It is currently Mon Sep 15, 2025 11:28 pm
 Post subject: CA removal from uv poly?
PostPosted: Sat Jun 16, 2012 10:11 pm
Is there a product that will remove CA glue from a UV poly finish that won't eat the finish? I smeared jet glue on a headstock and I'm hoping I can avoid a sand/rebuff...
PostPosted: Sat Jun 16, 2012 10:31 pm
Don't know about the UV but I've used 100% acetone to remove CA from standard polyester finish. Didn't even touch the polyester. I tested in the pickup cavity first. It beaded up and didn't even begin to dissolve the guitar finish, and it took the CA right off.
Old growth, shmold growth!
PostPosted: Mon Jun 18, 2012 7:11 am
Last Name: Ressler
City: Sandwich
State: IL
Zip/Postal Code: 60548
Have used super glue remover without any harm
John Ressler
PostPosted: Mon Jun 18, 2012 12:09 pm
Hmmm, but what is superglue remover?
PostPosted: Mon Jun 18, 2012 8:35 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Acetone will remove CA, and should have zero effect on UV polyester.
I have done it a few times on Taylors with UV polyester, and hundreds of times on the catalyzed polyester of Asian guitars.
Mostly acetone.
PostPosted: Mon Jun 18, 2012 8:41 pm
Last Name: Garrish
Acetone and nitromethane both work well as CA solvents, it's likely one of those.
Bob Garrish
PostPosted: Mon Jun 18, 2012 9:50 pm
Thanks folks...
PostPosted: Tue Jun 19, 2012 4:42 pm
Acetone did the trick, thanks!
