It is currently Wed Aug 06, 2025 6:29 pm
PostPosted: Sat Jan 14, 2012 12:13 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Put it on in the other direction?
Alex
PostPosted: Sat Jan 14, 2012 12:31 am
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
Put it on the wood.
PostPosted: Sat Jan 14, 2012 1:07 am
First name: Stuart
Last Name: Gort
That's rubber adhesive on that tape.
For a better stick than rubber adhesive find some green 3m pinstripping tape...which has silicone adhesive. That will be less sensitive to heat.
If you want a good, permanent stick...find something with acrylic adhesive on it. Then....if that still doesn't work well enough you can treat the bearing with acrylic accelerant prior to appying the tape....which 3m makes...and I can't remember the number. Acrylic adhesive gets stronger with age. The accelerant gets it there in minutes. We used it to adhere 3m urethane tape to propeller leading edges. The centrifugal force would challenge the acrylic adhesive on the tape but the accelerant more or less made it a permanent part of the blade.
If you really need accelerant I might be able to dig up the number on an old computer but I doubt you're going to want to buy a quart of this stuff. :)
StuMusic
PostPosted: Sat Jan 14, 2012 2:58 am
First name: Jim
Last Name: Hansen
Every time I've tried to put tape on a bearing I've either had problems with it coming off, or had challenges getting a consistent depth on the cut.
It's not perfect, but I had better luck running a strip or two of blue tape around the body where the bearing(s) rides.
Jim Hansen
PostPosted: Sat Jan 14, 2012 10:29 am
Last Name: Wood
City: Chester Springs
State: PA
Zip/Postal Code: 19425
I use the aluminum tape for taping duct work joints. Buy it at any Lowe's. Seems to work pretty well. As others have said, it works better if I pay attention to the direction of rotation.
Chris.
PostPosted: Sat Jan 14, 2012 11:06 am
Use Scotch 3M #2060 masking tape for hard to stick surfaces. Great for bearings and gluing binding, among other things.
PostPosted: Sat Jan 14, 2012 11:15 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
I used some copper tape I had on my bearing and it is staying on quite well.
PostPosted: Sat Jan 14, 2012 11:55 am
First name: Big
Last Name: Jim
Fillippo , A REAL PRO doesnt need no stinkin tape pfft laughing6-hehe laughing6-hehe
PostPosted: Sat Jan 14, 2012 12:13 pm
First name: Aaron
Last Name: Craig
State: Missouri
I've had some luck using electrical tape. You can sort of stretch it around the bearing for a tighter fit. But, I now prefer running tape around the sides.
Aaron Craig
PostPosted: Sat Jan 14, 2012 1:10 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I run tape around the sides too. I've never had much luck with tape on the bearing.
PostPosted: Sat Jan 14, 2012 1:16 pm
Probably a dumb question, but what is the purpose of putting tape on the bearing?
PostPosted: Sat Jan 14, 2012 1:26 pm
First name: Stuart
Last Name: Gort
For what it's worth....pretty much all metal tapes are going to use acrylic adhesive. Not a guarantee mind you, but I haven't found a store bought aluminum or copper tape yet that didn't use acrylic adhesive.
StuMusic
PostPosted: Sat Jan 14, 2012 1:38 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
runamuck wrote:
Put it on the wood.
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Sat Jan 14, 2012 4:20 pm
Wouldn"t useing the correct size bearing work better, instead of shimming it with tape?
PostPosted: Sat Jan 14, 2012 5:45 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Yeah, I think hat's always the best thing to do if it's available.
PostPosted: Sat Jan 14, 2012 6:32 pm
Therein lies the problem!
PostPosted: Sat Jan 14, 2012 7:14 pm
I too have had better luck taping the sides than the bearing.
PostPosted: Sat Jan 14, 2012 8:11 pm
What about all that wasted tape? gaah
PostPosted: Sat Jan 14, 2012 8:26 pm
First name: alan
City: Santa Rosa
State: ca
What about all that wasted tape? [quote]
and time...
PostPosted: Sat Jan 14, 2012 8:46 pm
First name: Jim
Last Name: Hansen
How long does it take to run a couple of strips of blue tape around a guitar body?
Jim Hansen
PostPosted: Sat Jan 14, 2012 10:16 pm
First name: Jim
Last Name: Hansen
Huh.. I've never had trouble with the tape on the body method.
Is the bearing binding?
Jim Hansen
PostPosted: Sun Jan 15, 2012 7:58 am
Could be seized with glue buildup between bearing and shaft. I keep my bits in a small plastic container filled with kerosene.
Helps prevent gunk buildup.
PostPosted: Sun Jan 15, 2012 11:57 am
First name: Ringo
Ridgid 2400 is under $100 last time I checked. Changing height can be a pain, but getting the bearing right where you want it is a breeze.
PostPosted: Sun Jan 15, 2012 2:01 pm
Last Name: A
Lex -
thanks for posting that picture ! I did not know the guide existed - I have the 2401 (I think) which did not come with the guide but is a great router -
do you do all your bindings with this ? How does it work ?
PostPosted: Sun Jan 15, 2012 2:18 pm
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
I made a binding machine I copied from Chris Paulick's video http://www.youtube.com/watch?v=Ve_PmQMSnQQ (Thanks Chris I love your videos).
He uses an adjustable depth of cut guide so you don't need any bearings when doing the sides. Work's good for me too. Doesn't solve the problem of routing out other areas though.
We are all in the gutter but some of us are looking at guitars.
Users browsing this forum: ptourin and 42 guests
