It is currently Fri Aug 15, 2025 6:46 pm
 Post subject: Saddle slot angle?
PostPosted: Thu Mar 22, 2012 4:52 pm
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Zip/Postal Code: 86339
Well I'm working on my first bridge and struggling with the compensation angle of the saddle, I can't seem to find any info that describes this angle? [headinwall] Can anyone help me with this or point me to more info? I've seen many saddle slot jig videos but nothing about that angle. Should I just copy the angle off the plan (seems reasonable)? Input would be greatly appreciated.
Mark
 Post subject: Re: Saddle slot angle?
PostPosted: Thu Mar 22, 2012 5:29 pm
I dont use a measured angle, but a 3mm offset treble to bass .. you could workout whatever angle that is, but to me it doesnt matter .. just use 3mm
PostPosted: Thu Mar 22, 2012 5:34 pm
Saddle angle isn't really determined as an "angle", per se, but rather by string length. This varies by the string width locations. I.E. Stew Mac gives string length numbers for a 25.4 scale guitar as - Treble "E" 25.489 " (±0.030") - Bass "E" 25.614 " (±0.030"). Depending on the string spacing, though close as in angular terms this does change. Some guitars could be as wide a 2" some as 2 3/8 or more at the saddle.
It's best to mark off lengths and go from there.
PostPosted: Thu Mar 22, 2012 5:54 pm
nevermind....I thought I had something for you...
Old growth, shmold growth!
PostPosted: Thu Mar 22, 2012 6:29 pm
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Thanks for the input I really appreciate!
PostPosted: Fri Mar 23, 2012 1:43 am
Last Name: Renick
City: Mount Shasta
State: ca
Zip/Postal Code: 96067
Country: us
http://www.cumpiano.com/Home/Articles/A ... DDLE~1.HTM
http://shastaguitar.com/
http://www.kalimbakit.com/
PostPosted: Fri Mar 23, 2012 2:40 am
Since Comfyfoot posted that link, let me help clarify, as it can look somewhat confusing. Cumpiano makes his saddle slot 3 inches long.
At the ends of the slot, the treble side is 3/16ths in from the front edge of the bridge, the bass side is 5/16th's in from the front edge of the bridge, giving the slot it's slant. The front edge of the bridge is parallel to the last fret, the saddle is positioned so that the center of the saddle slot is compensated .15 inches back from the actual scale length, going by the middle of the saddle (not the front edge).
In other words, if the scale length is 25.4 inches, the center of the saddle would be placed at 25.55 inches from the nut.
PostPosted: Fri Mar 23, 2012 8:58 am
I've always found this discussion -- the manner in which compensation is laid out -- to be problematic. I find its easier to talk about saddle slope rather than angle, and I find measuring to the center of the saddle slot to be unnecessarily difficult. Most bridges are set with the leading edge of the saddle set to the scale length, and the offset adjusted accordingly. It's much easier to measure to the leading edge of the saddle -- something that you actually can see, and compare against, than against the center of the slot.
I use a slope of .125/2.875 and set the bridge to the leading edge of the slot on the treble side -- everything else follows from there. I use an .125" slot, and this allows a little more meat behind the strings on the bass side.
PostPosted: Fri Mar 23, 2012 9:03 am
David, you mean 0.125 slope over a length of 2.875 length (i.e. distance between high E and low E)?
PostPosted: Fri Mar 23, 2012 11:06 am
No. My slot is 2.875".
PostPosted: Fri Mar 23, 2012 3:40 pm
I use a 1/8 in off set from the 1st to 6th string. About a 3 degree angle will get you close
hmmm .... .125 inch over the saddle slot length .. thats about 3mm (and I use a 70mm slot - thats about 2.756 inches) !!!!! Great minds think alike David.
PostPosted: Fri Mar 23, 2012 4:44 pm
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Wow great info! Thank you all very much!
Users browsing this forum: DennisK, Kbore and 12 guests
