It is currently Sun Jul 27, 2025 1:09 pm
 Post subject: First CNC Inlay
PostPosted: Tue May 10, 2011 9:39 am
Hi all. Well, the bad news is that my wife had a small stroke a few days ago that gave us all a big scare. The better part of that is that although she has lost her vision to the right side (both eyes work fine but her brain is not processing the signal) it seems that it will recover after a few months. She has no other issues that we can see. For the time being she can't drive and as we live out of town with young and active boys (sports and music and friends) that can be an issue. So if her vision does not recover we will be moving into town but we are waiting for a while and hoping for the best!
So, as my re-saw is a couple of kilometres away I have not been to saw wood for a while and have been instead working on cnc skills. I have a great "tutor" in Michael Turner and he is guiding me through my journey. The other day Dave White (our friend from England and a long time friend and customer) asked if I could do a headstock logo for him for one of his commissions. It is the Leo astrological sign. It will be African Blackwood into Yew. There is always a problem with dark wood into light as the gaps are harder to hide. Anyway, in anticipation of the wood he is forwarding for this headplate I ran a test of EIR into maple. I think it turned out great and look forward to seeing the finished product in Dave's wood on his finished guitar! Here is the sample I sent him last night:
The "legs" are about .080 wide and the inlay is about 1.5" long. I am excited and will indeed be doing a lot more of this.
 Post subject: Re: First CNC Inlay
PostPosted: Tue May 10, 2011 9:57 am
First name: Tony
Last Name: C
City: Brooklyn
Cool stuff. Nice work on the inlay.
http://www.CostaGuitars.com
PMoMC
PostPosted: Tue May 10, 2011 9:59 am
Looks outstanding Shane. Here's hoping your wife makes a quick and full recovery.
Jim Womack
Will Rogers
PostPosted: Tue May 10, 2011 10:01 am
Looks really good!
So, How did you hold down the EIR during machining?
What kind of clearance did you use for the inlay? Did you program that in to the cad model or did you use tool size adjustments for that?
PostPosted: Tue May 10, 2011 10:11 am
Andy Birko wrote:
Looks really good!
I held the EIR and the maple down with double back tape and used a .060 upcut spiral bit, stepping down .030 per pass so very little torque on the wood. I left a .003 gap all around (so .006 clearance) with and offset curve, the space for glue and fitting is programmed rather than tool adjusted.
PostPosted: Tue May 10, 2011 10:14 am
Shane I'm sorry to hear about your wife. I hope she has a full recovery.
Inlay looks great.
PostPosted: Tue May 10, 2011 11:56 am
Just regular carpet tape or did you use something special?
The other thought I had was that one could use a much thicker piece of stock for the inlay, cut deep but not through and liberate the piece on a table saw. A little risky though. I've done that before (with non CNC parts - possibly a ring of some sort) and kind of recall a piece disintegrating it the pocket when it hit the back teeth on the blade.
Oh, and I hope your wife has a speedy recovery!
PostPosted: Tue May 10, 2011 12:08 pm
Nice work Shane!
Brad
Avon, OH
PostPosted: Tue May 10, 2011 12:13 pm
Very Nice!!!!
PostPosted: Tue May 10, 2011 12:40 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I am sorry to hear about your wife, I wish her a full recovery. I hope your CNC work does not get too much in the way of your resaw work, we would miss the great top wood.
Fred
Fred Tellier
PostPosted: Tue May 10, 2011 1:29 pm
First name: Corky
Last Name: Long
City: Mount Kisco
Shane -
Best wishes to your wife for a full recovery!
PostPosted: Tue May 10, 2011 2:07 pm
Last Name: Ball
Well, the question wasn't addressed to me, but I cut a lot of inlays on my CNC and I can tell you what I've learned. First, thicker, stronger double sided tape (like the good carpet tape you can buy) doesn't work well. Although I've used a lot of this kind of tape for holding down wood when I don't have a vacuum jig set up to hold it, and it works pretty well in this way, it is too "springy" for accurate inlay cutting. I've found that the really thin, but strong clear double sided tape works well.
The other thing that I've done is to use white glue to glue the inlay to posterboard or thin plywood, and then cut through the inlay material, but not through the backing. With pearl, you can soak the backing/pearl in water and the inlays come loose. Couldn't get by with that for wood inlays, but posterboard sands off really easily. I cut the inlays so that the posterboard is facing up when they're actually inlaid (sometimes this requires reversing the inlay before cutting it). That way, when you sand the inlay flush to the surface it's inlaid in, you sand the posterboard off first.
Just my .02.
PostPosted: Tue May 10, 2011 2:15 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Nice CNC work my friend!
But the wives stroke !
I hope she makes a full recovery & you can handle the kids & all !
She needs ya now!
Man -"if ya didn't have bad luck-you'd have NO luck at all"
Mikey ;)
Mike Collins
PostPosted: Tue May 10, 2011 5:25 pm
Shane, best wishes for your wife to make a speedy and complete recovery.
Bob
PostPosted: Tue May 10, 2011 5:44 pm
She needs ya now!
Mikey ;)
Mikey!! I only have one wife! I wouldn't know what to do with more than one, I can barely keep up with this one! Anyway, Val is actually in very good spirits and will get part of the spring off of work to kick about the house and work on her garden (I hope!)
Thanks all!
PostPosted: Tue May 10, 2011 10:29 pm
First name: Danny
Last Name: Vincent
Man, sorry to hear of your wife's dilemma. Another one of life's crappier curve balls for sure. I hope she makes a full recovery. Please give her my best.
The CNC work looks great. Have you figured out how to get it to finish your guitar. :lol: Just kidding. We have to pick our battles and I know you have a lot on the go.
I know you'll make things work out well. All the best and I'll be in touch for some product in a couple of months.
Cheerio,
Danny
BTW, Got the "shake down" from your goons. :lol: They're good guys.
PostPosted: Tue May 10, 2011 10:45 pm
Just my .02.
Andy, I used the same thin stuff that Dave talks about. I think I actually found a 2" roll and just band sawed it half to two 1" rolls a good long while ago.
Danny....I will pass the word on to the goons... laughing6-hehe [uncle] ! Looking forward to talking to ya!
PostPosted: Wed May 11, 2011 9:41 am
First name: George
Last Name: Thomas
Shane:
Best wishes for a full and speedy recovery for your wife.
Nice work on the CNC practice. it looks great. Let us know when you are ready to add this service.
GEO
perpetual beginner
PostPosted: Wed May 11, 2011 2:11 pm
Best wishes to your wife Shane ...
PostPosted: Wed May 11, 2011 7:24 pm
Shane - best wishes to your family.....the CNC looks great....no rush with my order (really! I probably don't need any of it! I wouldn't miss it for 6-12 months). Take care of what's important first!
Laurie
PostPosted: Sat May 14, 2011 11:35 am
Prayers for your wife, Shane.(well,you too and the kids;I'm sure it will be a family effort)
PostPosted: Sat May 14, 2011 1:29 pm
First name: Hugh
City: Lake Oswego
State: oregon
Best wishes for your family. Not to show how little I know, but does the cnc cut both the inlay piece and the channel?
PostPosted: Sat May 14, 2011 6:39 pm
All the best to your wife and a speedy recovery.
Practice makes perfect on inlay whether it be CNC or by hand.
Looks pretty go though. :)
PostPosted: Sat May 14, 2011 7:01 pm
Hey Shane
All the best to your wife! I can't think of a nicer place to recover.
Nice work on the inlay!
Bob Hames
Users browsing this forum: Ken Lewis and 16 guests
