It is currently Sat Jul 19, 2025 1:42 am
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri May 13, 2011 9:29 am
First name: nigel
Last Name: forster
City: Newcastle upon tyne
Zip/Postal Code: ne12at
Country: england
That's the idea! Though that aint ebony for the neck, it was 1 piece of mahogany that I routed out and reinforced with carbon rods. It looked a bit messy so I smoothed it all out and Dave sprayed it black for it - it looked amazing.
Good news - the book has arrived, get your copy here:
http://www.nkforsterguitars.com/the-book
http://www.ypdbooks.com/photography/366 ... 00333.html
nigel
http://www.theluthierblog.com
PostPosted: Sat May 14, 2011 9:21 pm
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
aha. I wonder if you'd use an extra long truss rod with that design?
PostPosted: Fri May 20, 2011 10:20 pm
First name: nigel
Last Name: forster
Country: england
Latest episode on the blog:
http://nkforsterguitars.blogspot.com/20 ... a-iii.html
nigel
PostPosted: Sat May 21, 2011 1:24 am
First name: nick
City: Vallejo
State: ca
Wow. How did that sound? Or is it real?
PostPosted: Sat May 21, 2011 10:48 pm
First name: nigel
Last Name: forster
Country: england
Yes, it's quite real! Read the blog, and all will become a little more clear. I'll post a youtube clip of it soon so you can hear.
nigel
PostPosted: Tue Jun 07, 2011 12:42 am
First name: nigel
Last Name: forster
Country: england
Here you all are!
http://youtu.be/yPAqxT-ot6Y
http://www.nkforsterguitars.com/nkforst ... _book.html
nigel
PostPosted: Tue Jun 07, 2011 7:57 pm
First name: Big
Last Name: Jim
I like the sound , very nice work ! [:Y:] [clap]
PostPosted: Sat Jun 11, 2011 12:27 am
Be careful. That youtube link is either an accident or malicious. The guitar looks good.
PostPosted: Sat Jun 11, 2011 7:27 am
mikej wrote:
I'm looking at making the bridge like a piano's, using offset steel pins to form the node instead of angling the strings over a nut, that will remove nearly all the downward pressure of the strings on the top..
I would ditch the steel pins as they could very well add too much mass. There's a bit of info out there on "Low pressure bridges" or "Zero Pressure Bridges" for you to check out:
http://books.google.com/books?id=oejZDX ... ar&f=false
http://www.ricktoone.com/2008/10/neutra ... ridge.html
http://patft.uspto.gov/netacgi/nph-Pars ... =7,795,516
Just make sure you don't get sued! :D
PostPosted: Sat Jun 11, 2011 7:59 am
The guitar looks and sounds great! Well done.
PostPosted: Sat Jun 11, 2011 8:03 am
Last Name: williams
City: newark
State: ohio
Zip/Postal Code: 43055
Country: united states
I weighed the bridge with the steel pins and it was less than a standard bridge. Since I won't be relying on it to anchor the strings to the top, it can be much smaller. Have to wait till I get some more funds to start again. I'm pretty confident it's going to work really well.
PostPosted: Sun Jun 12, 2011 6:15 am
First name: nigel
Last Name: forster
Country: england
I just tried the link again after reading that. It works fine.
nigel
PostPosted: Sun Jun 12, 2011 11:21 am
First name: nick
City: Vallejo
State: ca
whew. That guy can play. Thanks for the link there. Sounds quite good, and I noticed how the raised pick guard area appears to act as a hand rest of sorts. I always wondered about raised fretboard extensions and their awkwardness due to being so high above the top.
PostPosted: Sun Jun 12, 2011 11:52 pm
First name: nigel
Last Name: forster
Country: england
Whilst the neck is high relative to the body at the 14th fret, the height at the saddle is only a little higher than normal. Basically its a long neck with a body suspended from the neck/body area, with a bridge "wedged" between the two. The height of the strings above the neck is about the same as a regular steel string acoustic, the finger rest is more or less in the same plane as the neck.
As someone in the UK said recently - Les Paul's "The log" lives again. I hadn't thought of that. I was thinking more in terms of "the cricket bat!"
