It is currently Tue Aug 05, 2025 6:00 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
PostPosted: Tue Feb 08, 2011 8:27 am
Hello all,
I finally got the pro pix back from the shoot of the Belair harp guitar, so named for tis 57 Chevy'ish tail fin, which I turned into an armrest.
The guitar is made from flamed makore, with a lovely lutz top from Shane. Rosettes are spalted maple, with blk/green/blk prufling lines. The binding, armrest veneer, bridge, and headplates are all african blackwood. Fingerboard is ebony. The scales for the multiscale fingerboard, where the reference is the nut which is straight, are 25 and 25.5 inches. The nut is 1 3/4, bridge spacing on the guitar is 2 3/16 (approx 56mm). The harp sub strings are spaced 9mm apart at the saddle. Harp ubs are tuned alal Stephen Bennett std tuning, GABCDG low to high. Gauges are 45, 54, 60, 62, 66, 72, John Pierce, from harpguitars.net .
Internally, the bracing is modified Dyer, with a few of my additions/deletions (for instance, the X goes all the way to the linings, and the bridge plate is smaller, and is not tucked under the X like a Dyer has in the GAL plans). I also added two 1/4 inch CF tubes from the neck block to the sides as buttresses.
PostPosted: Tue Feb 08, 2011 8:34 am
State: ON
Stunning my friend!
So is this one for sale? Or are you keeping it for yourself?
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Tue Feb 08, 2011 9:00 am
Wow Tony! It is beautiful. I am jealous. I love the finrest.
Burton
Brookline, MA.
PostPosted: Tue Feb 08, 2011 9:04 am
Wow! Beautiful work Tony. Those spalted rosettes look great. [:Y:]
PostPosted: Tue Feb 08, 2011 10:44 am
It turned out fabulous Tony!
Congrats
PostPosted: Tue Feb 08, 2011 11:16 am
First name: Heath
Last Name: Blair
City: Visalia
oh man, thats so great. love it.
sweat the small stuff.
PostPosted: Tue Feb 08, 2011 11:37 am
Stunning modern take on a classic!
PostPosted: Tue Feb 08, 2011 11:38 am
First name: Danny
Last Name: Vincent
wow7-eyes Outstanding! The work around the neck is most impressive. What sort of neck joint do you do?
Cheers,
Danny
PostPosted: Tue Feb 08, 2011 12:11 pm
Ditto to all the above. Gorgeous Tony!
Milton, ON
PostPosted: Tue Feb 08, 2011 12:15 pm
Congrats Tony! She is a beautiful thing with amazing lines. She sounds wonderful too! So when is Stephen going to take her for a test drive? Who doesn't want to drive a '57 Belair!
Rick
PostPosted: Tue Feb 08, 2011 12:17 pm
That is beautiful! I'd be sooo intimidated, with all those strings.
PostPosted: Tue Feb 08, 2011 12:20 pm
Impressive! I too would be interested in what type neck joint you used on this instrument. I've seen those that have used a Spanish heel on steel string harp guitars. Again, WOW! Clinton
PostPosted: Tue Feb 08, 2011 1:45 pm
First name: David
Last Name: Wren
State: ON
Zip/Postal Code: M4C 4X5
Tony ... that is just simply STUNNING ... the lines, the design, the execution ... what a masterpiece!!! I'd love to see a full front shot too if you've got one?
David Wren http://www.wrenguitarworks.com
PostPosted: Tue Feb 08, 2011 2:21 pm
Super nice Tony!
PostPosted: Tue Feb 08, 2011 3:27 pm
Wow. Amazing. There are so many things about that guitar that I wouldn't have a clue how to do. Very inspirational. I second the request for a full front photo.
Thanks for sharing.
PostPosted: Tue Feb 08, 2011 4:04 pm
First of all a huge thanks to all who posted the kind words. This was a true labour of love, as I had wanted to have one ever since I first saw Stephen Bennett play his Dyer copy a few years back, and to be able to play some of his great tunes. He has some new stuff out on Firefox, with video and tab for learning a bunch of his harp stuff. I am slowly working on a couple of them, it takes some getting used to, trying to find the right sub as you are playing fingerstyle on the guitar neck - I feel like a rank amateur player again, not that I am that good anyway, but I try hard [headinwall]
It took me about two years to build this, although other guitars got in the way, but all the while I was thinking about how to do certain parts. The neck is a butt joint, two bolt affair. It took most of a day to fit properly, as the compound curve is pretty extreme - I kept having to pair away from the bass side heel area until the treble side began to fit tight, then lots of flossing to get it tight and centred. The harp headstock is a two piece unit glued up, and then routed thinner where the tuners mount. After seeing Michael Greenfield's harp in Montreal last year, I will be modding this area to accept a bolt on headstock into an internal block, but it will still look pretty much like this one does. Just easier IMO. I used my 18 and 28 bowls to shape the rim both front and back, with some flat boarding out to the harp headstock area - it blended nicely, it was one of those well lets try and see what happens things, and it worked. In my mind I wasnt so sure.
