It is currently Wed Aug 13, 2025 7:31 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
 Post subject: Re: Nitro Buffing Setup
PostPosted: Mon Jun 18, 2012 10:57 am
John Sonksen wrote:
I think it was on MIMF before they changed the site, I guess I'll have to wait until they update the archives to look at it again.
OK, the archives have just now been ported over to the new MIMF. But you have to register to be able to see it.
http://www.mimf.com/phpbb/index.php?sid=572395138b1532e7a7ba979c8fc85954
PostPosted: Mon Jun 18, 2012 11:36 am
Last Name: Sonksen
City: PORTLAND
State: Oregon
Zip/Postal Code: 97216-2013
Sweet, I had some things bookmarked over there that I'll be able to look at again. I'm sure I'll have to search for it again, but at least the pages are available again.
PostPosted: Mon Jun 18, 2012 11:56 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
Here's the buffer I built about 8 years ago. It has a 1/4 HP 1725 RPM motor turning the shaft at half speed through 2" & 4" pulleys.
As you can see, it is attached to a wall & hinges up out of the way, when not in use.
I mounded it so the shaft is about mid-chest height & find this very comfortable on my poor old back.
The thing I like best about this design is that there is no support structure above or below to bump the guitar into.
Every place I could bump into is covered with 3/8" X 1" self adhesive foam tape. (The pics were taken when the buffer was new & I hadn't yet put the foam tape on all those nasty sharp corners.)
Originally, I used double wheels, but since most of my instruments are cutaways and quite tight waisted, I find a single wheel works better for me.
I leave the belt a bit slack so the buffs will stall if too much force is applied. If I catch an edge, there is enough momentum that the belt slipping doesn't help much. It happens really fast, so you gotta have a firm grip & avoid catching an edge.
I have had a neck tossed onto the floor & it's no fun, when it happens.
I mounted a small fluorescent light on the wall at floor level. The light comes on when the buffer is running. Really helps to be able to see what's happening as you buff.
The shaft is 36" long... If I built another, I'd add 6" to the length to get the wheels a little further apart. I would also mount the bearings on a pad attached to the ends of the stressed skin table, instead of underneath it. This would give a bit more room to move without fear of bumping into the rig.
I used a friend's Shop Fox once & didn't like how close together the wheels are. The longer the shaft, the better, is my feeling.
PostPosted: Mon Jun 18, 2012 12:06 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
How do you make a shaft? Do you need a machine shop to make the right threads and get it to fit in the bearing?
I have trouble finding shafts but steel rods and tubes aren't hard to find, however I am concerned that I have to take it to a machine shop to get it to fit the bearing exactly.
Typhoon Guitars
PostPosted: Mon Jun 18, 2012 7:00 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
Tai Fu;
You can buy precision ground shaft to fit any common bearing size. Most machine shops have this stock available. I have heard that Go-Cart axles work well as a buffer shaft. They are easily obtainable & are already threaded... & cheaper than having a machine shop do the work. In Taiwan, you may have more difficulty finding these materials.
On my rig, I used 1" shaft & turned down the ends to 3/4" to fit the wheels.
I threaded both ends with a right hand thread & used self locking nuts.
To save money, you could buy 3/4" shaft & thread it far enough to wind a nut on to support the inside the wheels.
I don't know how well 3/4" shaft would work on a shaft this long... Probably be fine, but it might be too flexible.
PostPosted: Mon Jun 18, 2012 7:03 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
double post... sorry!
PostPosted: Wed Jan 30, 2013 12:49 pm
First name: Rienk
Last Name: Ayers
City: Santa Maria
Daniel Minard wrote:
Tai Fu;
This concept has been picked up in a new thread, but here is an interesting shaft to use, 39-1/2", 1-1/8" stepped down to 1" - and already threaded and keyed - all for $35
bliss
http://www.bmikarts.com/1-18-to-1-Step- ... p_514.html
PostPosted: Wed Jan 30, 2013 6:48 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Not to change the subject.But how much pressure should be applied while buffing?I`ve always errored on the side of caution using very light pressure.I`m really not sure if this is correct or not.
James W Bolan
Nashville Tennessee
PostPosted: Wed Jan 30, 2013 7:56 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I have been having problems with buffing, it seems no matter how fine of a grit I wet sand with there are always scratches no matter how much buffing I do, starting with rather coarse compounds that would just not go away. The problem is bigger with nitro than poly actually since you could apply a LOT of pressure with poly and sanding scratches would go away almost instantly.
Typhoon Guitars
Users browsing this forum: Cal Maier, guitarjtb and 21 guests
