It is currently Sun Jul 27, 2025 10:05 am
 Post subject: Fretboard radius?
PostPosted: Fri Feb 10, 2012 7:07 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
What radius do you or your customers prefer and on what type of guitar? Factories seem to span from 12-16 inch for steelstrings, curious what everyone else is doing.
Brian
 Post subject: Re: Fretboard radius?
PostPosted: Fri Feb 10, 2012 7:57 pm
My standard if a spec guitar is a compound radius, 12" at the nut to 16" at the 20th fret.
Chuck
PostPosted: Fri Feb 10, 2012 8:41 pm
I use a compound type radius of 14" at the nut - 20" at the 21st fret (termination of the board)
I am here: http://maps.google.com/maps?ll=49.068135,-122.373814
PostPosted: Fri Feb 10, 2012 9:10 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
How do you do a compound radius? do I make the board 16", and then sand the first 10 frets with the 10" block, or is there more to it?
Typhoon Guitars
PostPosted: Fri Feb 10, 2012 11:17 pm
You can do it by hand but a jig is more repeatable.
I am here: http://maps.google.com/maps?ll=49.068349,-122.373847
PostPosted: Fri Feb 10, 2012 11:32 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So how do you make a jig for it, and what if I don't have a belt or thickness sander, because the only radius jigs (which allows the possibility of a compound radius) requires either one...
Typhoon Guitars
PostPosted: Sat Feb 11, 2012 12:06 am
No it doesn't. Most require a router. Do a search there are many threads here on compound jigs.
I am here: http://maps.google.com/maps?ll=49.068201,-122.373841
PostPosted: Sat Feb 11, 2012 3:55 pm
Last Name: Howard
City: Magnolia
State: Delaware
So what are you guys building with compound radii? Dreads for flatpickers? OM's for fingerstyle?
Brian
PostPosted: Sat Feb 11, 2012 4:26 pm
Everything I build now has a compound type radius. For either flat pick or finger style.
00 to GA
I am here: http://maps.google.com/maps?ll=49.068214,-122.373827
PostPosted: Sat Feb 11, 2012 9:37 pm
Mine are also all compound radius. Parlor to dred.
Chuck
