It is currently Wed Jun 25, 2025 3:37 pm
PostPosted: Mon Feb 21, 2011 3:44 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
I have used a flat top on the steel string guitars I have built so far and I was wondering If I could do the same for the a classical top. I have one 20' dish I use for the back, but lack the funds and recourses to make/buy another one for the top.
PostPosted: Mon Feb 21, 2011 3:46 pm
Country: Romania
Sure. Use a Hauser plan.
Build log
PostPosted: Mon Feb 21, 2011 3:53 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
You don't need a radius dish to create radii. What's your building method? Solera?
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Mon Feb 21, 2011 4:09 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
I don't have any work boards or jigs, other than my bench, a piece of plywood and the back dish
PostPosted: Mon Feb 21, 2011 4:24 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Free hand? So you should go for a flat-top.
PostPosted: Mon Feb 21, 2011 9:50 pm
First name: Tony
Last Name: C
City: Brooklyn
For a radius clamping caul on the cheap, check this out:
http://kennethmichaelguitars.com/contourcaulkitinstrction.html
You will be able to clamp your radiused braces and when you are done, you will have a nicely contoured top.
I have used that method and it works and at $1.25 for a pack of index cards, it is a heck of a lot cheaper than a radius dish. You can clamp the top on using rubber bands for another $2.00.
Not everyone can afford a couple of radius dishes.
Hope you work it out.
http://www.CostaGuitars.com
PMoMC
PostPosted: Mon Feb 21, 2011 9:55 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
That won't help me, but thanks
PostPosted: Tue Feb 22, 2011 8:27 am
That's very interesting but this problem is easily solved by using a flexible slat as a clamping caul. I've been doing it like that for almost 20 years now. Hope I'm not missing something?
As for flat top classical, I've never tried it before but after building my first true flat top steal string a few months back it sounds very interesting. Go for it!
PostPosted: Tue Feb 22, 2011 8:31 am
First name: David
Last Name: LaPlante
Brian, simply sand a bit of radius into your braces (just the main two harmonic bars above and below the sound hole) and clamp them flat to your surface when gluing. They will spring back (albeit to a lesser dgree) and impart a slight arch to your top. A slight arch is desireable as completely flat tops tend to go concave. Slightly arched ones, most likely in the case of Hauser over time flatten out.
PostPosted: Wed Feb 23, 2011 3:49 pm
Country: Romania
Another thing you can try is to brace it flat in very low humidity, say 30%. At over 40 it will get a belly.
Build log
PostPosted: Wed Feb 23, 2011 10:57 pm
Like the rest of us
