It is currently Tue Jul 22, 2025 8:43 am
PostPosted: Mon Feb 13, 2012 11:55 am
Last Name: Sollod
I've been thinking about setting up a jig to shape the back of the headstock among other things. I have seen that what is typically used for this is a small stationary 4" X 36" belt sander with a jig made to rest the headstock on and feed it under the arm of the belt sander and bring it to the desired thickness and put in a nice scooped volute. [:Y:]
I understand the concept of the jig. A hinge is used as a pivot, but I'm not sure how to adjust the angle. How is this designed? It looks like some type of long bolt arrangement. Does anyone have a photo, plans, and/or can you describe how to adjust the height?
Also, do you have a recommendation for a 4" X 36" belt sander? It looks like most of the ones I've looked at (Harbour Freight, Rikon, etc. for about between $70 - $150) have some kind of complaint... but, I would guess for this light use it may not matter so much...
BTW - I've built 6 guitars (working on number 7) so I'm "small time".
www.swiftcreekguitars.com
PostPosted: Mon Feb 13, 2012 7:31 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
If you have a drill press. you can easily mount a 3in sanding disk , with a wood fence mounted to do this .Most of the small sanding machines especially the 4 by 36 are IMHO crap, unless you can find a cheapie off craigslist or e-bay.Think china gaah
PostPosted: Mon Feb 13, 2012 8:07 pm
Last Name: A
I would also like to see the jig -
I am happy with my Porter Cable - it has an 8" disk and the 4x36 belt -
i would not say it is crap - it serves it's purpose well.
PostPosted: Mon Feb 13, 2012 10:13 pm
Here's mine. I'm sure there are better designs out there, but this just gives a picture of one idea. I used spring hinges to keep tension on the whole mess and barrel bolts because....well....because that's what I had on hand. I would actually like to redesign it at some point to make it a little more solid, but it works. Which, knowing me, means I'll probably redesign it when something breaks or I need to get a new sander.
Wes McMillian
Santo, TX
http://www.wesmcmillian.com
PostPosted: Tue Feb 14, 2012 7:57 am
Last Name: Wood
City: Chester Springs
State: PA
Zip/Postal Code: 19425
Here's a bad cell phone picture of mine.
Chris.
PostPosted: Tue Feb 14, 2012 10:07 am
Last Name: Sollod
This is what I'm talking about... Those are some interesting designs. Chris, I was thinking that a turnbuckle could be used to adjust the height (thickness). Does anyone else have a design to share before I attempt to make one?
PostPosted: Tue Feb 14, 2012 11:36 am
You could do like Chris but use threaded rod. The rod would go into a thick block so you would have some travel and the rod would still be inside the block. Have two nuts, one to adjust height, the other to lock. Or one coupler nut with some blue lock tight or one of those lock nuts with the nylon inside.
L.
PostPosted: Tue Feb 14, 2012 11:48 am
I found an old picture of mine. I used 1/2" threaded rod. I'll see if I can find a better picture of the mechanism.
PostPosted: Tue Feb 14, 2012 1:28 pm
Online
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
When I made the table height adjustment for my thickness sander (same principle) I used threaded rod and imbedded a coupling nut into the loser brace and put a hand wheel on the rod. If I had been thinking more clearly, I would have used a tee-nut instead of a coupling nut, I think that would have been much easier.
Bryan Bear PMoMC
PostPosted: Tue Feb 14, 2012 1:33 pm
Last Name: Wood
State: PA
Mine works fine. Were I doing it over again I might fabricate a way to lock it in position. It's never moved, but I always worry it might.
Chris.
Users browsing this forum: jfrench and 17 guests
