It is currently Mon Aug 18, 2025 2:03 am
PostPosted: Mon Jul 18, 2011 2:08 pm
Last Name: Garrish
I'm not sure if it's that the non-French-half of my heritage did it or the fumes, but it brings just a little tear to my eye ;) . I think those ground surfaces are smoother than 200 grit, too!
http://www.galwayindependent.com/motoring/motoring/irish-made-henkel-superglue-enters-guinness-book-of-records-/
Bob Garrish
PostPosted: Mon Jul 18, 2011 2:13 pm
I thought about doing an all superglue build just to see.
I'm sure someone out there already has.
What were the results?
Old growth, shmold growth!
PostPosted: Mon Jul 18, 2011 2:16 pm
Last Name: Garrish
A guy I know built a Les Paul completely with superglue in the early eighties, and he still plays it. So it's stuck together about as long as I have at least!
Bob Garrish
PostPosted: Mon Jul 18, 2011 3:31 pm
Hi,
I'm sure CA glue would be really strong to make a full guitar, but I don't think I'll try this someday.
And some steps of the building could be really hard to deal with, like soundboard or back gluing, don't you think?
PostPosted: Mon Jul 18, 2011 3:44 pm
Kevin Gallagher (RIP) built an entire guitar out of CA about 15 years ago. Still in use according to the same asked questions about 3 years ago.
There are different viscosities of CA which take longer to set up, this would help with larger glue ups like back and top to rims.
PostPosted: Mon Jul 18, 2011 3:47 pm
I don't see why you couldn't use CA for a solidbody, but if you wanted to take it apart for a neck or fingerboard repair, cleanup before reassembly might be problematic.
PostPosted: Mon Jul 18, 2011 4:08 pm
First name: David
Last Name: Malicky
Zip/Postal Code: 92111
Our student project guitars are almost entirely superglue bonded. The main exception is the back-to-siding joint, where we need a slow cure and use wood glue. If the joint is prepped and set properly it's stronger than spruce. It does lose strength in impact (though that's handy for rework). Here's our low-tech method for attaching siding to the top without a mold (gluing starts at 1:18):
http://www.youtube.com/user/USanDiegoMe ... LyDZgdwkNo
I think the fact that it works despite the quick and crude clamping is a testament to the CA.
David Malicky
PostPosted: Tue Jul 19, 2011 12:22 am
Hi,
What kind of veneer is the long white strip you use for sides on the video?
It's strange!
PostPosted: Tue Jul 19, 2011 3:42 am
First name: Daniel
Last Name: Wotton
City: Old Toongabbie
Zip/Postal Code: 2146
The glue is not that strong. BUT that sticker that they put on the side is AMAZING laughing6-hehe laughing6-hehe laughing6-hehe
PostPosted: Tue Jul 19, 2011 8:21 am
Over the last 20 years of building guitars I've been using more and more CA as I trust it. It really is nice to speed up some operations.
PostPosted: Tue Jul 19, 2011 12:15 pm
Last Name: Garrish
Now it all makes sense!
(big image at link, and I didn't want to byte bomb users with slow connections)
http://axewar.com/axedetails.php5?pid=919
Bob Garrish
PostPosted: Tue Jul 19, 2011 12:32 pm
First name: David
Last Name: Malicky
quentinjazz wrote:
Hi,
It's strange!
Yes, it is strange! It's 2 layers of Baltic Birch plywood, made by planing/sanding off 1 layer of 1/8" (3 ply) BB. Final thickness is about .070". Once down to 2 layers it's flexible enough to fit the profile. Lately, we soak it in water and let dry in a template to help it assume the curves before gluing... easier to assemble.
David Malicky
PostPosted: Tue Jul 19, 2011 12:50 pm
ok thanks,
Is it because you want to show the whole building step, or do you sometimes bend "standard" sides on the iron in your course, too?
PostPosted: Tue Jul 19, 2011 12:57 pm
Hey David, I didn't see any videos where you are bracing the top. Do you have those up and I just didn't see them?
PostPosted: Tue Jul 19, 2011 3:02 pm
I don't see a guitar build video either?
PostPosted: Wed Jul 20, 2011 1:46 pm
First name: David
Last Name: Malicky
quentinjazz--the student project guitars are all done as in the video (I needed to simplify the process to fit in the classtime available... the single 60" side also helps).
theguitarwhisperer--yeah, I still need to make those, hopefully by Sept 1! Last Fall I taught the first third of the project with written and in-person instruction, then converted to video.
jfmckenna--I'm not quite sure what you meant... here are all the vids so far: http://www.youtube.com/user/USanDiegoMe ... ature=mhee
Sorry if this is hijacking the thread--I can start a new one if helpful.
David Malicky
PostPosted: Wed Jul 20, 2011 2:06 pm
Oh woops I see now, thought it was referring to the original poster...
Users browsing this forum: TimAllen and 20 guests
