It is currently Tue Aug 05, 2025 6:01 pm
 Post subject: Bending Ausie Blackwood
PostPosted: Fri Mar 30, 2012 8:51 pm
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Zip/Postal Code: 86339
Does anyone have experience bending ausie blackwood? I was thicknessing it today on my drum sander and noticed that it burns quite easily. I was just wondering if I needed to be concerned about my blanket temp. when I put it into my bender. If anyone has some input it would be greatly appreciated. Thanks!
PostPosted: Fri Mar 30, 2012 9:01 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
It wasn't my favorite wood to bend.
Next time I'll go from .095- .085.
Nasty to work with, but beautiful to look at!
PostPosted: Fri Mar 30, 2012 9:38 pm
First name: Trevor
Last Name: Gore
City: Sydney
We generally regard it as one of the easier woods to bend. The straight grained stuff is no more difficult than EIR. The figured stuff is easier to bend than figured maple.
http://www.goreguitars.com.au/main/page_10929_41.html
As for the bloodwood bindings....def. not the easiest wood I've dealt with.
PostPosted: Fri Mar 30, 2012 11:06 pm
Don't wrap your sides in foil when bending Aussie Blackwood or they'll turn green. It sands out but it's far better to just avoid foil in the first place.
0.085" generally works well.
PostPosted: Sat Mar 31, 2012 12:15 am
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Thanks for all the input it's greatly appreciated! Paul, I don't wrap with foil I wrap with craft paper so hopefully I won't have any green issues.
PostPosted: Sat Mar 31, 2012 3:14 am
First name: Allen
Last Name: McFarlen
City: Mt. Sheridan
State: Qld.
Zip/Postal Code: 4868
It's the easiest wood you'll ever bend.
But like Koa it will turn green and black when water is present and in contact with anything metal. Do not soak the wood. Just a wet and a squeegee off so it's barely damp, then I wrap mine in kitchen paper towel and then al-foil. It might get a just tinge of black that is easy to sand off. It's the water that will really stuff you up. Too much and it's all bad. You can get stains that will go 1/2 the way through if you get careless.
Allen R. McFarlen
Facebook
Cairns, Australia
PostPosted: Sat Mar 31, 2012 6:17 am
First name: rasmus
Last Name: erlemann
Country: Estonia
It's the easiest wood to bend according to my experience.
It bent very easily at 2.2mm (0.9'inch~) and there was almost no spring-back.
my aussie blackwood sides were perfectly quartered and there was very little flame.
PostPosted: Sat Mar 31, 2012 10:13 am
Wow, not in my experience! But you have more experience with it than me, I'm sure. It does burn easily, or rather discolors when sanding with a drum sander, and it can be pretty tough to bend. Rosewoods are much easier in general, but I agree that it is gorgeous to look at. Perhaps that's why I have basically a lifetime supply of the stuff.
I can bend figured maple almost without anything but soaking it in really hot water for a bit. At least the softer varieties I can. I'd put figured blackwood on par with mahoganies.
Users browsing this forum: Bing [Bot], bobgramann, doncaparker, guitarjtb and 18 guests
