It is currently Fri May 15, 2026 9:37 pm
 Post subject: Pumice Stone
PostPosted: Fri Oct 28, 2011 10:29 am
Last Name: Charnock
Country: UK
Anyone using pumice stone as a pore filler ?
Good - Bad ??
 Post subject: Re: Pumice Stone
PostPosted: Fri Oct 28, 2011 10:33 am
It's labor intensive, but it works. It does tend to sink back a little over time.
PostPosted: Fri Oct 28, 2011 10:52 am
PostPosted: Fri Oct 28, 2011 11:53 am
Geez... used to use it buff out finishes, but never considered using it for filler.
PostPosted: Fri Oct 28, 2011 12:19 pm
I did for the first time on my recent Flamenco build. Only the rose wood head plate so it wasn't too intensive for me :) But yes it worked quite well, not sure I'd want to do a whole guitar. I think I am going to try egg whites next time.
PostPosted: Fri Oct 28, 2011 12:38 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I used to use it. Never liked it.
Now I use drywall compound mixed with dye. Much easier
PostPosted: Fri Oct 28, 2011 4:42 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
It's all I ever use. I love it.
PostPosted: Fri Oct 28, 2011 5:21 pm
Last Name: Kincheloe
I love it. Time taken is quite variable so far, but I think it will be not too bad with a bit more experience. I tried the LMI micro bead filler, but it was at least as much time and effort as pumice to mash it all in and carefully scrape back to wood twice, and even then I ended up losing a little thickness and opening some new pores by the time I got the splotchy color mostly cleared off the wood surface. Pumice gets you a perfectly color matched filler, and it can always be re-softened and moved around the surface to level it out without having to carefully scrape/sand to bare wood.
The pumice leveling operation is also dual purpose. Since pumice is an abrasive, you can also skip the finer sandpaper grits. Or do what I did, and leave it at a scraper finish. The pumice polished it out quite beautifully. The neck I sand to 1500 though, as it's easier to grind up slurry from open areas and push it into tight spots, which means the tight spots don't get the abrasive treatment.
PostPosted: Fri Oct 28, 2011 8:52 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
I'm just about to use pumice.
My understanding is that it doesn't actually fill the pores,
but uses some of the spit coat finishes to do that.
Oh, I might add that I think pumice is used solely in french polishing,
cuz da alcohol melts the finish in there.
Users browsing this forum: Facebook [Bot] and 93 guests
