It is currently Mon Jul 21, 2025 2:06 am
 Post subject: Shellac over stain
PostPosted: Sat Dec 25, 2010 7:03 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
Hi!
I begin to mess around with french polished shellac a bit. It's holidays, so I have some free time to try different recipes and make some tests. I have an bass body that I stripped a while ago, and wanted to refinish it with shellac, for fun and for experience. So, I began to make tests with shellac over stain.
First, I try to put few coats of shellac on a waterbase stained piece of curly ash (green...), and polish it. The stain bleeded on my rag, but I didn't find it abormal. Staint didn't seem to be fade, so I let it dry, and begin to polish. And then, more and more, the stain began to go away.
I thought maybe I didn't wait enough to let the stain dry completly. So, I grabbed a piece that I had stained few months ago, and redo the same experience. Same results. The stain began fade on the first coat of shellac.
Maybe an oil-based stain will be better? Or should I use some sealer between the stain and the finish?
Thanks!
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
 Post subject: Re: Shellac over stain
PostPosted: Sun Dec 26, 2010 10:43 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
It would probably work if you sprayed light coats on instead of wipe.
James
James W Bolan
Nashville Tennessee
PostPosted: Sun Dec 26, 2010 4:16 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Francis, I agree with James. I don't know what stain you are using, however, I spray shellac over oil stains (I always let them dry a few days) and have good success with it. Seems like you could french polish over a spray coat, or follow the sprayed shellac with just about any varnish or lacquer. I know for certain it'll work with oil varnish, waterborne lacquer and nitro lacquer.
