It is currently Sun Jul 27, 2025 2:25 pm
 Post subject: Where to get plans
PostPosted: Thu Apr 05, 2012 8:56 pm
First name: Jon
Last Name: Woodall
City: Suwanee
State: GA
Zip/Postal Code: 30024
Well, my Martin kit came in, but I still need plans. Where do I get them. I see that LMII and STEWMAC have plans that say "Similar to Martin OM" but does that mean that they will match up to the kit?
Where would you guys get a set of plans for a Martin OM kit?
 Post subject: Re: Where to get plans
PostPosted: Thu Apr 05, 2012 9:09 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I'd start here, because they're free
http://www.grellier.fr/plans.php?lang=en
Kevin Looker
Ps
Yes I've built from them & I'm happy with the results. Take them to a blueprint shop for full scale printing.
I'm not a luthier.
PostPosted: Thu Apr 05, 2012 9:15 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
"Similar to Martin OM" is just a cover your *ss sort of line. Those plans and the free plans you can find will meet your needs.
Kinkos have large format printers that will print the pdf files you find on the web full size. I usally get a few copies so that I can cut some of the copies up.
PostPosted: Thu Apr 05, 2012 9:20 pm
First name: Jon
Last Name: Woodall
City: Suwanee
State: GA
Thanks guys! Huge Help!
PostPosted: Thu Apr 05, 2012 10:14 pm
Kevin Looker
Ps
+1
In addition to being free, TMK they are also the most accurate/true OM plans available with respect to bracing.
PostPosted: Fri Apr 06, 2012 12:12 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I buy printed plan from LMI and the like because I don't trust printers will print an accurate copy... plus the cost to print something that big is probably almost the same as what LMI charges for their printed plans, at least I know the stuff they have works.
They only say "Similar to OM" so Martin doesn't sue them.
Typhoon Guitars
PostPosted: Fri Apr 06, 2012 12:31 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
Well, these plans have been printed on the same kind of printer, one day. From a pdf or from a original scan, it's the same. It's even worse from an original paper plan because you have the error margin of both the scanner AND the printer.
That said, that why I never use any plan directly. I use plans as a reference, and redraw mine by hand. You can't have more precise than that.
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Fri Apr 06, 2012 7:51 pm
First name: Jim
Last Name: Kirby
So, your plan is off by a mm, why do you care?
I think you are stressing over variations that will probably be less than what you end up with during an actual build.
Jim Kirby
kirby@udel.edu
PostPosted: Sat Apr 07, 2012 11:59 am
Tai Fu wrote:
....They only say "Similar to OM" so Martin doesn't sue them.
The plans by Scott Antes from LMI are in fact only "similar" to Martin's OM/000. The dimensions are somewhat off, so if you want an "OM" that's the same body shape as Martin's, they are only an approximation. (The spacing for the tuners that is shown on the headstock plan will also result in the strings interfering with each other, as I found from experience.) You can find a template here: http://www.waldronmusic.com/product_inf ... f08iep4dg7 that is fairly "exact" I believe. John Hall is another good source.
Joe
Users browsing this forum: Bing [Bot], Chris Pile, Michaeldc and 20 guests
