It is currently Sat Jul 26, 2025 4:04 am
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Oct 30, 2012 6:56 am
bluescreek wrote:
yes
you cannot trim binding with a flush trim bit
Yes, you can. As I mentioned, I did it more than 70 times without any binding pulling off, nore any other issue.
Alain Moisan
(Now building just for fun!)
PostPosted: Tue Oct 30, 2012 8:16 am
wood maybe
Plastic I wouldn't recommend it.
PostPosted: Tue Oct 30, 2012 9:02 am
bluescreek wrote:
wood maybe
Good point. I only did it with wooden bindings.
Alain Moisan
PostPosted: Tue Oct 30, 2012 10:08 am
Plastic? Eww.....
Kidding.
I only use wood. I don't see how it could be a safety issue. I use a ribbecke style jig with a carriage, wear hearing protection, eye protection, respirator etc..,
Time will tell...
PostPosted: Tue Oct 30, 2012 12:20 pm
Plastic will not cut as nice as wood with the router. When I did this with a plastic binding it destroyed the binding and actually pulled the binding off the guitar. The plastic binding shattered . I think the plastic being softer can get pulled by the bit .
PostPosted: Tue Oct 30, 2012 9:33 pm
This is true, I have witnessed this myself. It is a bad idea to try to flush trim plastic binding. I use a rolling pin sander, scraper and hand sanding. It takes precious time but I see no alternative.
Ken
PostPosted: Sat Nov 03, 2012 6:25 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I finally got to try that whitesides bit I posted a picture of (earlier). I used climb cut to trim top and back with through cuts. ZERO tearout, zero issues, and it was very smooth. I LOVE this bit. Note: I am not recommending it for binding trimming. Never used it for that.
PostPosted: Sun Nov 04, 2012 1:45 am
nkforster wrote:
I used a bearing guided roundover bit
Nigel, Was that a 1/8 or 1/16?
PostPosted: Sun Nov 04, 2012 3:43 am
City: chicagoland
State: illinois
regarding plastic binding and a router:
....i have no experience with this, but i do use weed whips every summer, so i could imagine...
:P :lol:
PostPosted: Sun Nov 04, 2012 5:07 am
First name: nigel
Last Name: forster
City: Newcastle upon tyne
Zip/Postal Code: ne12at
Country: england
If you mean the shank - 1/4", as for the size of the roundover - don't know I'm afraid! It was the bit from one those cheap "selection boxes" that came with a router. I don't recall the size, it wasn't such a small bit, but then these was on an archtop, so the plates were pretty think compared with a flat top. I set it up in the router in my LMI binding jig, tested the size of cut on scrap and routed away. You could use whatever your taste dictates and your top/ribs/linings could cope with. If you draw it out full size you'll see how big a roundover can work. A big roundover would certainly be unconventional but can look really nice.
nigel
http://www.nkforsterguitars.com/#/book/4568936095
nigel
http://www.theluthierblog.com
PostPosted: Sun Nov 04, 2012 10:06 am
Thanks. I guess a 1/16 would give you the full radius but larger would have more of a bevel look and you could sand the corners. I sort of did this with just sand paper around the rib and armrest areas and really liked the comfort factor.
PostPosted: Sun Nov 04, 2012 12:10 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Hey, why don't you do a test with a 12" long board,
with the binding glued into a ledge,
and give it a whirl.
PostPosted: Mon Dec 17, 2012 3:44 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Am I the only one using a Stewmac/MacRostie binding trimmer? With this tool, I trim my binding to match the binding channel plus a few thou for scraping flush after gluing. The usual binding bit bearing limited size selection also becomes a non issue. I thoroughly recommend the tool.
Dave F.
Cambrian Guitars
PostPosted: Mon Dec 17, 2012 4:46 pm
First name: Ron
Last Name: Belanger
+1 Stewmac/MacRostie binding trimmer? [:Y:] [:Y:]
