It is currently Thu Aug 14, 2025 7:59 am
PostPosted: Mon May 23, 2011 6:24 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
What exactly is radial purfuling? Did a search of the forum and didn't get any hits.
Brian
PostPosted: Mon May 23, 2011 6:48 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
So called "radial purfling" or "marquetry edge banding" has been used for hunderds of years as far as I can tell. I don't think it is possible to reliably attribute its use to lutherie to any one person in particular.
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Mon May 23, 2011 8:37 pm
The first I remember seeing it was on Jim Olsons guitars. This was quite a many years back, but I'm sure it was done before him. I don't get out of my shop much or see many others guitars though so I'm sure someone has a much more informed answer than this.
PostPosted: Tue May 24, 2011 10:09 am
Why does it matter who did it "first"?
Burton
Brookline, MA.
PostPosted: Tue May 24, 2011 11:12 am
Cool. I was just curious. Thanks for the response.
Burton
Brookline, MA.
PostPosted: Tue May 24, 2011 11:16 am
First name: Bruno
Last Name: Piancatelli
Country: Argentina
that kind of purfling looks real nice and solid.
do you need to bend it on a hot pipe or it just bends cold?
PostPosted: Tue May 24, 2011 12:14 pm
Todd Stock wrote:
No bending...just snap it in like shell and soak the channel with CA...very easy to do. Toughest part is cutting the strips to consistent width.
Todd, do you cut yours close to width, and then dial it in with a thickness sander?
That seems one way to skin the cat...
Just wondering.
PostPosted: Tue May 24, 2011 1:39 pm
Last Name: Ensor
City: Springfield
State: Missouri
While I am sure the snapping in method works, I have had some trouble with consistence on width. I now glue up a few pieces to length, cut them a little wide, then sand them to exact width. I also laminate my outside purfs on it and bend them. I have found this method to work just fine.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Tue May 24, 2011 7:31 pm
Thanks guys,
PostPosted: Tue May 24, 2011 7:37 pm
First name: Darryl
Last Name: Young
State: AR
Todd Stock wrote:
I cut on the tablesaw using a cover plate...consistent to .002, so good enough. These are tiny little strips...
Forgive my ignorance, but what do you mean by a coverplate?
PostPosted: Wed May 25, 2011 1:45 pm
I just glued up pieces into a big stick and bent mine. Ignorance is bliss !
PostPosted: Wed May 25, 2011 3:17 pm
Last Name: Ellis
City: Manteca
Zip/Postal Code: 95337
Waddy, that is the best rosette yet! Is that your latest?
Absolutely gorgeous!
PostPosted: Wed May 25, 2011 7:07 pm
Thanks, Steve. That is my most recent. It'll be #9, and my first WRC top - Pau Ferro back and sides. I thought the radial Zebrawood would fit nicely.
PostPosted: Wed May 25, 2011 9:16 pm
Last Name: Ensor
City: Springfield
State: Missouri
I also like zebrawood for radials. I am using it on a maple/sitka auditorium. It is paired with a zebrawood rosette and end wedge. Should be finished soon.
PostPosted: Thu May 26, 2011 7:15 am
I agree that it is cool but nothing new. One of my first guitars I built back in the 70's had brazilian tulipwood (Dalbergia frutescens) crosscut strips since it is very distinct in color with gold/red stripes.
The person that suggested it to me if I remember was Thomas Humphries who at that time was working in Michael Gurian's shop. He was talking about how the french bombard furniture would use tiles of tulipwood with the grain arranged like a checkerboard and that the english would use satinwood and other exotic grain woods but as lines to frame the tops and drawers of furniture.
He explained that rope, herringbone and other ornamental purfling came to be as a way to bend wood around a radius but that theoretically there was no reason why a thin crosscut strip could not be used if it was a species in which the grain was more pronounced.
Note that I never saw it one of his classicals as back in those days the guys in the Gurian shop were building mostly steel string with a much smaller number of classicals.
Users browsing this forum: A.Hix, jfrench, Ken Lewis and 15 guests
