It is currently Wed Aug 06, 2025 5:53 am
Post new topic Reply to topic  [ 50 posts ]  Go to page 1, 2  Next
PostPosted: Wed Oct 19, 2011 7:21 am
First name: Big
Last Name: Jim
Well guys its that time again , we have had almost a full month to get our best work done. That being said , we alllllll know what happens in that same time frame ! laughing6-hehe
Usally I lead the charge , However I have done very little this month in the shop in the way of luthrie . So I will leave it up to someone else to run with it !
SO Who is gonna recieve the coveted " Doofus Of The Month "
And get to Kiss our presenter, the lovely Nichole Kidman !
Almost make a guy wanna mess up huh !
PostPosted: Wed Oct 19, 2011 7:36 am
If by Doofus of the month you mean doing stupid things and making dumb mistakes then I win hands down. Sometimes I want to smash everything and give up [headinwall] [headinwall] [headinwall]
After boasting in the quarter century thread about building 60 instruments and then going on in another thread about books that I have "most of the things in my head by now" I go to glue on the bridge of my freshly french polished flemenco guitar and realize that I marked the bridge out to the wrong scale length. [headinwall] [headinwall] [headinwall]
Well at least I can say I will now have some experience repairing a FP finish.
PostPosted: Wed Oct 19, 2011 8:26 am
First name: Big
Last Name: Jim
Wow , ummm I think Nichole is puckern up Already ! laughing6-hehe laughing6-hehe
PostPosted: Wed Oct 19, 2011 7:36 pm
My wife even knows I've always had a thing for Nichole Kidman. :P
PostPosted: Wed Oct 19, 2011 7:54 pm
I'll take a shot at it. I was doing my first Z-Poxy pore fill, all was going well.
Mixed my Resin and hardener, moved my supplies to the shelf and had at it.
The next day when I went to the shop I realized my mixing stick had fallen to the shelf
below, yep, it landed right on my newly carved neck. It was bonded nicely and sticking straight off to the side.
So then I decide I'll just pop it off, bad idea, it took a nice piece of the neck with it.
A real comedy of errors.
Scott
PostPosted: Wed Oct 19, 2011 9:39 pm
Last Name: Kincheloe
I mentioned this in another thread, but here it is again.
Fingerboard side dots. Knowing good and well that it's a common place to make stupid mistakes, I thought long and hard and checked repeatedly before drilling them. But what I didn't think of is the fact that I hadn't radiused the fingerboard yet, and that doing so would reduce the binding height. Yep, I centered them for the full height binding, and radiusing will most likely cut into the tops of the dots. I'd just call it a spontaneous feature if the dots were more precisely centered vertically, but as it is, some of them will wrap around the binding a bit, and some will only be visible from the side, and it will look horrible. If only I'd bought that brad point drill bit before doing this one...
I had planned on gluing down the fingerboard extension, leveling the board, and then radiusing. But in light of this new situation, I think I'll radius first, at least close to final, and see if it actually looks as bad as I think it will. The neck fit is pretty good, so any leveling of 14th fret hump will be very minor anyway. If the post-radius dots do turn out ugly, I think I'll replace them with vertical strips of shell. Might not be able to get them 100% smoothly blended into the neck, but less risk of catastrophe than chiseling off the whole binding strip.
PostPosted: Thu Oct 20, 2011 5:19 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I don't know if this counts...
Slotted a Macassar Ebony fretboard using another guitar as a template... ended up getting it slightly off.
Oh well, I'll fill the slot with veneer and flip it over, and try again...
Typhoon Guitars
PostPosted: Thu Oct 20, 2011 10:14 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I would recommend not using another guitar as a template, too easy to mess up. Either calculate and measure (very carefully [several times]) or use w-fret (available from MIMF.com). I used to do the former, but once I was convinced I could do it I switched to the latter.
Bryan Bear PMoMC
PostPosted: Thu Oct 20, 2011 10:18 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I thought I was at the very least, a qualifier.
viewtopic.php?f=10101&t=33829&hilit=LR+Baggs
Mike pizza
PostPosted: Thu Oct 20, 2011 5:23 pm
First name: Jim
Last Name: Kirby
Heh, you could have glued it on backwards. (Gotta love the long open time of fish glue [:Y:] )
Jim Kirby
kirby@udel.edu
PostPosted: Sat Oct 22, 2011 6:01 pm
First name: Patrick
Last Name: Hanna
State: Missouri
I spent a couple of days meticulously laying up laminations of walnut and maple veneer strips and gluing them to a walnut stick 1.25" wide and about 35" long. I wanted to cut them into wedges that I could glue to the bottom of a banjo rim (then rout the whole assembly flush to the inside and outside of the rim and then turn it to a nice rounded surface on my lathe). I was doing just great until I brought my long-beamed protractor into play laying out the angles I needed to cut. I didn't bother to notice that my long beamed protractor doesn't register zero along the bottom edge. In fact, it registers zero about a quarter inch up from the bottom edge.
Thus, it is essentially worthless to me for measuring angles like this (although it'll work just fine as a long beamed sliding bevel). I cut a whole bunch of real nice little walnut/maple/walnut Christmas tree ornaments this afternoon. Maybe even dangle earrings for a very flamboyant lady! And...gee...they fit real nice into a circle of about 10-inches diameter--not the diameter of the banjo rim. I didn't even start swearing. My wife and I just had a good laugh over it. Live and learn.
