It is currently Fri Aug 08, 2025 1:55 am
PostPosted: Wed May 23, 2012 1:55 pm
First name: Dan
Last Name: Pennington
City: Brooklyn Park
State: MN
Zip/Postal Code: 55428
I've seen photos of some side benders that have what looks to be a sheet metal arch on the waist caul. I'm assuming that it auto adjusts to whatever waist shape your bending form has. Who sells these? Or who designed it? Any info around on it - plans, photos, etc?
PostPosted: Thu May 24, 2012 6:57 am
Mine is like that. Got it from John Hall at Blues Creek. Love it.
Mike Lindstrom
PostPosted: Thu May 24, 2012 8:48 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Anyone got a photo of the sheetmetal waist caul from the side view?
Fred Tellier
PostPosted: Thu May 24, 2012 8:05 pm
First name: kevin
Last Name: waldron
City: Bell Buckle
Zip/Postal Code: 37020
See if this helps.
God Bless.
Kevin
PostPosted: Thu May 24, 2012 8:35 pm
First name: Dan
City: Brooklyn Park
State: MN
Thanks, Kevin. The solid piece inside the metal does the trick.
I was playing with some aluminum flashing for the metal tube, but even with three layers of aluminum, it was still too soft to compress my spring steel slats into the waist curve. I might have to buy another slat and sacrifice it.
I was about to experiment with a solid piece inside.
Your plan confirms my thinking. And the round form should help from crimping the side wood with a sharp edge. I'll change to a larger round shape inside.
Nice work on the plans. Thanks, again.
Dan
PostPosted: Thu May 24, 2012 8:50 pm
First name: Fred
Last Name: Tellier
City: Windsor
Thanks for the pdf file Kevin, that is what I thought everyone was doing, mine is quite different and has to be adjusted for each different bending form waist shape. I might make up one with the sheet steel and dowel before my next bending session. Will this style also work in a cutaway press
Fred Tellier
PostPosted: Thu May 24, 2012 8:52 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
Not sheet metal...but I use 1/4" Aluminum, stacked, with a full radius on the contact edge of each piece, about 7 of em. I inserted them into a shoe and then bolted them together when I had them where I wanted. Haven't moved them since.
I have also gun drilled Aluminum billets that were 8" long for a heating element to be inserted and then used as a waist form to bend sides in a bender similar to a Fox style.
Don't think unbacked sheet metal is going to be able to hold your shape when you will need it most. Just my .02
Tim
PostPosted: Fri May 25, 2012 5:11 am
State: Tennessee
Yes.
PostPosted: Fri May 25, 2012 11:28 am
First name: Dominic
Last Name: Regan
City: Canberra
I've got the Blues Creek bender and took the wooden rod out. The SS cap is very stiff but conforms to the waist on different models under pressure. Works great.
Dom
PostPosted: Fri May 25, 2012 12:07 pm
First name: Fred
Last Name: Tellier
City: Windsor
That's what I use also but my plates are made from 1/4" masonite. Works great but needs to be adjusted for each waist and cutaway shape.
Fred Tellier
PostPosted: Sat May 26, 2012 2:55 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
From the title I thought you were going to use Metal caul to make a Metal guitar...
Typhoon Guitars
PostPosted: Sat May 26, 2012 12:35 pm
First name: Nelson
Last Name: Palen
Interesting concept!
Looks like a short heat blanket could be placed inside to get heat inside the bend.
