It is currently Wed Aug 06, 2025 8:10 am
 Post subject: Nut slot too deep
PostPosted: Thu Aug 11, 2011 2:06 pm
Is there a way of fixing a nut slot that I've cut too deep?
I'd prefer not to have to start again since the nut fits really well.
 Post subject: Re: Nut slot too deep
PostPosted: Thu Aug 11, 2011 2:10 pm
First name: Tom
Last Name: West
State: Nova Scotia
Bone dust and CA in the offending slot or a shim under the nut. I use the first but the latter is not the best.
PostPosted: Thu Aug 11, 2011 2:45 pm
I use one of my needle files, the one with the "knife edge" and file the slot to a tight wedge, below the level of the string slot.
Make a bone wedge and CA glue it in.
When it's set, cut off the top of the bone wedge and file it level with the rest of the nut.
Re-cut the slot, and try not to go too deep this time?
PostPosted: Thu Aug 11, 2011 3:46 pm
That is excellent!
I've done the bone dust and CA thing, and was always disappointed even if it worked.
Next time - I'll wedge it!
PostPosted: Thu Aug 11, 2011 6:16 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Very interesting responses. I've read many times that baking soda and CA have the same effect, but have never had to try it. Since none of the respondents have recommended that method, I'm starting to think maybe it was bogus advice. What do you guys say? I'm sure there are lots of lurkers who read the same things I read, and they would like to know, too.
PostPosted: Thu Aug 11, 2011 6:31 pm
I have tried the CA and baking soda, and it does work. Not pretty, but it works.
PostPosted: Thu Aug 11, 2011 7:07 pm
First name: Tom
Last Name: West
State: Nova Scotia
I've tried baking soda and CA and had a bit of a problem with corrosion on the string at the nut. Have not used it since.
Tom
PostPosted: Thu Aug 11, 2011 7:55 pm
Probably different with me, since I make classical guitars, and the string is silver plated. I didn't have that problem.
PostPosted: Thu Aug 11, 2011 9:56 pm
Baking soda and CA - did it, not happy with it.
Used talcum powder once - it was alright.
Better to not go too deeply (natch!), or try the wedge method IMO.
PostPosted: Fri Aug 12, 2011 1:02 am
I did a repair with baking soda and CA recently. It worked but the baking soda was a little too course and it turned slightly green.
PostPosted: Fri Aug 12, 2011 2:06 am
Last Name: Schreiner
City: Miami
State: FL
Zip/Postal Code: 33183
I CA a thin slice of a white business card into the slot and wedge it in with a sharp knife. The slice should be very wet with CA. Then I let it dry and recut the slot. The tone seems unaffected by this fix. I cut alot of nuts and use this method rarely but it works for me.
Michael
PostPosted: Fri Aug 12, 2011 4:14 am
Make a new nut.
PostPosted: Fri Aug 12, 2011 9:48 am
I agree with Tony.
A new guitar, or "my" guitar gets a new nut.
All the rest is a repair for those who do not wish to pay.
PostPosted: Fri Aug 12, 2011 4:22 pm
First name: Danny
Last Name: Vincent
LMI sells .020 bone shim stock. I haven't used it but I'm sure would be another option.
PostPosted: Fri Aug 12, 2011 6:12 pm
Bone dust and CA. I use some electrical tape to dam up the slot, keeps the CA from running wild. Let it set . Baking soda acts as an accelerator for CA too.
PostPosted: Fri Aug 12, 2011 7:05 pm
Last Name: Wood
City: Chester Springs
State: PA
Zip/Postal Code: 19425
I make a new nut when that happens.
Chris.
PostPosted: Sat Aug 13, 2011 8:55 am
First name: duh
Last Name: Padma
Slots in nuts pfft
Just another really good reason for the sacred Zero fret and a string holder. End of problem. Well not on this instrument.
As for this guitar, quick and dirty...anything you can glue in, that stays put and can be filed down. Me flavour Michaels saturated card stock.
Best fix is replacement, but look on the bright side...it ain't as severe as a hip or brain replacement. laughing6-hehe
Me, me got tired of replacing, got the big idea and grocked the wisdom of the Holy Zero Fret 10 years ago. Me haven't made a nut since.
Nuts...pain in the slot where the sun don't shine.
Nuts pfft
blessings duh Padma
PostPosted: Tue Aug 16, 2011 11:51 pm
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
CA glue and baking soda work really well I've found. Just build the slot a tad higher, refile it, and then touch it with a bit of graphite or something to give it some lubrication..or you could skip lubricating it and be just fine too.
Users browsing this forum: jfrench and 40 guests
