It is currently Wed Aug 06, 2025 1:28 pm
PostPosted: Wed May 23, 2012 12:04 pm
This top was pulled off a 1931 Martin OM 28. There was old work done on it by the factory at some point and the plate was changed. The original plate was 1 3/8 inches wide . I could measure that off the notches in the X braces. The bracing was all notched and the transvers brace is .325 wide .650 high the X braces are .312 by .625 , tone bar and finger braces are .250 wide. The width is 15 1/16 without the binding , with the binding it was 15 3/16 inches.
Look close at the rosette , that is different to the modern . Enjoy
PostPosted: Wed May 23, 2012 12:07 pm
Last Name: Beaver
City: Lake Forest
Oops! Picture disappeared
Back again and even more!!!
Joe Beaver
Maker of Sawdust
PostPosted: Wed May 23, 2012 12:12 pm
Last Name: Beaver
City: Lake Forest
Very infornative John. Thanks for posting
Joe Beaver
Maker of Sawdust
PostPosted: Wed May 23, 2012 12:32 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Cool. Those braces look very hand carved
What's the white ring around the sound hole?
PostPosted: Wed May 23, 2012 12:37 pm
Last Name: Beaver
City: Lake Forest
Rosette picture didn't get posted
Joe Beaver
Maker of Sawdust
PostPosted: Wed May 23, 2012 12:42 pm
Last Name: Sollod
Thanks for posting John. That looks like a pretty big bridge patch...
www.swiftcreekguitars.com
PostPosted: Wed May 23, 2012 12:56 pm
Very interesting, John! Thanks for sharing these.
That's a big bridge plate! eek Brazilian rw?
PostPosted: Wed May 23, 2012 12:57 pm
Buffing compound, I'd say.
jw ( o)===:::
PostPosted: Wed May 23, 2012 3:14 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
There is nothing quite like having the guitar apart to get the real info.
It does make you wonder why Martin builds modern OM's with 1/4" X-bracing, since none of the originals I have measured were so equipped.
PostPosted: Wed May 23, 2012 4:12 pm
Last Name: Arnold
City: Newport
Double post.
PostPosted: Wed May 23, 2012 6:06 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Too cool. Gotta ask though, why was it pulled?
Brian
PostPosted: Wed May 23, 2012 6:25 pm
structural issues and it is getting converted. The top is cracked at the neck block and the damage at the plate makes this a prime candidate for a 45 conversion.
PostPosted: Wed May 23, 2012 6:27 pm
Rosette
here it is
PostPosted: Thu May 24, 2012 6:48 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
How did it sound with that gigantic bridge plate?
Kevin Looker
I'm not a luthier.
PostPosted: Thu May 24, 2012 7:13 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
Thanks, John,
did you measure the thickness of the top?
We are all in the gutter but some of us are looking at guitars.
PostPosted: Fri May 25, 2012 11:27 am
Last Name: Arnold
City: Newport
My 1930 OM-28 had similar damage, but I chose to save the top. That is in spite of the fact that there is no original top left under the bridge. No one who has played the guitar could detect anything abnormal or substandard about the sound. The key is the parallel grain red spruce patch, which performs infinitely better than any oversize bridgeplate, especially a rosewood one.
I used a similar spruce patch underneath the fingerboard. The UTB had previously been replaced with a 1/2" wide brace, but after installing the patch, I installed a 5/16" wide brace like it had originally.
The top is reasonably flat, and the guitar was strung with medium strings for over 10 years with no change in the action.
The marks around the bridge were from an oversize pyramid bridge which was on the guitar when I bought it. The 'bridgeplate' was 3/8" thick Douglas fir plywood, at least as large at the rosewood plate in John's photo.
PostPosted: Fri May 25, 2012 1:03 pm
I agree the top may have been salvageable but the customer wanted to have this converted . The top was also thinned when it was refinished at the factory sometime in the 70's. Since the guitar was not in original condition with the refin , replaced bridge and pickguard , it was a good candidate for conversion.
I won't destroy a guitar for conversion unless it had already been altered.
PostPosted: Fri May 25, 2012 1:54 pm
Thanks John! (and John!) Any idea what those crisp looking rosette rings are? 10/20/10 B/M/B? plastic in the middle?
PostPosted: Fri May 25, 2012 5:45 pm
actually the rosette is made from Black wood fiber , maple and according to the Archive , the inner white was a plastic no longer available called fibroid and I think it was a brand name , and may have had a acetate base. I use ivroid for the off white appearance. I do get the "vintage" rosette material custom made.
inner and outer rings are the same .010 blk .015 maple .030 blk .015 maple .010 blk
inner ring
.010 blk .015 maple .030 blk .040 white. .010 blk .040 white .030 blk .015 maple .010 blk
PostPosted: Fri May 25, 2012 7:38 pm
State: Tennessee
John Arnold wrote:
Make you feel good when they use the "good stuff" for a repair. duh
Users browsing this forum: doncaparker, ptourin and 20 guests
