It is currently Fri Jul 18, 2025 8:33 am
 Post subject: Purfling ledge question
PostPosted: Mon Oct 03, 2011 6:57 pm
Well, I mistakenly cut the top purfling ledge a bit too deep on a guitar body this afternoon (the adjustment ring on the router must have been misaligned, then snapped into place as I began cutting?). It cut all the way through the top, so the only thing that's holding the top in place right now is about 2/3 the width of the kerfed lining-to-top glue joint.
I can source some taller purfling and fit it to this existing ledge. My gut feeling is that with a good purfling joint, and with binding in place, everything will be fine when all's said and done.
But I still can't help wondering if the integrity of the top/guitar will be jeopardized.
Anyone have any opinions or suggestions to offer? Anyone been there/done that?
TIA,
Ken Mitchell
Durham, NC
PostPosted: Mon Oct 03, 2011 7:07 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
No problem. Mine end up like that all the time.
PostPosted: Mon Oct 03, 2011 7:11 pm
Once it's all glued together, it should be fine. I have gone through where my tops were thinned at the tail, with only a few mm left clinging to the dentellones.
PostPosted: Mon Oct 03, 2011 7:42 pm
OK, I will go ahead. Thanks guys!
Ken Mitchell
Durham, NC
PostPosted: Mon Oct 03, 2011 9:08 pm
First name: Tom
Last Name: West
State: Nova Scotia
I don't feel safe unless I have at least one third the thickness of the top under the purfling. I think you guys live dangerously.....!!!
Tom
PostPosted: Tue Oct 04, 2011 6:14 am
Tom, I feel the same way, and would never cut all the way through the top intentionally, but given the alternative of pulling off this top and starting over... weeeelll... I'm going to live dangerously. :(
I'll feel much better when the purfling and binding are in place!
Ken Mitchell
Durham, NC
PostPosted: Tue Oct 04, 2011 7:36 am
Were you using a PC 310 laminate trimmer? I've had that happen where the adjustment ring was not full seated in the spring clamps and it dropped down a fraction halfway through the cut. I always triple check that now.
PostPosted: Wed Oct 05, 2011 6:32 pm
Touche! That's exactly the model, and it's exactly what I imagined happened. There's nothing else that could explain what occurred. (And I 'thought' that I had checked EVERYTHING).
Ken Mitchell
Durham, NC
Users browsing this forum: DennisK, Ken Lewis, Woodie G and 19 guests
