It is currently Sat Jul 26, 2025 11:29 am
Post new topic Reply to topic  [ 181 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 8  Next
PostPosted: Fri Oct 19, 2012 5:29 pm
First name: Stuart
Last Name: Gort
Phillip Patton wrote:
I've done literally nothing guitar related for 3 or 4 weeks, but I did finish this (sword) recently.
This a luthier site, pal.
Next time.....make an axe.
StuMusic
PostPosted: Fri Oct 19, 2012 5:40 pm
First name: D
Last Name: S
laughing6-hehe
It is a cool sword though.
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Oct 19, 2012 5:43 pm
First name: D
Last Name: S
lex_luthier wrote:
Say what you will, making a telecaster every once in a while makes me smile.
Fenders can be nice if you use the proper materials and techiques.
Awesome build!
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Oct 19, 2012 5:53 pm
laughing6-hehe Well played. [:Y:]
PostPosted: Fri Oct 19, 2012 9:40 pm
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
Clinchriver wrote:
Nice blade, what pattern and how many layers is that damascus?
Spraying #2 with Mohawk Piano Lacquer. #1 was twenty five years ago.
Thanks!
The core is made up of three bars, with 11 layers each, with the twisted sections alternating clockwise and counter-clockwise.
The edge wrap is random pattern, about 400 layers, if I remember correctly.
Haha, very good.
Ok, here's a few axes that are in process:
An 8 string electric baritone ukulele with curly maple over mahogany:
An electric tenor uke with claro walnut over hog:
And a small body classical. Osage orange and Lutz:
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Fri Oct 19, 2012 11:27 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Hey Phillip,
Doesn't look like you're letting any grass grow under your feet! The sword is incredible!
This is a very talented group of people (and goats too, Tony).
PostPosted: Sat Oct 20, 2012 7:50 am
First name: Jim
Last Name: Kirby
Alex, the flamenco looks great!
Progress slow here as usual but a few things are coming to a head. Pics are in progress shots of #7, which is presently getting nut and saddle refined and then final cleanup hopefully by tomorrow - it goes to new owner on Thursday. I'll have pics of the finished guitar by then. This one is straight off the Romanillos GAL plan. Lutz spruce, Palo Escrito B&S, Cedro neck.
I really liked working with the Palo Escrito. It looks great under french polish right away. On the other hand, I think this is the first time I tried to use Zpoxy as a pore filler on the neck - never again, unless I find the right modification to the process. The end grain of the heel soaks up the epoxy like crazy, and the concept of sanding back to bare wood was pretty futile. Now I have blotchiness on the heel. Perhaps a seal coat?
Next up will actually be #9, which is a Barbero style flamenco. This is bound in cypress - I really want to see what the light-on-light binding looks like. This one now has it's frets, and the bridge is getting finished - someday. My woodworking isn't really up to all the light wood to light wood butt joints and stuff here.
Finally, #8 will be a Romanillos-style again, with Lutz and EIR. This one is waiting for bindings, and has a customer.
Jim Kirby
kirby@udel.edu
PostPosted: Sat Oct 20, 2012 8:20 am
Last Name: Kincheloe
Try clogging the end grain with a couple coats of thin hide glue. It doesn't seem to soak in too deep and therefore doesn't darken much, and prevents other finishes from getting in either. My current one has a Port Orford cedar neck, and the heel end grain darkened a lot with shellac applied directly. Sanded back and tried the hide glue trick, and it hardly darkened at all :)
But I wouldn't want to try sanding back when the guitar is already assembled. I carve my heels before gluing to the soundboard, and seal all near-final surfaces with shellac to keep them clean, so mine was relatively easy to retry.
The palo escrito looks great [:Y:] I'll have to give it a try sometime. How does the density and tap tone compare with other rosewoods?
PostPosted: Sat Oct 20, 2012 8:30 am
Country: Romania
Looking great Jim, although next time I'd use maple rather than cypress, that stuff tends to be way too soft for a binding...
Today i am patching together a 5 piece, totally asymmetric, buttery Carpathian top for myself, pieces I split from a very old reclaimed construction beam. I give it a 9.5/10 for stiffness to weight and a 10 for taptone, and it also has the strongest resinous smell I ever encountered in spruce. It beats cedar and almost comes close to cypress. It's wonderful to plane this stuff, and fingers gets sticky after removing the piles of shavings from the bench. Really really excited about this one :D
Build log
Last edited by Alexandru Marian on Sat Oct 20, 2012 8:53 am, edited 1 time in total.
PostPosted: Sat Oct 20, 2012 8:52 am
Been spraying varnish on the ukulele. Just one or two more coats to go.
