It is currently Fri Aug 08, 2025 9:48 pm
 Post subject: TAP TUNING tools
PostPosted: Mon Nov 21, 2011 4:14 am
First name: herry
Last Name: trismono
City: malang
State: east java
Zip/Postal Code: 65142
Country: Indonesia
hai,, what tools or machines do you use for tap tuning... [xx(]
and did you always tap tuning your board (back, side, and soundboard) eek
thank's... bliss bliss bliss
herry tze beehive
 Post subject: Re: TAP TUNING tools
PostPosted: Mon Nov 21, 2011 11:16 am
First name: Corky
Last Name: Long
City: Mount Kisco
my finger.... idunno
PostPosted: Mon Nov 21, 2011 12:04 pm
First name: Sen
Last Name: Goh
Country: Singapore
And the ear too [:Y:] :D
Sen CL Goh
http://senguitar.blogspot.com
PostPosted: Mon Nov 21, 2011 5:46 pm
Some folks like to use a small mallet, sort of like a piano hammer but with a piece of rubber on the end
PostPosted: Mon Nov 21, 2011 5:53 pm
WRT a hammer or mallet, the thread linked below has a couple of photos of, and brief discussion about an example of one used for this purpose.
viewtopic.php?f=10117&t=30241&hilit=tap+tune
PostPosted: Mon Nov 21, 2011 7:10 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
istrobosoft app on the Iphone....
MK5acoustics.com
PostPosted: Tue Nov 22, 2011 12:05 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
hai CharlieT, thank's alot..
may I know what is that tool machine like tuner on the photo? [uncle]
PostPosted: Tue Nov 22, 2011 12:06 am
First name: Jim
Last Name: Hansen
Henry,
That is an iPhone (or iPod Touch?) running an "app" called "ProTune".
Edit: It looks like the name was changed to "TuneUp"
http://itunes.apple.com/us/app/protune/id359063365?mt=8
Jim Hansen
PostPosted: Tue Nov 22, 2011 12:11 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
A piece of cork glued on to a stick to "bonk".
A mic plugged into a Boss tuner.
Still don't know what to do with the carving, shaving, etc.
PostPosted: Tue Nov 22, 2011 12:15 am
First name: Jim
Last Name: Hansen
It is neither of those things, speaking very specifically. If you read his posts, the 'mallet' is a piece of rubber sanding belt cleaner CA'd to a piece of maple, and the Tuner is an iPhone/iPod Touch app called "TuneUp" (formerly ProTune).
Jim Hansen
PostPosted: Tue Nov 22, 2011 1:47 am
First name: Dominic
Last Name: Regan
City: Canberra
Download the free visual analyser software and tap into your PC mic. You'll get better information as it will show you all the resonant peaks, not just the main top frequency. In fact, when you tuner has trouble working out which frequency the top is it is because it is picking up the main air and/or other peaks.
Dom
PostPosted: Tue Nov 22, 2011 3:52 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
Dom
thank's Dom, oops_sign again have you the web address for free download visual analyser software?
bliss bliss bliss
PostPosted: Tue Nov 22, 2011 5:31 am
First name: Miguel
Last Name: Bernardo
Country: portugal
Don´t know what Dominic is using, but here´s a free spectrum visualiser: http://www.sillanumsoft.org/download.htm
If you have a VST-compatible host, these two are verygood (and free):
voxengo span: http://www.voxengo.com/product/span/
IHA Spectrum analyser: http://www.hoertechnik-audiologie.de/we ... ftware.php
cheers,
Miguel.
PostPosted: Wed Nov 23, 2011 4:03 am
First name: Dominic
Last Name: Regan
City: Canberra
Yep the first one, its called Visual Analyser. 2009 seems less buggy than the latest ones. VA seems the easiest to set up and use.
Check out the threads on the ANZLF here http://www.anzlf.com/viewforum.php?f=33 for tips how to setup and use it. Its amazing what you can do with it.
