It is currently Mon Jul 28, 2025 11:08 am
PostPosted: Sat Feb 11, 2012 12:32 pm
Last Name: Charnock
Country: UK
Hi
This was my fist top that I prepared, glued and set the sound hole inlay.
I planed it a bit and then ran it though the drum sander a few times, its now about 2.80mm to 3.00mm. I will probably have to smooth off the the drum sander grit marks as it was 80 grit. My question is , is it too thin already or will I be OK ?
I guess the final thickness will be about 2.5mm
PostPosted: Sat Feb 11, 2012 12:55 pm
Well, it's hard to say due to all the usual caveats, but I suspect you'll be just fine, unless you're a real heavy strummer.
PostPosted: Sat Feb 11, 2012 1:13 pm
The color on my computer monitor is not very accurate and it's hard to tell what top wood that is. Looks like it could be either Sitka or cedar. The answer to your question may depend at least somewhat on what wood you're using.
PostPosted: Sat Feb 11, 2012 1:23 pm
Last Name: Charnock
Country: UK
It is Spruce
PostPosted: Sat Feb 11, 2012 1:58 pm
Last Name: Kincheloe
Looks like OM-ish size? My guess is you'll be fine.
I can say this- if you make it that thin, make the X angle very wide, carve it too short, scallop the legs just below the bridge, use a bridge shape with fairly pointy wings that don't get a great deal of overlap with the X, and set the neck angle a little too high resulting in the strings being ~9/16" above the soundboard at the bridge... then it will probably dip a little too much around the soundhole :?
PostPosted: Sat Feb 11, 2012 3:22 pm
I say you are more than fine. I usually make my spruce tops thinner than this, and even on Dreadnoughts.
My advice is go forward and don't worry about a thing.
Alain Moisan
(Now building just for fun!)
PostPosted: Sat Feb 11, 2012 8:56 pm
Last Name: Cox
I agree... It will be fine...
I wouldn't worry about gyrations of trying to re-design your bracing scheme.... just make sure that all the braces that are supposed to butt together do... Don't leave any gaps that aren't in the original design...
Users browsing this forum: ChuckB and 10 guests