Time to make a bridge!
PostPosted: Sat Oct 20, 2012 9:10 am
First name: D
Last Name: S
Love it!
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Oct 20, 2012 12:16 pm
That varnish looks really good. I'm re-finishing a old bandura using P&L #38 but I'm trying to wipe it on and after seeing your results, I may just have to level it and spray a few coats.
PostPosted: Sat Oct 20, 2012 1:13 pm
First name: Jim
Last Name: Kirby
Thanks for the tip. I'll give it a try (on scrap first :D ) I've been shellacking and pumicing the heels up to this point, and the darkening is not nearly as bad as with the epoxy.
The Palo Escrito is less dense than Indian by a little. (Sorry, I didn't measure directly - something I've only started doing very recently). I'd say it's a little harder to bend, but not much. It taps similar to Indian (at least mine does) - not a really bright tap, and it's not a glassy sounding wood when you rub two pieces together. I'd say that, for someone happy with the properties of Indian, its more or less a drop in (and much more fun to look at.) I have 2 more sets (all from LMI - I don't think I've seen it anywhere else), all look more or less the same.
Jim Kirby
kirby@udel.edu
PostPosted: Sat Oct 20, 2012 3:33 pm
First name: Jim
Last Name: Kirby
Pictures sooner than I expected.
I wasn't anticipating the 1.3 mm difference in action between the high and low E that the customer requested (translating to a 2.6mm difference at the saddle.) I would have taken a mm off the fretboard on the bass side if I had known. The saddle looks really weird to me.
Jim Kirby
kirby@udel.edu
PostPosted: Sat Oct 20, 2012 4:36 pm
First name: jack
lots of nice looking instruments..
I'm working on my first sunburst matte finish... somewhat less elbow grease, but I'm not sure if I like it yet... (the matte that is), though it is growing on me......
PostPosted: Sat Oct 20, 2012 5:05 pm
Oh yea, knocked out a bridge the other day. This is a prototype in maple just to see...
PostPosted: Sat Oct 20, 2012 5:27 pm
Nice. Isn't that fun Andy?
PostPosted: Sat Oct 20, 2012 7:54 pm
First name: D
Last Name: S
I like the matte finish! Certainly an eye-catcher.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Oct 20, 2012 8:03 pm
First name: D
Last Name: S
Forgive my ignorance Lex, But what material did you use?
Totally georgeous.
DZ
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Oct 20, 2012 11:15 pm
First name: Ringo
It's from about 10 pieces of really nice vertical grained Macassar ebony. It is pretty well hollowed out or 'chambered' as the electric folks call it so the whole guitar should end up weighing about 8 lbs. A huge pain to work, especially carving the neck with hand tools, but boy oh boy is it pretty under finish.
PostPosted: Sat Oct 20, 2012 11:55 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Jack, what brand of matte finish are you using? I think it is gorgeous!
PostPosted: Sun Oct 21, 2012 12:24 am
City: chicagoland
State: illinois
sanding, painting, sanding, painting, repeat, repeat......i started this project about 2 years ago, finally getting around to painting it. its a baritone Jazzmasterish thing. i just blew up a pic of a jazzmaster or jaguar on the computer and traced it best i could, then blew that up more. tele style bridge, 2 single coils. neck one piece maple with ebony fretboard
i used about the worst wood possible, it was a nightmare. i think its doug fir or ponderosa, just garbage 2x8 they had at Menards. the difference between the hardness in the grain lines is large, so it is very difficult to get a smooth surface. plus the wood has lots of small cracks in it, which will hopefully stay that way-small, and filled!
this color is actually very close to fender's "sonic blue" or "daphne blue", can't recall which. just some rattle can stuff
PostPosted: Sun Oct 21, 2012 8:15 am
Heck yea it is. I'm loving the whole napkin sketch to finished product work flow. Finding it very satisfying.
So, how are you spraying the varnish? My wipe on just isn't flowing out well enough. Particularly, what size tip are you using (not that it matters much, 1.2 is the biggest I have)
PostPosted: Sun Oct 21, 2012 8:26 am
Standard Crapsman compressor, Walcom STM 1.2 gun, around 35-40 psi.
PostPosted: Sun Oct 21, 2012 8:41 am
First name: Tony
Last Name: C
City: Brooklyn
Beth Mayer wrote:
Hey Phillip,
Beth,
I beg to differ as I have yet to see an actual goat build any instruments on this forum. Goat lovers on the other hand....
http://www.CostaGuitars.com
PMoMC
Users browsing this forum: doncaparker, rbuddy and 39 guests
