It is currently Sat Aug 09, 2025 1:59 am
PostPosted: Fri Mar 25, 2011 5:43 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I see that Dicks tool sells some HSS chisels, besides being expensive as hell, is there any real advantage to chisels made out of this material?
I do wonder if anyone actually made a tool out of old HSS drill bits...
Typhoon Guitars
PostPosted: Fri Mar 25, 2011 6:07 pm
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
The advantage of HSS over regular tool or carbon steel is that they stay sharp longer. The downside being that they are a little harder to sharpen. Actual cutting action should be similar.
Hope that helps. :)
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Fri Mar 25, 2011 6:41 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Hope that helps. :)
Yes, but are they more brittle/more prone to chips and cracks, etc?
I know many Japanese carbon steel tools are hard (as in around 64 RC) but the hardness actually makes it brittle.
Typhoon Guitars
PostPosted: Fri Mar 25, 2011 7:09 pm
I thought that HSS was more for turning in that it's more heat resistant than regular tool steel. Hence the "High Speed" in HHS. In other words, if you're not heating the tool much in use, there's no advantage to HSS.
PostPosted: Fri Mar 25, 2011 8:18 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I may be wrong, but I thought all "modern" chisels were tool steel or high speed steel as opposed to carbon steel.
If I'm wrong, I'm sure it won't take long for someone to chime in.
Kevin Looker
edit:
OK, I need someone to clarify the difference between "tool steel" & HSS. Is carbon steel the same as tool steel?
I'm not a luthier.
PostPosted: Fri Mar 25, 2011 8:21 pm
First name: Phillip
Last Name: Patton
City: Yoder
It depends on the steel. Some are more brittle than others. Brittleness depends on the alloys used in the steel, as well as the heat treatment. Lower grade steel with a good heat treatment will outperform higher grade with poor treatment.
Regards,
Phillip Patton
PostPosted: Fri Mar 25, 2011 8:36 pm
First name: Tom
Last Name: West
State: Nova Scotia
Carbon steel comes in different classes depending on the amount of carbon. Ranked from low to high with the same range of hardenability. Generally not used now a days for tools. Tool making been taken over by the various so called tool steels and HHS generally related to the metal machining trades. A certain amount of cross over for all the steels in their use depending on the purpose of the specific tools.
Tom
