It is currently Fri Aug 01, 2025 1:54 am
PostPosted: Thu Aug 11, 2011 11:50 am
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
Now I have some questions. :)
I got the sandpaper to go with the dishes. Is it ok to leave the paper on through all the building steps? I don't have to take it off in between shaping the braces and gluing them on, do I?
Hmm. I guess that's the only question I have for now. ;)
Thanks in advance,
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Thu Aug 11, 2011 12:02 pm
First name: Tony
Last Name: C
City: Brooklyn
Phillip,
You want to leave the paper on or it will lose its tack and will slide around when you "drive the bus" in the future. When you have the back in the dish and you are going to glue on braces, you should cover the sand paper with some news paper or anything to protect the plate from getting scratches on it while you glue up your braces.
Tony
http://www.CostaGuitars.com
PMoMC
PostPosted: Thu Aug 11, 2011 12:06 pm
Perhaps it's better to put something between the sandpaper and the top when gluing in the braces with the go-bars as you may likely mark/scratch the top itself.
I've seen it suggested to keep and use the backing paper for the PSA sandpaper disc supplied as protection for the top, but a piece of plastic sheeting or something similar should do just as well.
PostPosted: Thu Aug 11, 2011 12:27 pm
Last Name: Wood
City: Chester Springs
State: PA
Zip/Postal Code: 19425
I keep a big roll of heavy brown craft paper from Lowe's for this and other things around the shop. It's very handy.
Chris.
PostPosted: Thu Aug 11, 2011 12:28 pm
First name: Phillip
Last Name: Patton
City: Yoder
Thanks, guys! That sounds good. If I think of any more questions as I go along, I'll post them here.
Regards,
Phillip Patton
PostPosted: Thu Aug 11, 2011 1:21 pm
Newspaper works fine, too. If anybody remembers what a Newspaper is...
PostPosted: Thu Aug 11, 2011 7:34 pm
This is my recommendation Phillip, just save the backing paper from the sanding disc. If you loose it or threw it out then craft and or news paper works well also. Hope they work well for you!
PostPosted: Sat Aug 13, 2011 2:50 pm
I like to use plastic coated freezer paper for gluing and finishing. The plastic coating keeps glue or finish from soaking through and messing up whatever is underneath. I put the coated side on the bottom.
PostPosted: Mon Aug 15, 2011 5:45 pm
Does anyone have the info for shane and where to get the discs? You can PM me, post here, or send to gustav.buhund@gmail.com. Thanks in advance!
Eric
PostPosted: Mon Aug 15, 2011 9:07 pm
First name: Phillip
Last Name: Patton
City: Yoder
Eric
There's a menu on the left; scroll down and you'll see the dishes listed there:
http://highmountaintonewood.com/id27.htm
Regards,
Phillip Patton
