It is currently Sat Jun 13, 2026 7:10 am
 Post subject: Soundport Insert…
PostPosted: Sun Apr 08, 2012 7:30 pm
Last Name: Sollod
I am working on a Black Limba grand auditorium with ziricote fingerboard, bridge, rosette, headplate, and back strap. I put in my first soundport. I was thinking about making a soundport insert out of ziricote to close the hole if I want to. I think I have seen this done here on the OLF. I was wondering what would be a good way to do this… Velcro? Does anyone have any thoughts or comments. Is this a cool idea or is it lame? I was also thinking of some sort of hinge design. I think I’ve seen this done. Has anybody done this? What do think? …Any photos of something like this?
www.swiftcreekguitars.com
 Post subject: Re: Soundport Insert…
PostPosted: Sun Apr 08, 2012 11:27 pm
First name: Rick
Last Name: Davis
City: Seattle
I've recently talked with several of the first people to do soundports -- Laskin, de Jonge, Manzer -- and they all had sliding closures on the first instruments. John Monteleone, who came up with it independently, also did. As far as I know, none of them bother anymore as players don't generally want to close the 'port.
PostPosted: Mon Apr 09, 2012 8:29 am
Last Name: Ensor
State: Missouri
While the sliding port is the one I am most familiar with (and am playing around with myself) here is another option:
http://www.acousticguitarforum.com/forums/showthread.php?t=241207
http://elevatelutherie.com
PostPosted: Mon Apr 09, 2012 8:32 am
First name: aDAM
Last Name: cHAN
City: Singapore
State: Singapore
Zip/Postal Code: 323108
Country: Singapore
What might be the reason for keeping the option to close the sound port? Learning from luthiers, the creation of sound port hinges on augmentation of sonic properties especially for the player.
Years back, I have the chance to remove a spoiled onboard electronic control module from an acoustic guitar. A rectangular opening was left on the side of the guitar. Lo and behold, the player felt the differences in sonic properties and it was improvement to the player. The opening was left on the guitar since…
I have seen some guitars with sliding features to close and open the sound port. My best guess is the sound ports are left opened most of the time. To think of the closing feature as dust protection doesn't make a lot of sense as well. Dust can enter from the sound hole anyway.
Perhaps for training one's craftsmanship… the challenge in making a functional cover as well as one that is aesthetically pleasing should provide sufficient impetus to carry out this task.
Anyhow, best wishes to you in the event you have decide to take on the challenge. Keep us updated should you do. Cheers.
Regards
aDAM
PostPosted: Mon Apr 09, 2012 9:37 am
Steve, I'm just finishing off one like that now. As much as anything, wanted to hear the actual differences plugging/unplugging the port. I'm hoping it will stay in place with some craft store foam cut slightly oversized.... let you know how it works out.
Milton, ON
PostPosted: Mon Apr 09, 2012 10:01 am
Having seen Marc Beneteau's inspired "stopper" I made this one for a recent commission:
PostPosted: Mon Apr 09, 2012 11:18 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I have sound ports in most of my builds and I would never close them. I often show people trying the guitars the difference in sound by covering the port with my hand while they are playing and they all prefer the port open. The closing of the port lowers the box resonance by around 3 hertz as measured with Audacity, the larger the port the more change, same effect as a larger sound hole.
Fred Tellier
PostPosted: Mon Apr 09, 2012 11:52 am
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
Inserted magnets could work too, but I guess you should think about it before closing the box and put magnets inside.
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Mon Apr 09, 2012 12:23 pm
Last Name: Sollod
It sounds like most of the time folks feel like the guitar sounds better with the port open, so why close it? Based on what Fred says, it appears that the difference in resonance is 3 hertz, depending on the size of the hole. I'm not quite sure what a difference in 3 hertz sounds like... Would there be any value to an insert that would reduce the size of the hole...? ...that is, that there is another smaller hole in the insert...? Perhaps this would allow for optimizing the resonance.
NOTE: I did not compensate for the soundport by decreasing the diameter of the front sound hole...
PostPosted: Mon Apr 09, 2012 2:08 pm
My concept of a soundport was so that you could hear the guitar! If you put your ear to the side when you play, you get the concept. So, technically, the forward soundport is off. To hear the guitar better, you need it on the other side of the bend, which is not the best place to put it? Can you hear the guitar better with one of those forward facing soundports?
PostPosted: Mon Apr 09, 2012 3:33 pm
First name: Fred
Last Name: Tellier
City: Windsor
My 1st was on the slope towards the waist from the high point of the upper bout, my last was from the high point forward towards the neck block. Both work about the same for the player and both are brighter sounding open than closed.
Fred Tellier
Users browsing this forum: No registered users and 66 guests