Dom
PostPosted: Wed Nov 23, 2011 9:48 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I have tried quite a few programs with the capacity to create a FFT frequency graph and I find the Audacity program great and easy to use. That said they all require a bit of experimentation to get comfortable with their features. As for what to actually do with them is a very complex topic. The nice thing with Audacity is I can save the project file and revisit in the future to compare what I am doing to what I have done in the past. Keep records of all parts of the tuning process, and attempt to repeat the results of the instruments that you like the sounds of.
I have a piano hammer that I pot a longer handle on that give a repeatable result.
Fred Tellier
PostPosted: Wed Nov 23, 2011 12:16 pm
First name: Dominic
Last Name: Regan
City: Canberra
Hey Fred, I've not used audacity so I am not sure what it can do but the nice thing about VA is that you can collect data from any number of taps and the program will give you the average value of those taps. So it controls a bit for different tapping techniques etc which is good if you are going to start adjusting anything. Most of us set up to take an average of around 10 taps and then save the spectral data into excel.
Dom
PostPosted: Wed Nov 23, 2011 12:37 pm
First name: Fred
Last Name: Tellier
City: Windsor
They work the same except Auadacity being a recording program allows better keeping of records, I got the same numbers with all of the programs I used, but settled on using the Audacity.
Fred Tellier
PostPosted: Fri Nov 25, 2011 5:28 am
First name: Dominic
Last Name: Regan
City: Canberra
Thanks fred, I'll give it a try.
Dom
PostPosted: Fri Nov 25, 2011 5:47 am
First name: Miguel
Last Name: Bernardo
Country: portugal
Audacity is also VST-compatible, so you can always beef-it-up if you need to. VA also looks very nice, thanks for the ANZLF link Dom!
miguel.
PostPosted: Fri Nov 25, 2011 3:18 pm
First name: David
Last Name: Malicky
Zip/Postal Code: 92111
Here's an updated quick-start for Audacity 1.3.13:
- Install as usual: http://audacity.sourceforge.net
- In Audacity: Edit > Preferences > Devices > Recording > Select your mic > OK.
- Record the taps
- Select the tap(s) signal with the mouse
- Analyze > Plot Spectrum
-- Size: Change to "16384"
-- Axis: Change to "Log Frequency"
-- Drag the right window edge to make it ~full screen width
-- Hover the cursor near the peaks... Audacity will automatically lock onto the peak frequencies! Numbers are in the lower left. I've found it's within 1 Hz of Wavesurfer for the air, top, and back modes.
1.3.13 is a Beta but is working great for me in both Win7 and XP.
My tap-test results and procedure are in this thread... viewtopic.php?f=10101&t=31330
David Malicky
PostPosted: Sun Nov 27, 2011 10:53 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
- Record the taps
Thank's David, I've downloaded Audacity 1.3.13 and I'll try it...
but can the audacity record the tap of plain soundboard, back, side... I read the book of Roger H Siminoff "The Art Of Tap Tuning" he started form plain wood then make some carved or change stiffnes to find the right frequencies or tone...
PostPosted: Mon Nov 28, 2011 1:48 pm
First name: David
Last Name: Malicky
Audacity can record and analyze any sound, but for methods and theory, I'd recommend other resources over that book. See the archives for posts by Alan Carruth -- e.g.:
viewtopic.php?f=10102&t=3860&hilit=+main+air+top+back
viewtopic.php?f=10102&t=11547&hilit=+main+air+top+back
viewtopic.php?f=10101&t=15626&hilit=+main+air+top+back
viewtopic.php?f=10101&t=22181&hilit=main+air+top+back
viewtopic.php?f=10101&t=25425&st=0&sk=t&sd=a&hilit=main+air+top+back&start=25
viewtopic.php?f=10101&t=25664&hilit=main+air+top+back
And see these articles: http://www.pantheonguitars.com/DanaBour ... ticles.htm
And the books by Gore & Gilet, and Somogyi.
David Malicky
PostPosted: Mon Nov 28, 2011 2:43 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
FWIW, Roger Siminoff sells a nicely made tap tuning hammer.
Dave F.
Cambrian Guitars
Users browsing this forum: No registered users and 39 guests
cron
