It is currently Thu Aug 21, 2025 9:00 pm
PostPosted: Wed Jul 04, 2012 12:04 pm
First name: Tom
Last Name: Phillips
City: Arcata
Shopping for an outside caliper for measuring top and back thickness. I have one that can measure around the edges, I want to be able to get closer to the middle of the top/back, so I'm thinking something like a 6 or 8 inch caliper. Any recommendations? What are you using?
PostPosted: Wed Jul 04, 2012 12:23 pm
If money is no issue, buy one of these. They are nice. http://www.stewmac.com/shop/Tools/Measu ... liper.html
If money is an issue, buy a cheap dial indicator and attach it to a plywood frame. $12 at Grizzly. http://www.grizzly.com/products/Dial-In ... 001-/G3632
http://www.chassonguitars.com
PostPosted: Wed Jul 04, 2012 1:14 pm
I went the cheaper route Kent described and it has worked great.
PostPosted: Wed Jul 04, 2012 5:06 pm
I just bought the calipers from LMI for $170, but they work well.
PostPosted: Wed Jul 04, 2012 5:16 pm
Last Name: Kincheloe
Home made with dial indicator for me. Not like you need extreme accuracy anyway, since every piece of wood is different. I mainly just use it to check for evenness, and to make sure I'm not way outside the typical thickness range.
PostPosted: Wed Jul 04, 2012 9:36 pm
Last Name: A
I just got this one and I like it much better than the caliper which they sell for $133 that has the metal frame.
This was $28.00 - I highly recommend it ~! it does 8" - in fractions/inches, inches, and mm
http://www.amazon.com/Quint-iGaging-Digital-Outside-Calipers/dp/B002PU77Q8/ref=sr_1_3?ie=UTF8&qid=1341455722&sr=8-3&keywords=outside+caliper
PostPosted: Thu Jul 05, 2012 1:51 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
I have one of these an it is pretty good but it does have limitations. The reach being the main one. I have used someone 12" violin style caliper and plan on getting one after seeing that it is much superior.
Another day, another dollar.
PostPosted: Thu Jul 05, 2012 11:42 am
Ive seen this one called Magic probe - but Im not sure of the cost - sure looks cool though!! Especially for luthiers
http://www.youtube.com/watch?v=KKtFxzFbOiI
Heres a demo of it in action
Charlie
PostPosted: Thu Jul 05, 2012 11:57 pm
First name: Tom
Last Name: Phillips
City: Arcata
Ah, thanks. Was tempted by the Quint and the $100 Amazon gift card. I figure it's accurate enough to tell me whether I'm in the right time zone, and the rest is just instinct. Someday I may go big, but not right now.
That and a doublesided diamond stone should about kill it. These gift cards are great for stuff that would otherwise be hard to put lots of money into!
PostPosted: Fri Jul 06, 2012 1:12 am
Last Name: Shaw
City: Philadelphia
State: PA
Charlie
This works in a similar fashion as the Hacklinger Thickness Gauge. This is just and electronic version I believe. The top of the line one is about $400 and the lite version is $229. I have seen their ads in Fine Woodworking magazine.
PostPosted: Fri Jul 06, 2012 2:14 am
If you're getting into diamond stones, my recommendation for sharpening is an extra extra coarse and extra fine 8x3" DMT dia-sharp. They cut fast enough that the inbetween grits aren't really necessary, and the XXC is not so coarse that you shouldn't start with it anytime you're preparing a new blade, or regrinding a bevel or whatever.
The extra extra fine is nice to quickly smooth the back side of plane blades further, but it's more expensive than XF and still not fine enough for a final surface, so you might as well just get the XF and then switch to other abrasives. Lee Valley's 4 grits of diamond lapping film are the best I've found for fine polishing of the back side, and creation of the micro bevel on the bevel side.
For fret leveling, the coarse 2x6" is just about perfect.
Don't buy the double sided dia-sharps. They're not flat. Or at least mine aren't. They're fine for sharpening the bevel side of chisels and plane blades, but not for flattening the back side.
Users browsing this forum: No registered users and 40 guests
