It is currently Wed Aug 13, 2025 7:33 am
PostPosted: Mon Aug 27, 2012 9:44 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Well, I have struggled with this in the past. My hands are just too big. And with the Uke I just finished, there was no way to get anything of mine in that sound hole. Nothing like an impasse to help the mind really focus. And now, this just seems so obvious!! But, I've not recently seen anyone post this... so here is what I did. I took a long piece of sewing thread and and tied a safety pin to one end, and a looped zip tie to the other. Dropped the safety pin through the jack hole and pulled it out the sound hole. The zip tie on the other end is finish safe (soft) and won't come through the jack hole. By now, you know where I am going with this. Put the thread through the side holes in the jack (after you put all nuts and washers on). Tie a knot. Now, with the guitar vertical, lower bout up, use the thread to slowly, carefully, pull the preamp jack through the jack hole. Put on the washers and nut. The nut will cut the thread. Keep an eye on the holes in the jack for orientation. Once past the holes, insert a skinny eyeglass screwdriver through them. Tighten the nut and screw on the decorative jack nut.
Done. That was so obvious. And I bet a few of you do it that way. Perhaps, I'm the only one who did not know! [headinwall]
PostPosted: Mon Aug 27, 2012 10:05 am
I also have big hands, here's the way I do it. Dowel thru the end hole, stick the jack on the dowel (friction fit) at the sound hole. Pull it in place. Drop nut and washer over the dowel then proceed as you have stated.
Whatever skins the cat.
PostPosted: Mon Aug 27, 2012 10:58 am
Last Name: O'Melia
City: Huntsville
State: Alabama
That will skin said cat as well! [:Y:] Poor cat... doesn't stand a chance around here.
PostPosted: Mon Aug 27, 2012 11:04 am
City: winnipeg
State: manitoba
Country: canada
I don't want to hijack this thread but what pre-amp-jack did you use?
Bob :ugeek:
PostPosted: Mon Aug 27, 2012 11:08 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Not hijacking at all! Fishman Matrix Infinity, voiced for Uke. See my Tenor Uke thread for pictures.
PostPosted: Mon Aug 27, 2012 7:06 pm
First name: Tom
Last Name: West
State: Nova Scotia
I use a plug on a dowel. Plug through the jack hole up to the sound hole,push the plug into the jack and pull back through the hole. Install washers and nuts.
Tom
PostPosted: Mon Aug 27, 2012 11:10 pm
I just use a piece of coat hanger, with the about a 1/8" 90 degree bend at one end that fits into those little holes in the jack. I feed it through the end hole up to the sound hole and now I have the jack "hooked" and I can pull it through, works great!
PostPosted: Tue Aug 28, 2012 8:30 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I dunno. I think all of these ideas are clever, maybe even obvious. But still, I like mine the best so far since it has the least potential for any possible damage to the finish. Admittedly, the damage potential is low, but not non-existent. :) I'm a bit picky during the end phase. I even wear latex gloves and all of that.
Thanks!
Users browsing this forum: Cal Maier, guitarjtb and 17 guests
cron
