It is currently Sat Aug 02, 2025 5:41 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jun 24, 2011 1:39 pm
Last Name: Livermore
State: Minnesota
But Howard, that's the way Martin does it. So it must be good!
Regardless, I got the pattern to close up and it rings like a gong. Here's where it all ended up.
PostPosted: Fri Jun 24, 2011 2:07 pm
I look forward to hearing about how that sounds when it's done.
PostPosted: Fri Jun 24, 2011 2:12 pm
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
why angle the finger braces (as in your original pic)? Though relatively new I would tend to trust the lower brace method of Martin guitars and leave it at that. Why re-invent the wheel? Just a thought.
PostPosted: Sat Jun 25, 2011 2:01 pm
Country: Romania
What is the ring frequency? That is some extreme lower X carving.
Build log
PostPosted: Sat Jun 25, 2011 3:55 pm
State: Minnesota
She rings at 248hz
Right smack dab in the middle of my target zone.
PostPosted: Sat Jun 25, 2011 9:32 pm
First name: Darryl
Last Name: Young
State: AR
Thanks for these tips!
Blanchard wrote:
Dave Livermore wrote:
..... Trouble with that build was it had asymmetrical (traditionaly lower legs) bracing which made closing the ring on chladni tests a real bear.
Imagine a line joining the points where the lower X-brace arms intersect the edge of the top. Any bracing below that line will tend to open the ring+ near the finger braces. If the bracing is to the right of center, the ring+ will open on the left side. With a typical Martin style bracing pattern, the lower ends of both tone bars extend below the line on the bass side and usually cause the ring+ to open on the treble side. The lower brace is especially influential. If you taper the lower end of that brace off, the ring+ will close a lot easier. Leaving a scallop peak on the lower end of the lower brace will cause serious problems with the ring+.
On my guitars, I solved all this by running the tone bars horizontally, straight across the grain. One is behind the bridge plate and the other connects the lower ends of the X braces. Yes, my bracing looks a lot like the Larrivee pattern.
The double X has the potential to open the ring+ on both sides unless you you taper off the lower ends of the braces significantly. Otherwise I think it is a good pattern. Al Carruth has built some great sounding guitars with it.
Mark
PostPosted: Sat Jun 25, 2011 9:41 pm
State: Minnesota
That single tip was what made it all happen.
I had given up, torn all the equipment from the shop, re-read that post, set everything back up and tried shaving everything below that imaginary point, and voila, the ring was closed. Very cool tip.