Josh .. its available, although I am playing it now - I will have it at the Moonshine show !!! My personal keeper will be more like a Dyer style 8 in apptointments, they have way more shell, and made from some crazy pomele/flamed/figured sapele I have. Top will likely be some bearclaw sitka.
I though I had the full frontal in there, but I guess not !!! As well, a bridge closeup - had to make a special three bolt clamp for this one, thru three of the pin holes.
*** Finrest .. now why didnt I think of that - very cool Burton !!!
PostPosted: Tue Feb 08, 2011 4:39 pm
Last Name: Kincheloe
Beauty! I can't wait to build myself one of these things.
That neck joint does indeed look like a beastch.
The bridge is gorgeous. Love the continuous row of pins. That highest sub-bass looks like it's falling off the edge of the saddle though... or is it just barely hanging on?
Nice bass peg head shape as well. Much better than those funky Mickey Mouse ears on most of them.
And you must post some sound clips once you get those tunes practiced up to a decent level :)
What strings are you using?
PostPosted: Tue Feb 08, 2011 4:54 pm
Hi Dennis, thanks.
Yes the highest sub is close to the saddle edge, it has about 2 or 3mm there .. that end of the sub string saddle has very little round over, so it wont fall off. Again, a design decision,. I wanted the subs to be as close to the reg guitar strings as I could get, to minimize the thumb stretch while playing. I will likely widen the sub spacing to 9.5 mm on future harps, a slight difference from the 9mm now, a little more between as I do reach and hit an adjacent one while trying to play a tune ... but that could just be me though !!! But most Dyer copies have wider spacing, this was just my idea.
Harp sub basses - from www.harpguitars.net, Gregg Miner's harp site - I am using the Stephen Bennett tuning John Pierce set (now there's a surprise), in light/med gauge - they are gauged 45, 54, 60,62,66,72, and tuned GABCDG low to high. You have to drill out the lowest tuner to fit anything 70 an over, but the others are fine. Its quite amazing to hear that 45 gauge tuned to G, in comparison to a G on the guitar lkow E fretted 3rd fret .. the harp is clearer, and rings FOREVER .... same with the harp D, as compared to the guitar in drop D tuning.
As for me playing and recording .. HAH ... that might take a while ... Might have to get my pal Carter Lancaster to do that for me, he lives about 30 minutes away - check him out on Youtube .. he started playing harp a few years ago and is remarkably talented at it ... Stephen likely would as well, but he lives quite a ways from here !!!
PostPosted: Tue Feb 08, 2011 5:54 pm
WOW.
Just, wow!
PostPosted: Tue Feb 08, 2011 6:10 pm
First name: Al
Last Name: Darned
yowza! ... O.o ... sweet tony, congrats:)
If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason. - Jack Handey
PostPosted: Tue Feb 08, 2011 11:12 pm
Off the charts, Tony. I love the simple bridge solution.
PostPosted: Wed Feb 09, 2011 12:31 am
I have come to expect great work from you, Tony. But you are raising the bar. Outstanding!
PostPosted: Wed Feb 09, 2011 1:25 am
Wow!
PostPosted: Wed Feb 09, 2011 1:44 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
Cool armrest and bridge too. Work of art. [clap]
Jason Moe
LaCrosse WI 54601
PostPosted: Wed Feb 09, 2011 10:02 am
Tony, you have managed to work some beautiful angles into a well-designed whole. Great work! How do you like the multiscale fretboard with a straight nut and how does it affect the size and shape of the bridge plate and bracing? Any chance of seeing the bracing of the top? For me an angled nut on a multiscale fretboard might help with the bracing layout and design but makes it awkward for barre chords in the first position.
Ken Franklin
clumsy yet persistent
Users browsing this forum: Bing [Bot], bobgramann, doncaparker and 18 guests
