It is currently Wed Aug 20, 2025 3:00 pm
PostPosted: Wed Nov 02, 2011 2:52 pm
Last Name: Sollod
Do you tuck your lower x-braces or not? I have done it both ways... some do, some don't. What's your opinion?
www.swiftcreekguitars.com
PostPosted: Wed Nov 02, 2011 3:32 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
There would appear to be no valid reason to do so, and several reasons not to do so.
PostPosted: Wed Nov 02, 2011 3:38 pm
First name: Darryl
Last Name: Young
State: AR
I don't. Can't say if it makes a big difference or not, but I don't. My theory is keep the perimeter of the lower bout as free to move as possible.
PostPosted: Wed Nov 02, 2011 3:42 pm
First name: Tom
Last Name: West
State: Nova Scotia
Steve: I tuck the X braces at the bottom. The main reason is that I use them as registeration points when gluing the top. Same with the upper X and the UTB. I do take the end down to about .060 or so. If you leave the tucked ends heavy you can tighten up the top too much in my opinion.Some folks don't tuck the lower X and taper the ends down to nothing to help prevent the brace from peeling in case of a hard knock. I see nothing wrong with that,so it's pay your money and take your chances with whatever way you prefer.
Tom
PostPosted: Wed Nov 02, 2011 4:14 pm
Tucking, or not tucking, the lower main braces, in addition to the tone bars, is a tool to control tone.
It is another technique that the builder can use to shape the tone he wants.
As an example, tucking the lower braces and tonebars can help a dreadnaught in the treble department.
PostPosted: Wed Nov 02, 2011 5:11 pm
I've done both, it's a very small piece of the puzzle IMO tucking can be rectified in other ways to get the same result as untucked....
PostPosted: Wed Nov 02, 2011 6:41 pm
I have done it both ways, and currently prefer not to tuck the lower X. I seem to have better results closing the ring+ mode.
Chuck
PostPosted: Wed Nov 02, 2011 7:19 pm
It depends on the guitar for me but usually tapered to nothing before the linings.
Burton
Brookline, MA.
PostPosted: Wed Nov 02, 2011 8:15 pm
Would you care to elaborate on this? Why is it Ok to tuck in other braces but not the X? And what are the "several reasons not to do so"?
I personnally tuck in the bottom X, but I may be wrong doing so, which is why I'd like to know more about what you have in mind.
Alain Moisan
(Now building just for fun!)
PostPosted: Wed Nov 02, 2011 8:47 pm
Untucking braces and fleathering them to nothing near the lining allows the plate to move much more as a unit rather than having a brace in the lower bout coupled fast to the rims to stop or slow the vibration of that area of the plate, it is my opinion that this allows for a bit more sustain versus tucked braces. Think about a drum skin, hit it with a drum stick and it will vibrate to some oscelation, uniform (because it is not impeded by anything but the tightness of the skin), now hold one drum stick on the skin right at the edge of the rim with a skosh overhand into the open area of the drum, it will damp the skin somewhat... Tried this with a drummer friend of mine and it was an interesting, simple experiment. I of course could be off base here, but that's my thinking.
PostPosted: Thu Nov 03, 2011 8:02 am
It depends if you want a tight top or loose one. I build according to a particular plan for that guitar , so i'll do both to get the results i want. Same for the braceing.
PostPosted: Thu Nov 03, 2011 8:50 am
Clearly good sounding guitars can be made both ways. I don't tuck the lower X-brace arms just because it sort of suits my image of how the (my) guitars work.
PostPosted: Thu Nov 03, 2011 9:39 pm
I definitely
dont do it on small guitars
PostPosted: Fri Nov 04, 2011 7:35 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
I don't tuck anything in the lower bout, but tuck the upper X, and transverse brace.
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
Users browsing this forum: Brad Goodman and 29 guests