PostPosted: Sun Oct 23, 2011 6:41 pm
First name: Big
Last Name: Jim
laughing6-hehe laughing6-hehe I go away for a few days and the doofus moves come pouring outa the wood work ! ( pun intended )
I will be back in the shop starting this week . Im sure I will have a moment thats postable soon ! duh
PostPosted: Sun Oct 23, 2011 7:09 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I am starting a shop at the moment...
you know the good thing about making guitars as opposed to repairing or restoring them, is that if you doofus on a build, you can always hide or replace the offending part, but when you are repairing someone's guitar, especially when woodworking is involved, a doofus is a catastrophe. You can't simply replace the offending part especially if they're no longer made, that and you have to explain to the owner why you messed up...
Typhoon Guitars
PostPosted: Mon Oct 24, 2011 7:00 am
First name: Jim
Last Name: Kirby
Time for a late entry?
I was looking forward to practicing purfling miters on a 3 line purfling, when dang, that router just kept on goin'
Truly a painful moment. I'd try to piece something together, but I'm afraid I wouldn't be able to hide it in the Palo Escrito the way I would in Indian.
How do you think it will look if I keep the mitering on the backstrip and binding joint, but do continuous purfling lines on both sides of the end strip? Or should I just forget the miters everywhere?
Jim Kirby
kirby@udel.edu
PostPosted: Mon Oct 24, 2011 7:25 am
I've been too busy with other stuff to get much guitar work done recently, so I was excited to get back to my baritone. I was doing some final thicknessing of the top. I run thin things like tops through the drum sander on a carrier board with a little ledge glued to it as a backstop/pusher. Well, something slipped and I realized the top was sitting on top of that ledge in the back. I grabbed the wheel to raise the drum and gave it a spin. Unfortunately, the direction of that wheel has always been counter intuitive to me. I cranked the drum down into the top, dug a groove into it and then watched Shane's beautiful lutz shoot out of the drum sander and slam into my workbench.
Tonight, I'll be bending some padauk sides for a parlor I've been meaning to build recently.
Mike Lindstrom
PostPosted: Mon Oct 24, 2011 7:37 am
First name: Trevor
Last Name: Gore
City: Sydney
Jim, glue on the bindings (no mitres with the butt strip) then re-do the butt strip with mitres using the technique shown in "the book". (It's easier than it looks).
http://www.goreguitars.com.au
PostPosted: Mon Oct 24, 2011 8:08 am
First name: Big
Last Name: Jim
:shock:
Been there , done that , feel your pain .
PostPosted: Mon Oct 24, 2011 8:12 am
First name: Stuart
Last Name: Gort
Nichole?
Really?
Man...I wish I was more stupider.
StuMusic
PostPosted: Mon Oct 24, 2011 8:23 am
First name: Big
Last Name: Jim
Zlurgh wrote:
Nichole?
Really?
laughing6-hehe laughing6-hehe laughing6-hehe laughing6-hehe
Ya know whats bestest part of this for me ?? I MIGHT get to call Fillipo a DOOFUS !! laughing6-hehe laughing6-hehe
PostPosted: Mon Oct 24, 2011 8:27 am
First name: Tony
Last Name: C
City: Brooklyn
Zlurgh wrote:
Nichole?
Really?
laughing6-hehe laughing6-hehe laughing6-hehe laughing6-hehe laughing6-hehe
I think, for the most part, more stupider = more happier. Or maybe more happierer? Either way, you will probably smile more.
http://www.CostaGuitars.com
PMoMC
PostPosted: Mon Oct 24, 2011 8:33 am
First name: Stuart
Last Name: Gort
WudWerkr wrote:
I MIGHT get to call Fillipo a DOOFUS!
Good luck with that. That mans' accidents are clever.
StuMusic
PostPosted: Mon Oct 24, 2011 10:50 am
First name: Jim
Last Name: Kirby
Oh, good catch, Trevor! That just hadn't occurred to me - too caught up in the pain. I've even done a guitar that way before. Thanks!
(Now, I should remember to chisel out the existing butt strip before gluing on the top bindings ...)
Jim Kirby
kirby@udel.edu
PostPosted: Mon Oct 24, 2011 9:14 pm
Well, I'm not too terribly ashamed to admit I've done this, oh, three times now, because I've recovered fairly well from two of the three by piecing them together so that it's fairly unnoticable. The other time was on the back binding, and I just did as you mentioned -- just kept the binding & purfling continuous, with the tail wedge butted up to it. Still mitered the top, and it looks fine. No worries!
Mountain Song Guitars www.mountainsongguitars.com
PostPosted: Wed Oct 26, 2011 7:27 am
First name: Jim
Last Name: Kirby
Thanks Ken,
I was so caught up in the adrenalin rush of the initial mistake that I just wasn't thinking forward to the fix. I don't normally try to mitre on the inside of a closed pocket the way Trevor describes, but I then realized that, once I've chiseled the butt strip out, I just need to replace it with a new one that over-hangs a little and do my mitres the way I normally would. Either way works. I hereby disqualify my own entry for having insufficient lack-of-recoverability.
Jim Kirby
kirby@udel.edu
PostPosted: Wed Oct 26, 2011 7:51 am
First name: Big
Last Name: Jim
Jim Kirby wrote:
Thanks Ken,
Sorry Jim no take backs !! laughing6-hehe laughing6-hehe
Users browsing this forum: Bing [Bot], ChuckB and 20 guests
