It is currently Sun Aug 03, 2025 4:22 am
 Post subject: Plate jointing jig
PostPosted: Sat Jun 18, 2011 12:18 am
What do you guys use on your plate jointing jigs to prevent the plates sticking to the jig? Wax, tape, wax paper, melamine?
Thanks in advance!
 Post subject: Re: Plate jointing jig
PostPosted: Sat Jun 18, 2011 12:27 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I use the old rope & wedge method & (after trying candle wax) have put clear plastic packing tape on the "sticks". Works like a charm.
PostPosted: Sat Jun 18, 2011 12:48 am
in my joining jig I use a strip or two of shipping tape down the center. It's been there for the past 50 guitars or so and working just fine.
PostPosted: Sat Jun 18, 2011 3:03 am
Hi Tony, what type of jig do you use?
On my previous one(Cumpiano style jig, with wedges) I used a melamine covered backing plate, it worked fine. I now use this set-up, which I like better. For one thing, it allows better air circulation.
Lots of folks are probably going to tell you to use masking tape to clamp the plates, which makes a dedicated jig redundant.
PostPosted: Sat Jun 18, 2011 3:24 am
Thanks for the input guys.
Arnt, I just have a simple rope and wedge lattice gizmo. This is my new one (actually I have a few) to replace the old one. Whats cool about it is that I made a special base for it to sit on while I am working. Once glued up you can swap it out for another and keep working. Tape works fine too, but I just feel better using something more secure and this works well (esp for the long plates I join). Your setup also looks sweet (and less time to make!).
Here I have the jig faces taped off using masking tape - which is OK, but you guys always have the best ideas!
PostPosted: Sat Jun 18, 2011 6:05 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Tony, I have the same jig. I went to lowes and bought a couple strips of that plastic flooring material that looks like wood. It has a very sticky backing. I cut it in to narrow strips and put it on anything that came into contact with the wood being joined.
PostPosted: Sat Jun 18, 2011 6:10 am
Cleat plastic packing tape for me too.
PostPosted: Sat Jun 18, 2011 6:20 am
First name: Big
Last Name: Jim
Wax Paper here , works great , cheap , easy .
PostPosted: Sat Jun 18, 2011 7:01 am
Tony, I just use parchment paper. Works good and has less wax than wax paper. ;)
PostPosted: Sat Jun 18, 2011 7:36 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Wax paper works for me, I use the tape method with hide glue to join then press between a couple plywood boards with wax paper over the joint overnight.
Fred
Fred Tellier
PostPosted: Sat Jun 18, 2011 10:22 am
I use a simplified rope and wedge thingy with packing tape to keep it from sticking.
Someday I might pimp it out with small sailboat cleats to secure the rope. 8-)
PostPosted: Sat Jun 18, 2011 1:19 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
The admonishment avoid wax paper is a good one. Though, I am surprised to hear that parchment contains silicone. Really? The kind used for cooking?
PostPosted: Sat Jun 18, 2011 2:21 pm
I just use news paper. And as far as a clamping jig I simply use masking tape stretched perpendicular to and across the joint.