Makes sense?
nigel
PostPosted: Tue Jun 21, 2011 5:09 am
First name: nigel
Last Name: forster
Country: england
Final episode is up on the blog:
http://nkforsterguitars.blogspot.com/20 ... arlie.html
nigel
PostPosted: Sat Nov 05, 2011 8:06 am
First name: nigel
Last Name: forster
Country: england
Those of you interested in modern guitar design may be inspired by the latest version of my "long neck" archtops. This one is called "Oscar" after my favourite Jazz player, Oscar Moore.
Questions welcome!
You can read more about the guitar and see more pictures on my site:
http://www.nkforsterguitars.com/nkforst ... oscar.html
And you can read about my approach to design here:
nigel
nigel
PostPosted: Sat Nov 05, 2011 8:33 am
City: chicagoland
State: illinois
the entire reason acoustic stringed instruments have a "body" is so that the large, lightweight cavity can resonate when the strings vibrate, thus projecting a louder sound.
i would think this concept seems to defeat that goal: the extended heavy neck/fretboard is effectively a damper over the thin sound box. for the same reason, thick finishes, heavy bracing, large pickguards, and massive bridges are shunned.
it looks fine for an amplified instrument but i would think it must be inferior to traditional designed guitars as far as sound and volume goes.
brilliant people have been tinkering with acoustic instrument designs for thousands of years, and there are excellent, solid, practical reasons that most "traditional" acoustic instruments emerged the way they look through the ages
having said all that, nice work, and i definitely enjoy tinkering around as well
PostPosted: Sun Nov 06, 2011 2:15 am
First name: nigel
Last Name: forster
Country: england
Well, I'm pretty familiar with how guitars work. i've made one or two in me time!
Perhaps if you go through the blog posts "The journey of an idea" you'll see how this design came about, and you may begin to understand how it works and the advantages it has for jazz players. Many jazz players when describing what they want from an archtop often describe qualities which are more in line with what flat tops have. And often in line with qualities electric guitars have too. This design in pretty much in line with those wishes. It really works.
Nigel
nigel
PostPosted: Sun Nov 06, 2011 11:46 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
I missed tose u-tube vids.
All I can say is "WOW"!!!!!
That thing sounds and looks absolutely beautiful!
[clap] [clap] [clap]
PostPosted: Wed Nov 09, 2011 6:08 pm
First name: nick
City: Vallejo
State: ca
i just closed the box on my design inspired by this post. Hope it works. Pics later.
PostPosted: Wed Nov 09, 2011 11:26 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
Nigel--I'm rewriting this post because I think I went off track the first time. It's great to find someone who enjoys the music of Oscar Moore as much as I do. Thanks for helping to keep his memory alive.
P.M. sent.
PostPosted: Thu Nov 10, 2011 1:29 am
First name: nigel
Last Name: forster
Country: england
Great, look forward to it!
nigel
nigel
PostPosted: Wed Nov 16, 2011 8:48 pm
First name: nick
City: Vallejo
State: ca
Okay. Here's a peek. Pinless bridge, 25" truss rod (for basses), "backbone" inside, dovetailed onto tail block. I call it the "suspension bridge", because it reminds me of the bay bridge for some reason (with bridge suspended on the top?), or a bow concept, where the neck and string ends are fully connected. It's a bit like your design, but all underneath the top instead. I 'm thinking this guitar will never need a neck reset, among other things, (if it works)... There is in fact no neck joint really to re set... if that makes sense.
Also I think of post tensioned concrete slabs, used on modern bridges, as a possible direction for bracing a top, where string tension itself adds bracing strength somehow. Being a carpenter I am familiar with this idea for reducing the weight and increasing length of unsupported spans of large slabs, and wonder how it could somehow relate to top construction (but this is not yet worked out). I frequently hear of braces acting as I beams, where a thin, tall shape is strongest, and wonder if other construction concepts could be theoretically relevant too.
PostPosted: Fri Nov 18, 2011 8:00 am
First name: nigel
Last Name: forster
Country: england
Mmmm....seen one ore two variations on this theme over the years. So does it work more like my first guitar in the series - that the sound is produced by sympathetic vibration? What's going on under the soundboard?
nigel
PostPosted: Fri Nov 18, 2011 5:08 pm
I think you did a nice Job on your design and execution. The sound is just as you described.
I wish you the best on your future journeys.
Ken
Users browsing this forum: Michaeldc and 16 guests
