It is currently Fri Apr 17, 2026 7:15 pm
PostPosted: Sun Jan 23, 2011 4:35 pm
Last Name: Nowicki
City: Mequon
State: WI
Zip/Postal Code: 53092
Hello All,
Was thinking of buying a vintage 61 flamenco but it has 1 problem. Someone glued on a white golpeador on 1 side with hide glue, and the guitar has a clear golpeador on the other side. The guitar has a spruce top and is french polished. Is removing a golpeador glued on with hide glue a risky proposition with regards to damaging the top under it? I have removed a couple of clear mylar golpeadors with a heat gun and goop be gone with no problems but this I suspect is a far more complicated project that I would have done by a professional. Thanks....
John Nowicki
PostPosted: Mon Jan 24, 2011 2:18 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
White meaning plastic or wood?
I would gently feel under it with the same tool I use for bridge removal
a thinned and rounded edge putty knife.
Hide glue can separate easily if used on plastic.
Go slow.
Mike Collins
PostPosted: Wed Jan 26, 2011 9:04 pm
Last Name: Nowicki
City: Mequon
State: WI
Wood....
John Nowicki
Users browsing this forum: Pmaj7, rbuddy and 23 guests
