It is currently Mon Aug 11, 2025 4:00 pm
PostPosted: Mon Nov 28, 2011 2:50 pm
Last Name: Sollod
I have looked all over on the internet for 1/4" top bearing flush cut router bit but can't seem to find one... I want to use it for a soundport jig.
Anybody know where I can get one?
www.swiftcreekguitars.com
PostPosted: Mon Nov 28, 2011 3:05 pm
First name: Big
Last Name: Jim
Amana tool #s 47090 or 47092 1/4" bearing top mount 2 flute flush trim bit # 47090 has 1/2" length of cut 47092 has 1" length of cut Call 1-800- 445-0077 ask for customer sevice or ask for closest local dealer .
Edit : Upcut Spiral 1/4" solid carbide bit with bearings Amana #s 46197 downcut # 46297
PostPosted: Mon Nov 28, 2011 3:06 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Lee Valley sells this one.http://www.leevalley.com/en/wood/page.a ... 46171&ap=1, but I would be worried about splintering. I think that you might be better to use a down spiral bit with a template collar.
Alex
PostPosted: Mon Nov 28, 2011 3:21 pm
First name: Mark
City: Concord
Change your search term to "Pattern Router Bit" and you will find tons of them. Klingspor, Woodcraft, WW Supply all have them. Whiteside is from NC if that matters.
PostPosted: Mon Nov 28, 2011 4:28 pm
Last Name: Sollod
Thanks guys, But these seem to have the bearing on the bottom... I want the bearing on the top. I have made a template for the soundport that I want to use as a guide. The bottom bearing won't help...
...you know what I mean? Any thoughts?
Alex you said...
Can you elaborate on that? template collar? ...do you have a picture of what you describe?
PostPosted: Mon Nov 28, 2011 4:30 pm
I think he means the other "top", as in the end closest to the collet.
I don't think I've ever seen one, probably because you would have to reduce the shaft to get the bearing on then weld cutters on to the smaller shaft.
You might try using the shaft of a 1/4" bit as the bearing. If you pattern isn't too soft and you keep it waxed and keep the bit moving, that can work quite well.
I like to use a smaller bit with a collar for mine. Less chance of a blowout.
http://www.chassonguitars.com
PostPosted: Mon Nov 28, 2011 5:00 pm
Use a 5/16 guide collar and a 1/4 inch downcut spiral instead .... your port will be slightly smaller (or you can always adjust the template size of the cutouts), but leaves some room to sand and bevel the edges.
PostPosted: Mon Nov 28, 2011 5:15 pm
First name: Alex
Last Name: Kleon
City: Whitby
Alex you said...
http://www.leevalley.com/en/wood/page.a ... 51208&ap=1 Using this type of template guide requires that you make your pattern smaller by the distance from the outside of the template guide to the outside edge of the router bit. I haven't seen a 1/4" pattern bit, but you can easily get a 1/2" size. You can get the template guides at any tool store or Home Depot. I would suggest getting a full set - they can accomodate a variety of router bits for many functions. I've got the Freud set, and have been happy with them.
Alex
PostPosted: Mon Nov 28, 2011 5:47 pm
I don't think these are available for "ordinary" routers; the shaft would have to be teeny-tiny where the bearing mounts. Not strong enough...
You'll note that the screw that holds the bearing on the end (in bottom bearing bits) is about 1/16"; but it's not supporting the cutters.
Hope this makes sense... :roll:
pvg
PostPosted: Mon Nov 28, 2011 5:50 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
What Tony said!!!!!
PostPosted: Mon Nov 28, 2011 7:26 pm
First name: Mark
City: Concord
http://www.woodcraft.com/Product/2083882/6717/Whiteside-RFTD2100-Flush-Trim-Down-Cut-Spiral-Router-Bit-14-D-X-1-CL-14-SH-3-OL.aspx
http://www.hartvilletool.com/product/2941/template-router-bits
http://www.amanatool.com/routerbits/down-shear-trimmer-47094.html
PostPosted: Mon Nov 28, 2011 8:36 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Kinda hard to find a 1/4" o.d. bearing to fit on a 1/4" bit shaft,
if ya know what I mean.
Smallest size I've found it 3/8".
Users browsing this forum: A.Hix, J De Rocher and 35 guests
