router
10) fill the gaps with purfling wood strips or mastic.
11) re-glue fingerboard and bridge.
Done
It works really well and you don't have to deal with trying to salvage bindings. The only trade off is that you will have a purfeled line which was not part of the original design but if you need a re-top then who cares.
PostPosted: Mon Nov 12, 2012 8:58 am
Oh I see the above link now. YEah that'll work. duh
PostPosted: Mon Nov 12, 2012 9:17 am
Last Name: coloccia
Country: States
Assuming the original binding channel was cut well, that is a SLICK way of doing it.
PostPosted: Mon Nov 12, 2012 9:35 am
First name: Tom
Last Name: West
State: Nova Scotia
John Greven does an excellent write-up on his web site under Workshop.
Tom
Users browsing this forum: meddlingfool and 22 guests
