It is currently Thu Aug 21, 2025 5:26 pm
PostPosted: Mon Jun 20, 2011 2:50 pm
I'm installing a pickup and the instructions say to put the battery pack somewhere flat and out of sight.
Where do you guys usually put it?
It's a Shatten pickup I'm installing.
Neil
PostPosted: Mon Jun 20, 2011 3:00 pm
bass side of the neck block, attached on the guitar's side, when using the self adhesive/velcro type
PostPosted: Mon Jun 20, 2011 4:28 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I usually put them underneath the fingerboard. You can reach inside through the soundhole with a couple fingers and pull the battery out to change without even loosening the strings.
PostPosted: Tue Jun 21, 2011 5:51 am
Battery box makes a neat and easy to change solution too, without having to loosen strings. Mine is near the tail block.
PostPosted: Thu Jun 23, 2011 12:48 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
I do the same as Colin.
I get them from Stew-Mac.
Mc
Mike Collins
PostPosted: Thu Jun 23, 2011 12:56 pm
First name: Darryl
Last Name: Young
State: AR
I was curious if anyone maounted the battery pack near the tail block to help balance a neck heavy guitar. Maybe the batteries are light enough that this isn't an issue, not sure.
PostPosted: Thu Jun 23, 2011 5:48 pm
Every little bit helps....
