It is currently Thu Aug 07, 2025 9:55 am
PostPosted: Tue Jan 18, 2011 11:08 am
First name: Corky
Last Name: Long
City: Mount Kisco
I'm resetting the neck on an old 1910 Stetson guitar, I'll post some pictures once my other computers back up - very interesting project actually - I've posted questions on it elsewhere here.
Anyway, it's clear this beautiful little parlor was built for gut. Ladder braced, and the depth of the neck block is about half of what we'd use for a steel string these days. The neck joint was "enhanced" - maybe at a later date - but a dowel that was glued straight through the neck block, into the heel of the neck. Yes, removing the neck was not pretty, and will require some repair skills.
Given the construction of this guitar, I won't be using my normal "light" strings on it. I think it would implode very quickly.
What's the relative tension of nylon versus "silk and steel"? Ultralight?
I'd like that steel string sound, but if that's not feasible, I'll string it with nylon if I have to.
Thanks.
PostPosted: Tue Jan 18, 2011 11:52 am
Did a bit of a search, Google -
Here's Daddario's http://www.daddario.com/upload/tension_chart_13934.pdf
Read the pre-amble with the info, but the info seems standardised for 25.5" scale for both SS and classicals, so they can be compared directly.
I suspect even the lightest steel strings will still be higher tension than average classicals.
Hope that helps
PostPosted: Thu Jan 20, 2011 2:51 pm
First name: Corky
Last Name: Long
City: Mount Kisco
Thanks, Colin. This is indeed some comprehensive info. I'll do some calculations. Thanks.
Users browsing this forum: DennisK and 38 guests
